Oh well!
Old Dec 21, 2007 | 11:28 AM
  #51
skywagon's Avatar
Default Re: Oh well!
Originally Posted by alan_in_tempe
Another way to look at it is that a locked up tire looses grip in all directions, and can no longer track; it can slide sideways as easy as it can slide forwards. Non-slipping rear tires keep the rear tracking, following the front tires.
If the non-slipping rear (or front) tires are leading, then the slipping front (or rear) tires are not so likely to follow the rear. Any side slipping of the trailing tires will yaw the car, steering the leading/tracking tires in the opposite direction which increases the yawing, which leads to a very rapid 180 spin until the tracking tires are then allowed to follow. Even if the rapid spin causes the previously tracking tires to begin to slip, there is a good chance they will regain traction as the yaw realigns those tires back to the direction of forward motion (although those tires will then be turning in the opposite direction as the car will have spun half way around).
It takes extremely good reflexes to control a car with a rear end lock up, requiring almost violent steering inputs.
-- Alan
All this fuss about snow tires and traction!! Just plain take your TCH out on the frozen lake and play with it so you know how it acts, it will save you a possible accident. This car after (owning many 4x4 trucks and all wheel drive vehicals) has to be one of the safest ones out there on ice and snow. try it you will like it. Also use the B gear, floor board it and make sharp turns, mine will not go into any kind of a slide Period!! Lock the brakes in a turn, it really performs. PS just make sure you stay clear of the ice houses lol.
johanerlandsson
Jun 16, 2004 12:24 AM
xcel
Apr 15, 2004 04:23 PM
Stevo12886
Off Topic
Feb 4, 2004 11:58 AM
opie420
Jan 29, 2004 05:48 PM
