Heat and the winter
Old Nov 25, 2006 | 08:25 AM
FL07THC's Avatar
Default Re: Heat and the winter
Yea I have not noticed this. My heat does not come on untill the ICE temp is up.
Old Nov 27, 2006 | 06:39 AM
klynch's Avatar
Originally Posted by Big-Foot
Actually the AC compressor does not put a strain on the engine directly as it does in most cars. There's no direct connection (belt) for the AC Compressor on a TCH. It is driven (always) via it's own electric motor. Hence the reason a TCH can run it's AC while in EV mode.
Randy,
Thanks for the info; it makes sense to me. I am confused, however, by the number of posts I think I read earlier in the year about people stating they try to improve FE by limiting A/C use. Are they (like me) misled? If so, maybe there is a case to be made for running in AUTO mode. One reason I don't do it now because I don't like the A/C coming on when I'm running the heater or when I want vent air.
Old Nov 27, 2006 | 06:49 AM
LouBeck's Avatar
Randy,
MPG appears to be 2mpg better in the fall with windows closed and HVAC off. No theory other then with a conventional car is the same. In theory this should not be true, if AC only ran off the battery, it must not be how it runs when using the gas engine.
Josh
Old Nov 27, 2006 | 06:51 AM
Big-Foot's Avatar
Currency-to-hydrocarbons
Originally Posted by klynch
Randy,
Old saying here - There ain't no such thing as a free lunch.
Relative to the current discussion - The voltage / current being consumed by the AC Compressor's electric motor must be replenished via the Motor Generator system. This will cause an additional (albeit slight) load on the ICE..
Given the extremely high efficiency of the AC compressor and system in general, I don't think you'll notice much (if any) difference in fuel economy.
Another good reason to run the AC compressor periodically is because the lubricant for the compressor is mixed in with the Freon (or in our cars R-134). If left to sit for long periods of time, the oil will settle out and take longer to circulate once you turn the AC on - this will cause more wear in the system and less overall efficiency.
Old Nov 27, 2006 | 06:54 AM
Big-Foot's Avatar
Originally Posted by LouBeck
Randy,
Josh
Josh - your AC compressor is right in front of the engine (between the radiator and the engine) - Unless I have a one-of-a-kind TCH, there is no belt to the compressor - only an electric motor.
2mpg is substantial - even more than I observed in our Honda Civic when I tested FE AC on vs AC off. I was able to get only 1mpg better FE on a 500 mile trip with running FAN only (no AC compressor - wire disconnected)..
Old Nov 27, 2006 | 07:11 AM
nash's Avatar
No, turning off the A/C will improve the FE (I notice about a 2 to 3 mpg improvement.) Think about it. The A/C uses electric power. The power has to come from someplace. The only sources of electric power on the TCH are the ICE, regen during costing/braking and the hybrid battery. The ICE will use more gas to make up the power used by the A/C. It just might not be noticable immediately if you have a high SOC on the hybrid battery.
CT Yankee
10
Aug 11, 2009 01:13 PM
eco.conduite.free.fr
Nov 21, 2008 04:53 AM
pianored1
Nov 4, 2006 02:38 AM
gumby74
Aug 26, 2005 03:22 PM
