New 2007 TCH owner, have questions
Old Oct 10, 2017 | 01:17 PM
mitrals's Avatar
Default Re: New 2007 TCH owner, have questions
I did not get the codes checked. I have a feeling that the codes came cause the car sat for extended periods of time or something else triggered the code. I have noticed that highway driving gets me 35+ mpg and longer local drives get me about 34mpg. The shorter drives seem to be terrible for the battery.
Old Oct 10, 2017 | 02:02 PM
They are certainly terrible for economy, and they aren't necessarily good for the battery.
There is always a net input into the battery for a given drive IF the battery is kept at the target SoC (about 60%), i.e., if you start the drive and end the drive at 60% SoC, the net current to and from the battery is always < 0 where negative current/capacity = charging.
Failure to drive sufficient distance causes the SoC to drop below target, which means it's parked in an even lower state of charge - a great way to take a marginal battery over the edge.
Old Oct 29, 2017 | 09:27 AM
mitrals's Avatar
Techstream
mitrals's Avatar
These are my techstream numbers. I think the battery is ok!
Old Oct 29, 2017 | 10:45 AM
If the car is just sitting there, then those numbers have almost no diagnostic relevance as resting voltage is not indicative of health.
Old Oct 29, 2017 | 01:41 PM
mitrals's Avatar
How do I check if the battery is good?
Old Oct 29, 2017 | 02:08 PM
Display only block voltages, SoC, MIN/MAX voltages/blocks, and current. Start recording.
Place car in "N".
Turn on the:
A/C full blast with fresh air intake
rear window defroster
lights
Discharge to 20% SoC in "N".
Place car in "P", turn off A/C, defroster and lights, and allow car to charge battery.
Terminate recording and export to CSV.
AmigaOneFan
Oct 31, 2012 03:59 AM
ScuubyT
Sep 7, 2012 12:10 PM
CiHyManTran
Oct 4, 2011 02:29 PM
RoadrunnerII
Feb 6, 2009 08:16 PM
dangerkitty
Mar 24, 2006 07:16 PM
