Gas Line Antifreeze
Joe,
E10 is 10 % Ethanol so you have about a gallon of it in each tank. Gas line antifreeze is either Methanol (wood alcohol - bad) or Isopropyl alcohol (made chemically but better) so do you really think that a few ounces of another kind of alcohol will make a difference? Save your money.
JeffD
JeffD
Unless you suspect your gas station has water in their tanks and does not check it, or you live north of the arctic circle, gas line antifreeze is generally a waste. The alcohol simply keeps any water in the system from freezing.
GreenBoy
02-07-2011 01:41 AM
