How does it average?
Old Nov 9, 2006 | 01:31 PM
FL07THC's Avatar
Default How does it average?
If you are in EV mode you are really getting unlimited miles per gallon, so what number does it use to average? Is it 99.9?
Old Nov 9, 2006 | 02:10 PM
gaijin42's Avatar
Default Re: How does it average?
The computer isnt taking multiple fuel efficincy readings and then averaging them together.
The computer is measuring the total distance, and measuring the total gas used. So the distance goes up, but the fuel stays the same.
The number maxes out at 99 mpg, so even though you might be over that number for a while you will still show 99. However, eventually your average will pull down, and the "extra" milage you had when you were in EV is not lost, its averaged in, because again, its not instantanious measurements, its one big measurement
Old Nov 9, 2006 | 02:33 PM
jdenenberg's Avatar
Engineering Professor
It doesn't compute an average using the current MPG. The computer keeps track of miles (km) driven and gallons (liters) of fuel used and then divides to get the MPG since reset. 99.9 is just the highest MPG the display is programmed to handle.
JeffD
Old Nov 9, 2006 | 02:46 PM
FL07THC's Avatar
JeffD
Yep that makes sense! Thanks
Old Nov 10, 2006 | 06:35 AM
ag4ever's Avatar
Dazed and Confused
I assume that the trip computer (miles to empty) uses some sort of weighted average where the most recent mileage is given more weight that that at the begining of the tank. If that is the case, then the computer must do some additional calculations to keep track of recent mileage, maybe not instantanous mileage, but very recent.
Old Nov 10, 2006 | 08:05 AM
Orcrone's Avatar
I see no reason to make that assumption. For weighted averages you have to worry about things like the weighting and divide by zero for periods of EV mode. If it just keeps track of total distance, total fuel then the calculations are greatly simplified.
It's all moot anyhow as it would be relatively easy to program either way. I think what's available at the sensor outputs is more of a consideration anyhow.
TOHHybrid
Aug 1, 2006 03:25 PM
lars-ss
Jun 8, 2006 07:41 AM
CLA
Honda Insight
May 23, 2004 06:04 PM
Jason
Apr 4, 2004 06:07 PM
