The little back thing in the trunk?
Old Aug 21, 2008 | 06:43 AM
rmorrow's Avatar
Default Re: The little back thing in the trunk?
Originally Posted by Squint
That's exactly what happened to me.
I just tested this. I opened the trunk, put the fob in, and shut it. The car beeped at me and I was able to open the trunk.
I did not have the 2nd fob with me, all the doors were locked, and the windows were rolled up. I separated the mechanical key from the fob so that I would have an alternate method of unlocking the car but did not have to use it.
I believe its a different behaviour depending on whether you have already locked the doors:
1) With the doors already locked, it beeps and refuses to lock the trunk if you leave the fob inside. I presume this is to avoid grief when that's your one and only fob.
2) If the doors are not already locked, it simply refuses to open again with the handle. I've posted the full explanation of that instance above. This behaviour is desirable because it means that you can still leave a purse with a fob inside the trunk, as long as you still have a second fob with you.
psyshack
Saturn Vue Green Line
20
Aug 1, 2008 06:38 PM
leepark
Nov 28, 2007 07:33 AM
rkr
Aug 10, 2007 10:59 AM
rcomeau
Jul 30, 2007 09:47 PM
hahguy
Jun 14, 2006 06:30 PM
