Oops...forgot the MAF sensor...check engine light on!
Hi everyone,
So, I took off the air box to do some good cleaning. When I put it back on I forgot to reconnect the MAF sensor (I know, I know...). Then I started the car. Well, everything seemed well but then the check engine light came on. I turned it off and reconnected the MAF sensor. It has been a few days now and the light is still on.
Doesn't this thing recheck at some point? What's the best way to clear it? Hit up the auto parts store for a free "check"?
Thanks,
Mike
Thanks,
Mike
Re: Oops...forgot the MAF sensor...check engine light on!
I did the exact same thing when installing my block heater.
Fortunately I have a ScanGuage. With it I was able to find and clear the code. So, yes, your auto parts store should be able to clear it.
I'm glad we don't need the kilobuck Toyota scantool to do this...
It will clear itself after so many cycles, don't worry about it.
cak615
10-28-2013 08:11 PM
sherritp
02-11-2013 11:50 PM
SadCarTime
07-09-2012 08:05 AM
sandykor@sbcglobal.net
12-01-2009 02:50 AM
