Gas type, Emission, EV mode.
Old Aug 9, 2006 | 05:50 PM
Ian's Avatar
Ian
Default Gas type, Emission, EV mode.
Does the type of gas i put in affect the time to have the gas engine running in order to meet the emission standard?
Maybe I have a totally wrong concept: The lower the gas, the "dirtier" the gas will be, therefore the gas engine has to run longer in order to meet the low emission standard. Thus, the EV mode will not kick in as early as I am using higher type (89) gas?
I used to use type, i just changed to 87 and I realize that the EV mode kicks in at the later stage. I am confident that my driving habbit is the same though.
What do you think?
Old Aug 9, 2006 | 06:20 PM
Orcrone's Avatar
Default Re: Gas type, Emission, EV mode.
Doubt it very much. 87 octane is no 'dirtier' (whatever that means) than higher octane. The higher the octane the more resistant a fuel is to detonation. High compression engines can cause the fuel to detonate before the spark. Using higher octane in these engines allows the fuel to not detonate until the spark causes it. Using high octane fuel in an engine that does not require it does nothing except make you spend more on gas. So save the money.
If you're finding a difference in when EV mode kicks in I'm guessing it's for some other reason.
Old Aug 9, 2006 | 08:33 PM
Droid13's Avatar
HSD Organic Interface
And just to add to that... The reason high compression engines develop more power with high octane fuel, is that the computer will adjust fuel/air mix causing lower power if it detects detonation from low octane fuel (ie 87).
The TCH technically has a high compression engine if you look at the specs, but the Atkinson cycle design nullifies this in actual use by reducing how much fuel/air mix actually is in the cylinder when the spark plug fires reaping all kinds of benefits like low pollution and high mileage.
agunther
Jan 31, 2011 08:38 PM
Ozbear
May 14, 2008 08:12 AM
VampHuntD
Oct 25, 2005 10:33 AM
aha
Oct 10, 2005 09:10 PM
myraellen
Oct 12, 2004 09:15 AM
