grabbing brakes
Old Sep 16, 2006 | 10:31 AM
alc13's Avatar
Default grabbing brakes
I notice that when I am braking gently, the brakes suddenly grab just before the car stops and it stops with a jolt. I think this is more noticeable becaause I attempt to brake slowly, but it's becoming annoying. Does anyone else experience this?
Old Sep 16, 2006 | 10:36 AM
Rcommander's Avatar
Advanced Technology-PZEV
Default Re: grabbing brakes
Happens to me all the time, i would love to get it fixed, if indeed there is a fix for it.
Old Sep 16, 2006 | 02:36 PM
Freeze's Avatar
The only time I've experienced grabby brakes is when I'm in reverse. Weird.
Old Sep 16, 2006 | 04:11 PM
David Price's Avatar
Happy 07 TCH Owner
This could be caused by any or all the following;MG2, MG1, and the PSD. I don't think it's your brakes.
Old Sep 16, 2006 | 04:36 PM
Freeze's Avatar
Yes, I agree.
Old Sep 16, 2006 | 08:39 PM
flopshot's Avatar
Old Sep 16, 2006 | 08:57 PM
nash's Avatar
You may not be using your brakes enough. The TCH really does a great job of using regen to slow the car. Try doing a few stops from 30 or 40mph with the car in neutral. Regen is disabled in neutral, and the brakes alone will slow the TCH. Further stops in drive should be smooth now.
That should dry out your brakes and remove any surface rust/moisture that can cause grabby brakes. Unless you brake hard, the regen does almost all the "braking" until the TCH slows under ~7mph, at that point the disk brakes take over to finish stopping the car. My opinion is surface rust and/or moisture causes the brakes to grab slightly the first few stops as the TCH slows under 7mph.
Old Sep 17, 2006 | 10:03 AM
alc13's Avatar
Thanks flopshot -- the link had some really good information.
Old Sep 18, 2006 | 06:41 AM
Droid13's Avatar
HSD Organic Interface
Also, just be mindful of when the brakes might have gotten damp (car sat in rain, etc.). Sometimes they are grabby until they they've been used a couple of times that day. In a normal car that happens right away usually at higher speeds where it's a lot harder to feel the extra friction (grabbiness?) so by the time the car slows down everything is back to normal. However with TCH regen braking it might not happen until the normal brake pads get applied at the last minute when the car has already slowed and you feel the grab at lot more. I've notice this once in a while on the odd morning and goes away after the first one or two "grabby" stops. I guess it's a price to pay for what should be super-long brake life.
wwest
Jan 13, 2007 07:51 PM
ohiocityprius
Jan 11, 2007 04:30 AM
solar dad
Jul 26, 2005 03:11 PM
zadscmc
Jun 14, 2005 07:22 PM
ericbecky
Honda Insight
May 10, 2004 08:00 PM
