LOW mileage (27MPG)... any ideas?
Old Oct 8, 2006 | 02:22 PM
IanShakil's Avatar
Default LOW mileage (27MPG)... any ideas?
I accidentally left the fuel cap open a few weeks ago, which caused the check engine light to come on. I quickly fixed the situation, and indicator turned off. Ever since then, however, I have gotten very poor mileage – about 27 MPG on average. This is far *far* below the spec’d MPG. What can be done?
Old Oct 8, 2006 | 04:03 PM
belbe's Avatar
Default Re: LOW mileage (27MPG)... any ideas?
How full is your tank? You might try topping it off and thus resetting the the gauge. Take it out for a nice drive where you can wring good mileage out of it and see if it improves. If it still isn't happy then I'd get it in for servicing...
Old Oct 8, 2006 | 04:05 PM
IanShakil's Avatar
I've sinced topped it off a few times, and the problem persists....
Is 27MPG truly abnormal?
-Ian
Old Oct 8, 2006 | 04:12 PM
belbe's Avatar
How long have you had the car? How many miles? What kind of driving are you doing...flat, hills, city, freeway.
If you are relatively new to the Camry and are not driving it any differently then 27mpg is probably 'normal'. Give us a bit more info on your kind of driving and your driving habits.
Old Oct 9, 2006 | 06:36 AM
WVGasGuy
Guest
Posts: n/a
Also did you average better than 27 before this?
Old Oct 9, 2006 | 08:55 AM
Pete4's Avatar
If I was in your place, before going to the dealer I would disconnect 12 volt battery for few minuttes and see if that helps. Of course I'm assuming your mpg is much worse than it used to be.
Old Oct 9, 2006 | 11:20 AM
CGameProgrammer's Avatar
You say it's below the "spec'd mpg" as opposed to being below your previous mileage, so I assume you've never had a tank better than 30 mpg? I think the fuel incident is irrelevant. The car, like all cars, will get low mileage if you drive it hard, do many short trips, or run in very cold weather.
Old Oct 9, 2006 | 07:30 PM
hamm3r's Avatar
What are you using to determine that it is 27MPG?
Last week I noticed that the MPG on my consumption screen (NAV version) was "stuck"
at a particular MPG reading. I had to hit the reset button to fix it.
If that's where you are reading from, maybe yours is stuck, so try to reset it.
Or is your tank average stuck too?
dwichman
Jun 22, 2022 04:23 PM
tug3
Dec 31, 2013 07:11 PM
tug3
Mercury Mariner Hybrid
Dec 30, 2013 02:52 AM
panjiaming
Aug 13, 2012 07:24 PM
molex
Apr 19, 2006 09:03 PM
