Low tire indicator
Old Jan 14, 2015 | 07:10 PM
jasmd2's Avatar
Default Low tire indicator
I recently had the low tire indicator light come on and had the dealer reset it 3 weeks ago. Now the light has come back on. I am going to check the tire pressure I have it set at 38 pressure. I will air up the low tire back 38 pressure and hope when I drive the light will reset. I realize I may have a slow leak and will have that checked. Do i have to find and use the reset button in the car 2009 Camry Hybrid.
Old Jan 16, 2015 | 09:09 PM
GeorgiaHybrid's Avatar
Default Re: Low tire indicator
Unless you want to reset it, you can leave it alone. To reset, press and hold the button located on the left side of your glovebox.
Old Jan 17, 2015 | 12:02 PM
jasmd2's Avatar
Thank You
maloski
Aug 20, 2009 09:42 AM
noflash
Feb 6, 2008 05:01 AM
pb5927317
Jan 5, 2008 08:52 AM
