How Long Have Your Brakes Lasted?
Old Sep 26, 2012 | 11:46 AM
  #41
LEAKYTCH's Avatar
Default Re: How Long Have Your Brakes Lasted?
Just took my 07 TCH in for an oil service, and asked the tech to also look at my brakes because I have a little squeal at low speeds.
Service Manager called me and was first asked if they had done all the service on it, because it appears that the brakes are new. I told them no, they do all the service. He seemed amazed that the brakes are like new since the vehicle has over 80,000 miles. Said I have at least 80% wear left on front and rear.
He said he could replace the front pads to correct the squeal but I will try putting it in neutral and braking to wear the glaze off.
Old Sep 26, 2012 | 02:43 PM
  #42
litespeed's Avatar
Professor Emeritus
The squeal is actually a high frequency vibration that comes from the backing being worn off the back of the pads. IE: you have metal to metal contact between the "back" of the pad surface and the caliper piston.
You can remove the pads and use a paste to coat the backs of the pads to stop the "squeal". ATE makes some stuff called Plasti-Lube that comes in a tube. Also, Permatex makes some stuff you can spray on the backs of the pads. I have used both and both work good. The stuff from ATE seems to last a little longer.
At 134,000 miles mine still look about like new too! Maybe 70 or 80% left.
Old Sep 26, 2012 | 05:31 PM
  #43
Ron AKA's Avatar
I have used the Permatex liquid which comes in a tube. It provided temporary relief from the squeal of some new pads I put on another non hybrid car. The pads finally wore in and stopped squealing.
I've never had pads start to squeal that are very old. I think you may be right in that there is a glazing problem. You may be able to get rid of it with some hard stops and the transmission in neutral to disable the regeneration braking. Or you could remove the pads and lap them on a sheet of glass with sandpaper on the glass. If you go to that much trouble I would use the Permatex on the back of the pads as well.
Old Apr 23, 2013 | 08:46 AM
  #44
ceguy's Avatar
Talking Re: How Long Have Your Brakes Lasted?
07 camry purchased 6/06. 83k. front pads 9mm, rear pads 8mm.
I find this amazing.
Old Jul 9, 2013 | 04:29 PM
  #45
Geckoboy's Avatar
I'm at 145k miles on my 07 TCH (bought in 2006). On my last oil change a few days ago, the service rep told I had 1mm left on my rear brake pad. However, the tech reported this:
25 Customer Pay Done PERFORM MULTI-POINT INSPECTION (FREE) FRONT BRAKES _8.0MM_ REAR BRAKES_4.0MM_____ TIRE PSI__32PSI___
I question this and apparently the tech was referring to the inner pad not the outer pad. How he was able to check that without taking the tire off, I want to know.
Anyway, when I got home, I took the rear drivers side tire off and lo-and-behold, I did have about 1-1.5 mm left on the inner pad. The outer pad looked to be about 3-4mm. I checked the other side (rear passenger) and the inner pad looked about 1.5-2mm and outer pad was 3-4 as well.
So I went ahead and replaced both rear brake pads.
Is uneven wear on the pads between the inner and outer typical? With the tire on, I can see the outer pad but inspecting the inner pad involves the removal of the tire and a small head (or a mirror)..
Old Jul 9, 2013 | 09:38 PM
  #46
GeorgiaHybrid's Avatar
Uneven wear on the inner and outer pads indicates poor or no lubrication on the sliding surfaces and pins. That is one of the reasons I pull mine every 40,000 miles or so to lube and inspect.
Old Jul 10, 2013 | 03:39 PM
  #47
litespeed's Avatar
Professor Emeritus
I just rotated my tires again the other day at 153,000 and all the pads look the same as they did at 134,000. There is "at least" 70 to 80 percent left on all of them. I agree with GH though. Next time I rotate, I plan to pull the calipers, inspect everything, take pictures, lube slide pins, repaint the rotor hats and plasti-lube the backs of the pads.
I have to agree with others who have said that the brakes could out last the rest of the car. Or at least as long as I own it. I am planning to take it to at least 250,000 before I get rid of it. Hopefully the traction battery will hold out. I have already been looking for places to rebuild the battery in case it decides to crap out on me. No issues.... I just want to be ready.
If anyone knows of places that overhaul the traction battery in the South East, please post. I have found one up in NC that may be good. Still researching.
Old Jul 13, 2013 | 08:40 AM
  #48
Ron AKA's Avatar
Uneven wear of the inside pad compared to the outside indicates the pads are not sliding evenly on the guides. Because they are used so little they can seize up. I recall this may have even been a recall issue with the early Camry hybrids? Toyota would know.
Agree with Georgia Hybrid, because the wear so little they tend to get neglected. Periodic cleaning and lubrication is what is needed to keep them working to a very long life.
Old Aug 9, 2013 | 07:01 AM
  #49
litespeed's Avatar
Professor Emeritus
So, I pulled the rear tires yesterday to deal with a nail in one of them. While I was at it, I pulled the slide pins and pads and greased everything up. The pads are wearing even all the way around and are still at least 70 - 80% @ 156,000 miles. I also found the lower slide pin on the drivers side was stuck. But, the pads were wearing even. It must have just happened. The whole job took about 10 minutes on each side to clean and grease everything.
I plan to do the front in a couple days. Hopefully noting is stuck!
Edit: Here is the front too. Now @ 157,200 miles. All the slide pins on the front were stuck or VERY stiff. The grease had dried up.
File Type: jpg
Old Aug 18, 2013 | 04:24 PM
  #50
UWAdventurer's Avatar
My pads have lasted 120,000 miles so far.
