How do I change 2007 camry hybrid engine air filter
Old Apr 3, 2008 | 05:07 PM
keithet's Avatar
Default How do I change 2007 camry hybrid engine air filter
I have looked and can not find by searching the forums how to change the engine air filter on my 2007 Camry Hybrid. Any help would be greatly appreciated.
Keith
Old Apr 3, 2008 | 05:30 PM
mikieboyblue's Avatar
Default Re: How do I change 2007 camry hybrid engine air filter
Hi Keith,
There is a link in the FAQ sticky at the top of the forum. If you have not had a chance to read through it, I suggest you do. It contains most of the really really frequently asked questions. It could use some presentation work but we do the best we can....
https://www.greenhybrid.com/discuss/159255-post13.html
Thanks,
Mike
Old Apr 3, 2008 | 05:44 PM
07CamHybrid's Avatar
Camry Freak
1. Driver's side of the engine close to the firewall. (black plastic cover)
2. You'll need a socket wrench- use it to loosen the 2 bolts, and one side will flip up slightly.
3. Pull the filter out. Inspect and replace if necessary.
4. Tighten the two bolts, making sure that the clips on the other side are properly in place.
(Mine didn't come out of their socket on my hybrid, but they would always come out of
their socket when I inspected my filter on my '98.
Old Apr 3, 2008 | 07:12 PM
nash's Avatar
Check out this thread for pictures on changing the air filter
Old Apr 3, 2008 | 08:07 PM
You're famous Nash...that's the thread linked to in the FAQ
BTW, I never got the clip by the MAF sensor off, it ended up snapping off. No big loss though. It isn't like that cable is going anywhere and it is one less thing to take off.
Old Feb 20, 2010 | 12:18 PM
jpezz's Avatar
2009TCH w/NAV bought 4/08
Worked great on my 2009 TCH. The bolts are 10mm.
Chriszep
Aug 15, 2012 07:34 AM
dgyimao
Dec 31, 2009 09:38 AM
sanosteam
Dec 26, 2009 07:17 AM
bugs
May 26, 2009 12:05 AM
