Importing a Camry
Old Jun 8, 2007 | 11:51 PM
beng's Avatar
Default Re: Importing a Camry
As the Camry is built in the USA, I thought that there was no 6% duty applied when bringing it across the border due to NAFTA.
Old Jun 10, 2007 | 01:39 PM
SPL's Avatar
SPL
beng — You may be right. When I checked in May 2006, all the TCHs were being imported from Japan. What I found out was that the duty rate on imported passenger cars from anywhere in the world (other than the USA?) was ~6%.
Stan
Old Jun 11, 2007 | 11:55 AM
Tideland Prius's Avatar
Originally Posted by ag4ever
I don't understand why you would need to cut a wire.
The DRL Off position is just the all off position for the lights.
Leave the switch in the auto mode, and you have DRL and regular lights in low light level situations.
Maybee just scrape the DRL from the stalk so it only reads OFF.
SPL explained it well after your post. We can't have a DRL OFF switch in Canada.
Old Jun 11, 2007 | 11:56 AM
Stan
Yeah there isn't so the difference is greater (instead of the $1-2k, it's now $5-6k). Hell, I even added nav and there's still a great difference cause their nav is $1,300 and our nav is nearly $3k.
Old Jul 11, 2007 | 08:27 PM
voodoo's Avatar
Originally Posted by Tideland Prius
Having that DRL OFF switch makes it easier to import a TCH with regards to DRL. Since the DRL is already there, we just need to "cut" the wire that sends the signal for the DRL OFF position. IOW, change the DRL OFF position so that it functions as "OFF" in the Canadian market. That'll save you time and money by not having to switch stalks.
shouldn't be a problem with the speedo since there are km/h readouts... just a bit smaller than usual heh.
Hello Timberline Prius, Have just imported the 50th anniversary edition of the Camry Hybrid and am wondering about the daylight running lights and the Fed requirement to have them no-defeatable. You mention just cutting some wire? Can you be more specific? I mentioned this to the US dealer and he checked with the Toyota technical people, the conclusion being because I have the NAV system adjusting the DRL's will cause a problem with the NAV.
Need some help here please. Regards Voodoo
Old Jul 12, 2007 | 01:03 AM
hey,
I don't actually have an imported TCH (yet). I would've guess it was simply cutting the switch that defeats the DRLs when it's in the "DRL OFF" position.
Hmm... not sure how it'll cause problems as it's going to function like an "OFF" switch. So if the nav doesn't switch from day/night mode automatically, that's what I expect. Unless there's something more to it.
Old Jul 12, 2007 | 02:42 PM
  #27
beng's Avatar
Tideland Prius, did you find out what it would take to get your MFD to display km vs mpg? Also, did you look into getting the speedo changed to display KM/H as the primary numbers?
Old Jul 12, 2007 | 03:05 PM
  #28
Hey beng,
no I haven't. I figured it's not too big of a deal (just have to realise that in the Prius, the shorter the bar graph, the better and on the future TCH, the higher the bar, the better lol).
It would be nice though to have km or km/h as the main unit of measurement.
Old Jul 16, 2007 | 10:13 PM
  #29
beng's Avatar
Hey Guys,
Well in the end, I decided to buy my TCH in Canada. The main reason was because I was able to get 2K more for my trade in from another dealer. Also, the posibility of having to live with MPG instead of KMh without spending $$$ to change it was too much. Anyways, I wish you guys good luck with your imports
Old Jul 19, 2007 | 11:25 PM
  #30
oh alright.
If I see a white TCH, I'll wave! (and they aren't many around.. I've only seen one and that was before you bought yours). If you see a Tideland Prius, wave back!
Curated Content Editor
Sep 1, 2013 06:22 AM
bugs
May 18, 2008 10:06 PM
Tideland Prius
Sep 29, 2007 10:44 PM
Jason
Hybrid & Related News
13
Feb 12, 2006 09:43 AM
