View Poll Results: How do you calculate your MPg? If by hand is it higher or loewer than the trip comp?
Hand Calculation
24
70.59%
Display
11.76%
Mix of hand and display
23.53%
5 below display
0%
4 below display
0%
3 below display
5.88%
2 below display
17.65%
1 below display
17.65%
Same as display
8.82%
1 higher than display
2.94%
2 higher than display
5.88%
3 higher than display
0%
4 higher than display
2.94%
Multiple Choice Poll. Voters: 34. You may not vote on this poll
How do you figure your MPG?
Old Mar 25, 2008 | 08:36 AM
coolshock1's Avatar
Driving in stealth mode
Default Re: How do you figure your MPG?
Did you only choose that you calculate by hand? If so what would the difference be that you WOULD have chosen?
Old Mar 25, 2008 | 08:42 AM
mikieboyblue's Avatar
I chose both and should have put my -1 as the MFD/NAV average is usually one higher. No big deal....
Old Mar 25, 2008 | 09:36 AM
coolshock1's Avatar
I will continue to update my original post with updated Database analysis info.
Old Mar 25, 2008 | 09:48 AM
haroldo's Avatar
300 Vehicles Checked
Hand = 32.67%
Display= 54.33%
Mixed = 13.00%
AVG MPG w/.3636 per vehicle avg subtracted from display entry method = 38.56 MPG for the TCH
... Hand Calculation of MPG = 33.93%, Display Calculation = 51.79%, Mixed Calculation Method = 12.50%...
... I am 99 vehicles so far. H=30.3%, D=58.59%, M=11.11%.
Looks like if you keep doint this you are going to find that Hand is ~32%+/- 1%, Display will be ~52% +/- 1% and Mixed will be ~12%+/1 1%.
But at least that's what the pattern looks like to me.
Old Mar 25, 2008 | 09:51 AM
coolshock1's Avatar
Now what's your guess as to where the AVG MPG for the Camry will be?
Old Mar 25, 2008 | 10:29 AM
haroldo's Avatar
I'll put my money on 36 MPG +/- 1 MPG
Old Mar 25, 2008 | 11:40 AM
coolshock1's Avatar
For those that didn't check the first page for the updates. I went through all of the Camry data and the results are below.
This is a 2 part Poll. First I would like to know How you calculate your MPG. Second, if you record it by hand what is the difference between your manual calculation and the trip computers calculation.
14 Votes in for a difference between hand calc and display with an AVG difference of .4286 (Mikie's vote added in by hand)
Database Analysis Info
529 Vehicles Checked (Completed)
Hand = 34.22%
Display= 50.47%
Mixed = 15.31%
AVG MPG w/.4286 per vehicle avg subtracted from display entry method = 36.21 MPG for the TCH
The database is reporting 36.5mpg.
While 50.47% of the data reported was calculated via the vehicle itself it really didn't skew the numbers that much (.29% approximately)
acowart
Aug 14, 2010 07:52 AM
ppgroup
Oct 2, 2009 11:31 AM
Tideland Prius
Sep 13, 2007 03:22 PM
AJR
Jun 16, 2007 07:59 AM
