Limits of B Gear
Old Apr 6, 2008 | 09:09 PM
wcrhsn's Avatar
Default Limits of B Gear
Have a new 2008 Camry Hybrid. I live in a hilly area. What is the maximum recommendedspeed at which one can travel downhill? Is there a limit beyond which damage may occur? For example, the "Grapevine" in Southern California on I5 is very steep, about 3000+ ft elevation change downhill for a few miles. If I keep the car in the B gear, will the acceleration of gravity cause the car to go too fast and break something?
Thanks,
Harold
Old Apr 6, 2008 | 09:45 PM
nash's Avatar
Default Re: Limits of B Gear
I have used B on 6% freeway grades at speeds up to 75mph, for 2 to 3 miles at freeway speeds with no problems. I find I need to give a little gas or B will slow me down too much on most freeway grades. I never felt the engine was over speeding due to the use of the B gear.
Old Apr 6, 2008 | 11:02 PM
wcrhsn's Avatar
Thanks for the reply. I was primarily concerned about excessive strain on the transmission when going 60-75 mph in B gear.
Harold
Old Apr 7, 2008 | 02:40 AM
haroldo's Avatar
Remember, the B gear wont illuminate your brake light, so if you have someone behind you, they may not be aware that you are slowing down.
Old Apr 7, 2008 | 07:16 AM
talmy's Avatar
B won't cause a strain on anything. Electronic controls will prevent overreving. All B does is enable engine braking. It can be selected at any speed.
Old Apr 7, 2008 | 09:37 PM
Dang's Avatar
Just to be clear, B isn't a "gear" at all in the Hybrid. There aren't any gears in the traditional sense. It's simply the computer altering how it manages the drivetrain to give you somewhat more slowing power. It won't let you hurt it.
Later!
Dang
Old Apr 8, 2008 | 12:59 AM
rburt07's Avatar
I go down a rather steep straight grade when going over the mountain west Las Cruces, NM. I use the B position and other times simply go easy on the brakes to slow occasionally.
I'm getting good at hitting the flashers for a few flashes to alert trucks or cars that i'm going slower than they are. Even in full sunlight those bright yellow rear flashers must be very visible from a long ways back.
Old Apr 8, 2008 | 08:23 AM
wcrhsn's Avatar
Later!
Dang
Thanks, Dang. So, the loud whining noise it makes is not the transmission slowing the engine? It sounds like a regular car in low gear.
Harold
Old Apr 8, 2008 | 08:47 AM
haroldo's Avatar
That loud whine always sounded like the engine saying "Ouch!"
Old Apr 8, 2008 | 09:49 AM
SPL's Avatar
SPL
The "whining" when coasting in 'B' is the ICE being spun (without fuel or spark) at higher speeds (between 1000-4000 rpm) by MG1 to give true engine braking. Coasting above ~40 miles per hour (~64 km/h) in 'D,' the ICE is spun by MG1 at idling speed (~1000 rpm) only, and so isn't readily audible. No harm will come to the engine or transmission by shifting into 'B' at speed.
Stan
Geckoboy
Jul 13, 2013 08:52 AM
Sky Blue
Aug 15, 2008 12:36 AM
Delta Flyer
Dec 11, 2005 10:24 PM
EricGo
Sep 3, 2005 04:44 PM
