MPG and tire pressure
Old Mar 4, 2007 | 03:55 PM
ByronJames2003's Avatar
Default MPG and tire pressure
Yikes....I thought the New England cold was to blame for my consistently low gas mileage since Dec. Perhaps it was partially to blame but in recently checking my tires (low pressure) and inflating them to 40PSI, my mileage immediately increased back to the mid-thirties from mid-twenties .
Others of you in cold climates may want to check your pressure and see if it affects your MPG. I am once again an overjoyed TCH owner. *chuckling*
Old Mar 4, 2007 | 04:18 PM
jbollt's Avatar
Default Re: MPG and tire pressure
Good point! In fact, I think I have read that tire pressures drop about a pound for every 10 degrees the air temp drops. So..If you filled them to 35psi when it was 90 degrees out, they would be 30 psi at 40 degrees. (Plus they always seem to loose a little over time as well)
Feel free to correct me if I have my numbers wrong, but that is what I seem to remember. Bottom line, your tires will always be inflated to a lower psi in winter if you don't actively check them and up the pressures monthly.
Edit: I guess I was right about the 1 psi per 10 degrees F...
see this....http://www.tirerack.com/tires/tirete....jsp?techid=73
Jeff
Old Mar 4, 2007 | 05:43 PM
Oh...I'll be checking my pressure every month --- religiously from now on.
B-
tekn0wledg
Jul 4, 2008 09:03 AM
Oiler
Jul 19, 2007 06:50 AM
sirfergy
Nov 29, 2006 11:11 AM
zimbop
Aug 13, 2005 02:31 PM
RoyalF
Apr 10, 2005 05:40 PM
