New Garmin 680 nav question (MPH)
Old Aug 5, 2007 | 10:33 AM
JOE540CI's Avatar
joe540ci
Default New Garmin 680 nav question (MPH)
The 680 shows the vehicle speed. At 60 mph on the camry speedo the garmin shows 57 mph. Witch one is most accurate?
Old Aug 5, 2007 | 11:42 AM
Pete4's Avatar
Default Re: New Garmin 680 nav question (MPH)
Garmin. Search the forum and you'll even find out why.
Old Aug 5, 2007 | 11:53 AM
stevil's Avatar
Lord of Time and Space
Arrow Re: New Garmin 680 nav question (MPH)
The Garmin may be closer - the speedometer is allowed to read high, but not low, per UN regulation:
http://www.unece.org/trans/main/wp29...egs/39rv1e.pdf
The relationship between indicated speed (V1), and actual speed (V2), according to the regulation is:
0 ≤ (V1 - V2) ≤ 0.1 V2 + 4 km/h
So, indicated speed will always be equal or greater than true speed, by no more than 4km/h plus 10% of true speed.
However, none of this guarantees the Garmin is correct, just that there is no specific regulation requiring your GPS receiver to be inaccurate. It too has an inherent margin of error, based on signal reception, and any embedded error should the military authorize it, but many GPS units will display the anticipated error on one of its screens.
Why does the UN get involved in this? Who knows? But there we are.
Old Aug 5, 2007 | 12:27 PM
talmy's Avatar
They are acting as an international standards body. Since cars are sold globally, this provides a world standard. AFAIK the UN cannot enforce any of these standards, but member nations have something to adopt. For instance, even though the standard has been around since 1958, Japan only agreed to it in 1998!
Old Aug 6, 2007 | 01:57 PM
voodoo's Avatar
Have TCH with factory NAV. How do I read the ground speed on this GPS NAV system? because I can't find this read-outanywhere.
If this GPS DOESNOT give the speed... it has to been the only one in the world that does not have this feature?
Old Aug 7, 2007 | 03:43 PM
JOE540CI's Avatar
joe540ci
I just did a simple mile post check against the odometer (tripodometer) I could not do a long enough test to really tell much , but the car seemed to register 1 mi about two car lengths before i got to the next mile post. this could have a small affect on my MPG. Has anyone done tests with mph or odometer readings against there nav ?? Next up for me will be a tri-fecta. the odometer VS the nav VS the mile posts, for miles traveled. If this stuff is in older posts maybe someone could refer me to them. JOE
tcampb01
Jun 4, 2009 04:54 PM
bar10dah
Dec 8, 2007 02:26 PM
KimikoPi
Jul 19, 2007 05:35 PM
jimmy1
Nov 13, 2006 03:34 PM
bwilson4web
Apr 1, 2006 12:23 PM
