Instrument lighting, or lack there of...
Old Jan 7, 2007 | 12:55 PM
Samuelrd1's Avatar
Question Instrument lighting, or lack there of...
I finally received My TCH after 13 weeks, from the KY plant. Red Metallic, Nav, Moon Roof, Fac. Leather, DVD Player.
I have been in it one month, 3,500 miles. No squeaks or rattles. About 38MPG average.
The remote mirror, door lock, and home link switches are not lit at night. I find this hard to believe. Is it a problem with my car, or is this the way it is?
Also, does anyone else find the ECO Mode switch oddly inconvenient? It also seems to turn itself off at times and I can't figure out why.
The only (minor) defect I seem to have is that the lights at the shifter that should show what gear I am in seem to illuminate all the positions EXCEPT the one I am using. I need to look at the dash to be sure I am in 'D'.
Otherwise, I could not have asked, or gotten more than I have with this vehicle!
Old Jan 7, 2007 | 03:30 PM
kris's Avatar
Default Re: Instrument lighting, or lack there of...
Change the light to a brigher white LED. That worked for me.
Old Jan 7, 2007 | 03:51 PM
Big-Foot's Avatar
Currency-to-hydrocarbons
Talk to us Kris... What part number LED? Where's it go? Thanks!
Old Jan 7, 2007 | 04:07 PM
TKCamry's Avatar
2007 Toyota Camry Hybrid
ECO mode turns off under a couple conditions I am aware of:
1. If you set the climate control system to all the way up or down on the temperature range.
2. If you turn on the front defroster setting.
Old Jan 7, 2007 | 05:19 PM
FL07THC's Avatar
Home link has no lights. Never been a problem for me.
Old Jan 7, 2007 | 07:09 PM
kris's Avatar
Sure,
#74 bulb in super white from autolumination
http://autolumination.com/74.htm
Once you remove the shifter trim, the green coated bulb is visible towards the bottom of the shifter (towards the rear of the car). Pull the old one out, push the new one in.
Old Jan 8, 2007 | 06:56 AM
Orcrone's Avatar
The Homelink switches have 1, 2 and 3 dots on them respectively, similar to braille. I find the corrrect one by touch fairly easily.
Old Jan 8, 2007 | 05:10 PM
jay_man2's Avatar
Beyond AM. Beyond FM.
Even with the dimmer as low as I can get it, the light from the NAV screen makes the homelink switches easily visible for me.
Old Jan 8, 2007 | 09:35 PM
thatchrisguy's Avatar
I too found it odd those switches were not illuminated. I wish they were lit up.
My 11 year old Ford Explorer lit those buttons up. Another thing I find slightly annoying is when you use the window lockout button to prevent the passengers from using their window switches...it also LOCKS out the driver from opening or closing the windows. What's up with that?
I too think the location of the ECO button is a bad one as well as the heated seats button...for some reason I'm always hitting one of the two seat warmer buttons when I reach for something in that storage compartment under the NAV/Climate Control.
Oh well....I like the car so far.
Old Jan 9, 2007 | 05:45 AM
Big-Foot's Avatar
Sure,
Thanks Kris!
