How long is the original alignment under warranty?
Old Oct 1, 2006 | 06:52 PM
cohort's Avatar
Default How long is the original alignment under warranty?
Mine seems to pull to the right @ 3,000 miles
Old Oct 1, 2006 | 06:58 PM
skywagon's Avatar
Default Re: How long is the original alignment under warranty?
A little trick that works great is let 5# of air out of the left tire.
Old Oct 2, 2006 | 04:01 AM
schmidtj's Avatar
Keeping Toyota Solvent
If it's the problem described by the attached TSB it's 12 mos or 20K miles.
Edit: corrected mileage
File Type: pdf
Old Oct 2, 2006 | 04:41 AM
Orcrone's Avatar
Originally Posted by schmidtj
If it's the problem described by the attached TSB it's 12 mos or 12K miles.
Schmidtj. Where do you find these TSBs?
Old Oct 2, 2006 | 04:46 AM
schmidtj's Avatar
Mostly here:
www.tundrasolutions.com
it requires a modest paid subscription to download the knowledgebase items.
Old Oct 2, 2006 | 05:00 AM
Orcrone's Avatar
Thanks for the info. I'll have to look into it. I like being able to go into the dealership with the TSB in hand (I already printed out the one for the squeaky brakes). I find that if you don't tell them about it, they know nothing.
Old Oct 2, 2006 | 05:16 AM
wcmack's Avatar
Just to clarify, the TSB attached by schmidtj states on p.1 that the warranty for this repair is 12 months or 20,000 miles.
bedrock8x
Mar 3, 2009 05:39 PM
joystix2
Jun 17, 2008 07:16 PM
robbking68
May 8, 2007 04:07 PM
heavenleigh
Jan 21, 2007 05:30 PM
fuji
Introductions
Nov 5, 2006 05:22 PM
