New Tires
Old Jul 20, 2007 | 05:19 PM
robertru's Avatar
Default Re: New Tires
Anyone out there move up to 17" tires? If so how did they affect ride and FE?
Old Jul 20, 2007 | 09:02 PM
rburt07's Avatar
I see in the Camry brochure that they only offer the 17" with the gas only powered models.
The hybrid shows to have only the 16", 8 spoke alloys. If you went to a larger wheel and tire it may rub. The engine and EV motor would not have the correct rpm in relation to the highway. The speedometer would also not be correct.
My Ford Five Hundred has the 17" wheels. That narrows it down to about 3 brands of tires. Two of the good brands in that size cost upwards to $750 drive out price.
Yes, the 17" tires might give a little better ride. A cars ride depends a lot on the car manufactures suspension.
Old Jul 21, 2007 | 08:57 AM
robertru's Avatar
Guess I should have been clearer. The 215/55-17 is a direct replacement for the original 16" tires. Same diameter etc. so no clearance or speedo problems. The sidewall is a bit stiffer, hence the ? about ride. The only reason I'm asking is because I think the 16's look a bit lost on the car.
Old Jul 21, 2007 | 05:29 PM
abward's Avatar
I guess I missing something...how can a 17" tire have the same diameter as a 16" tire?
Old Jul 21, 2007 | 06:41 PM
robertru's Avatar
Side wall height is lower thus allowing for the extra inch in rim diameter. Go to tirerack.com and it will show you replacement sizes up to 19". The lower side wall it stiffer and the ride gets harsher as there is less flex.
Old Jul 21, 2007 | 08:31 PM
rburt07's Avatar
I did look at Ford. Their Five Hundred comes standard with 17" / 60 series tires. The Limited which is there loaded luxury car comes with 18" / 55 series tires.
You can go to the tirerack.com/ site. Choose your tire and then, specs. This may be where they list the actual turns of the tire in a mile. Look up the tires you use now and compare them You may have already done this. I do understand the 55 series are a little wider and are closer to the ground. I guess the ride is the same or they would not put them on their high end Ford. I don't even know what tire Toyota uses on the Avalon.
Old Jul 21, 2007 | 08:41 PM
rburt07's Avatar
I looked at the brochure. The 16" tires does seem to make the car look a little larger. You might want to check the weight of the 16" vs the 17" tires. A few pounds of spin up weight per tire may slow you some from a standing start.
Old Jul 21, 2007 | 10:18 PM
jrb_nw's Avatar
Your ride will be a bit stiffer with the lower profile sidewall, but it should feel a bit more responsive, all other things remaining equal - type of tire, etc. Which wheels are you going to use?
Old Jul 22, 2007 | 04:10 AM
robertru's Avatar
Was looking at the SE wheels. New car take offs on ebay $399 for set of 4 from Rusty Wallace Toyota
Old Jul 28, 2007 | 06:33 AM
MFLetou's Avatar
ag--
I was told by my dealer this morning that my OEM Bridgestones have just 2/32's on them and need to be replaced!
I have 24,000 miles on them. NOT happy. They had been rotated once and there has been no sign of an alignment problem.
