Michelin Primacy Tire Upgrade
Old May 29, 2012 | 02:20 PM
GeorgiaHybrid's Avatar
Default Re: Michelin Primacy Tire Upgrade
Jimmy, gone 18 months and you are still here when I log back in. Like you I also put the Michelin Energy tires on the Camry and need to replace them soon although they have run over 63,000 miles. The car has around 103,000 now and as soon as I have time to put it on the rack, the water pump will be replaced and coolant changed for the engine as well as the hybrid cooling system.
Any new developments on a good tire to replace these with?
Old May 29, 2012 | 03:31 PM
rburt07's Avatar
Your saving lots of money by doing the water pump repair. I read somewhere that someone bought a new water pump from NAPA for like $85.
I use the tirerack site with their survey charts and customer reviews to locate the mxv4 primacy tires for my new '12 TCH. They do make the primacy that fits the '07 to '11 TCH. The V rated tires may be oem with the 9/32 tread. The heavier built H rated tires is a little lower priced and has a 11/32 tread. I use tirerack and discount tires to find the better tires.
MPLSMN
Feb 16, 2010 04:59 PM
tmparisi
Oct 9, 2009 12:26 PM
zimbop
May 14, 2008 07:00 PM
Mainer
Jan 4, 2008 09:45 AM
