Now that's just silly
In planning an upcoming long summer drive, I started planning luggage n' stuff in the TCH trunk. One of the items going is a small electrical cooler. Now wouldn't you think with the 12v battery back there, and the big battery taking up all that space there'd be a 12v receptical in the trunk? There's enough juice back there to power a small city for a year, yet no plug. That's just silly.
Re: Now that's just silly
Buy a 10' extension cord (example: http://cgi.ebay.com/12V-12-V-CIGARET...QcmdZViewItem), and run it up front through the seat pass-through hole to your outlet up front.
Thanks for the suggestions.
I thought about this, but given I'm a most forgetful individual (I'd forget my name if it wasn't tatooed backwards across my forehead) I'm worried I'd leave the wee little cooler plugged in and come out to a dead battery. I think running an extension cord as Abward suggests might work. Don't know about Kris' spark concern as the car has a process for being jumped or doing the jumping which can cause quite a bit of sparking. Or, now I'm thinking of shoving the cooler in the back seat with the kids. So many decisions...
You have to lift up the rear seat bottom and unscrew one bolt holding the right portion of the rear seat in. You will see the opening there.
You can then run it under the door sill then over to the outlet.
eradicator
07-10-2008 01:16 PM
