Motorola razr
Hi all...has anybody transferred the phone book from the razr(Verizon) to the car....if so can u post the procedure. I played around with the phone and the bluetooth...ccould not do it....thanz in advance
I posted something about sending contacts through vcards over bluetooth. I did it for my VX9800, so the procedure should be similar. Here ya go, hope it works!
1) Connect your phone to the car through Bluetooth
2) Go into the phone menu and click on phonebook
3) Click on transfer data
4) The display will say "transferring data" or something like that
5) Your phone will say "device is disconnected" or something along those lines
6) Go into your phone's contact list, highlight the contact you wish to transfer, then press Option then Send via vcard
7) Your phone will pull up a list of paired devices
8) Highlight the device corresponding to your car
9) Hit OK
10)You will see a message saying "VCard Sent"
11)Then another message saying "Bluetooth device is connected"
12)Repeat the above steps starting at step 3
13)Repeat until you have all the contacts you want in there.
BTW, I have a VX9800, just for reference sake, but all the Verizon interfaces on the phones should be the same? Good luck!
9) Hit OK
There is no tab on the razr called"transfer data"-atleast I could not find it. Also if i highlight a contact on my list the only options that I have r: call. send text message or send pix message, delete
I moved my wife's Razor entries to her SIMM and then temporarily moved the SIMM to my Sony Ericsson T-637 and transferred the WHOLE PHONEBOOK in one operation in about 30 seconds. Then moved the SIMM back. If you have more than a half dozen entries it becomes a pain in the rear with the Motorola's one at a time method.
The above method only works if your carrier uses phones with SIMM cards and have access to a phone that can transfer the entire phonebook at once.
J
J
J
mjcmjc
Toyota Highlander Hybrid
04-16-2007 12:58 PM
