Help: Tank mpg not reset
Old Jul 5, 2010 | 04:26 PM
Smilin' Jack's Avatar
Default Help: Tank mpg not reset
Help please.
Yesterday, I wanted to start a new tank record, even though I needed little gas. (I had resumed using the plug-in unit following a brief period without it, and I wanted to begin a new tank record for evaluation of fuel consumption with the plug-in unit.)
I filled the tank adding about 2.5 gallons.
I expected the tank mpg display on the MFD to reset, as it always had seemed to on previous fill-ups.
But it did not.
Anybody know why it might not have reset or how I could force a reset ?
Old Jul 6, 2010 | 05:30 AM
haroldo's Avatar
Default Re: Help: Tank mpg not reset
Guessing it only resets when you add more than just a few gallons.
Old Jul 6, 2010 | 03:58 PM
I could guess that as well, but does anyone out there know what the limit is or know how to force the reset?
Old Jul 6, 2010 | 06:01 PM
GeorgiaHybrid's Avatar
Jack,
Someone with the factory scan tool can reset the mileage or a Snap-on Solus Pro, Modis or Verus can do this if you go into the body control module. The problem is most of the people that have them will charge you quite a bit to clear it.
Old Jul 6, 2010 | 06:28 PM
If I knew how much gas fill-up is required to make the reset happen, and it were not too great a quantity, I suppose I could siphon it out and then back in.
AndrewXY
Dec 13, 2023 03:25 PM
Regztfen
Aug 18, 2008 02:16 AM
DrUsual
Jun 11, 2008 11:21 AM
Iguana
Feb 12, 2007 12:30 PM
jsal
Apr 25, 2006 06:54 PM
