Key not Detected Message
Old Sep 5, 2006 | 01:28 PM
Mainer's Avatar
Along for the ride.....
Default Key not Detected Message
Twice now, while driving along, with the key fob in my pants pocket, I gotten the message on the display that says "Key Not Detected." Then the car starts beeping and a warning light also appears on the display (a small red triangle). The car does keep running (thank heavens) and if I take the key out of my pants pocket and put it in my shirt pocket, the message disappears and all is well.
My jeans (as far as I know) aren't lined with signal dampening foil so I think they shouldn't be a barrier.
Anyone else had this happen?
Old Sep 5, 2006 | 01:30 PM
TKCamry's Avatar
2007 Toyota Camry Hybrid
Default Re: Key not Detected Message
Originally Posted by Mainer
Twice now, while driving along, with the key fob in my pants pocket, I gotten the message on the display that says "Key Not Detected. The car starts beeping and a warning light also appears on the display (a small red triangle). The car does keep running (thank heavens) and if I take the key out of my pants pocket and put it in my shirt pocket, the message disappears and all is well.
I haven't had that problem. But there is a warning about not having your cellphone in the same pocket/purse as the key fob. Something about interference could cause problems.
Old Sep 5, 2006 | 01:33 PM
cohort's Avatar
I don't have that issue as well. Maybe the battery in the key chain is low causing poor signal issues. Just a guess, I don't have anything to back that up.
Old Sep 5, 2006 | 01:39 PM
Droid13's Avatar
HSD Organic Interface
Maybe the environment? Were you in the same place each time? Near a source of strong RF interference?
Old Sep 5, 2006 | 03:13 PM
Mainer's Avatar
I was driving both times with the key in my right pants pocket. My bluetooth enabled cell phone was in the cup holder within a few inches of my pants pocket. Maybe it was that - I'll move the phone to the cubby ahead of the shifter.
Old Sep 5, 2006 | 04:11 PM
ByronJames2003's Avatar
Did you happen to open the car door for any reason.
I had something similar happen when I was stopped and opened the car door to spit out some mouthwash.
Byron
Old Sep 5, 2006 | 04:59 PM
spiff72's Avatar
This seems like a logical explanation.
daniellore
Nov 26, 2013 08:44 PM
FeelTheVolts
Mar 16, 2011 08:35 PM
bmgoodman
Jul 25, 2007 10:04 AM
cbrookhart
Mar 24, 2007 12:41 PM
DTDRIVER
Oct 17, 2006 05:48 PM
