HV battery bus bars
Old Aug 15, 2021 | 07:24 AM
cstaude's Avatar
Default HV battery bus bars
I have cleaned the very corroded bus bars on my HV battery and am ready for reassembly. I assume some type of dielectric grease would be good to minimize future corrosion.
Does anyone have an opinion or recommendation for a dielectric grease?
Old Aug 15, 2021 | 02:59 PM
Default Re: HV battery bus bars
Yes. Install without. Not worth the mess. Critical that you tighten the nuts to 48 in-lb.
I suspect that you noticed your bus bars were the least corroded in the area that contacted the module terminal's flat end face. There was likely some intrusion of corrosion around the perimeter of the contact face, but the majority of the facing material had little or no corrosion.
This is the only area that matters. The rest of the surfaces have negligible influence on the conductivity of the bus bar.
Old Aug 15, 2021 | 03:27 PM
cstaude's Avatar
Thank you for the prompt feedback. I like your thinking, no grease , no mess.
Yes, the main cable/ECU connections were like new but most of the bars and nuts had a nice mix of blue and white corrosion. What you might expect from a 2007 that has never been touched.
magav
24
Nov 22, 2019 08:51 AM
jdp72
Mercury Mariner Hybrid
Jul 18, 2009 01:58 AM
highflyer_i469
Aug 11, 2007 02:06 PM
TeeSter
Oct 11, 2006 08:43 PM
AlanWBaker
Aug 30, 2005 07:04 AM
