H11 to H9 Headlights
Old Oct 13, 2008 | 08:30 AM
blktoy's Avatar
Default H11 to H9 Headlights
Just changed to the H9 bulbs and what a difference, like night and day.Much better than the PIIA bulbs. Only problem is that within two days one of the high beams burnt out. I know it should not be related but was wondering if anyone else has had the same problem or similar by going from the 55 watt to 65 watt bulb.
Old Oct 13, 2008 | 09:47 AM
mikieboyblue's Avatar
Default Re: H11 to H9 Headlights
Haven't tried. Maybe it is getting too hot?
Old Oct 13, 2008 | 10:56 AM
blktoy's Avatar
That’s what I thought but I can't see why the low beam should be burning out the 9005 high beams. Maybe it’s just hazard that it happened right after putting in the H9 low beams. I'll put new 9005s in and see what happens. I pulled the H9 to see if showed signs of overheating and they were spotless with no heat on light housing or wires. It would be a shame to pull them because of the incredible difference they make and I have tried a few the Xenon bulbs out there and there is no comparison.
Old Oct 13, 2008 | 11:35 AM
Yeah. It wouldn't make sense for the low beam to over heat and cause the high beam to burn out.
I don't think they share the same circuit so the increased wattage is probably not the problem.
Probably just dumb luck.
So you like the H9 bulbs at 65w as opposed to the HIDs? I installed 35w HIDs and am now clambering for 55w HIDs. lol ... I need help.
Old Oct 13, 2008 | 12:14 PM
blktoy's Avatar
I just wanted a easy fix for the poor lighting on the camry, without the ballasts and wiring. Car is a lease so I'm not going to go in any mods I will have to remove later.
Old Oct 13, 2008 | 12:15 PM
I hear you.
Old Oct 19, 2008 | 05:46 PM
talljetman2's Avatar
So did you figure out why your highbeams went out? I want to change out the lights on my TCH, not to HID or anything, but just something better (plus to a bulb that I can actually find!).. Looking for something that won't fry the wiring or anything. Is this about what you were looking for?
Old Oct 19, 2008 | 07:56 PM
blktoy's Avatar
No reason just odd timing I guess. The H9 are twice as bright as the h11 almost as bright as the HID but not as blue white. An easy fix for the poor low beams on the Camry.
Old Oct 19, 2008 | 11:07 PM
Any particular websites that you went to for the bulbs? Are they street legal as well? I don't seem to have too much luck in my current search.. Well I found H9 foglights and H9 low beams.. but any specific links would be good.
Old Oct 20, 2008 | 10:28 AM
blktoy's Avatar
Just picked them up at local auto parts store, had them in stock $11 a piece.
sadeen
Oct 9, 2009 08:02 PM
UWAdventurer
Jul 17, 2009 08:16 AM
ptung07
Dec 8, 2008 10:56 AM
Intrus
Aug 3, 2008 08:24 AM
errlin
Jan 30, 2006 10:50 AM
