New Squeak - the eyeglass case
Old Aug 25, 2006 | 06:11 PM
ByronJames2003's Avatar
Default New Squeak - the eyeglass case
I noticed another squeaking that seems to show up only when it's cold outside. I had the center console squeak fixed at the dealers weeks ago. This evening as I heard the "cold" squeak began...I happened to reach up and push the sunglass case...and voila...the squeaking stopped!....I tried it repeatedly (actually ignoring my MPG meter for 15 minutes-incredible) and the case is definetly the source of the sound. I am not sure if it's the fact that there is side to side play in how it rests in it's moorings.....or if it's not held firmly enough when it is shut.
Anyone else notice this sound yet. Again it only makes this sound when it's "cold" (below 65 degrees)
Also...there were no glasses in the case at the time.
Byron
Old Aug 25, 2006 | 07:16 PM
stevenvillatoro's Avatar
Arrow Re: New Squeak - the eyeglass case
Occasionally, I have a tiny, tiny, tiny vibration (too small to call a rattle) from the top of the driver's door window. It stops if I lower the window even 1/16th of an inch (hard to do). Others?
Old Aug 25, 2006 | 08:11 PM
Default Re: New Squeak - the eyeglass case
Yep....I get the same thing on both drivers and passengers side, and opening the window a bit does tend to fix it.
Byron
Schwa
Dec 15, 2007 03:21 PM
bwilson4web
Nov 6, 2006 01:53 PM
hsolo142
Nov 4, 2006 09:53 AM
Delta Flyer
Honda Insight
26
May 8, 2006 07:55 PM
cdbrow1
Jul 14, 2005 09:28 PM
