Fresh Air
Fresh Air
Is 65 the lowest temperature that can be set without using air conditioning? Also, in my older Camry, I could just move a switch to allow fresh air to come in. On the hybrid, there is just the button that allows for air recycling. Is there a way to allow fresh air in? Also, is there a way to allow fresh air in without having to use the fan?
Thanks,
RedCamry
Thanks,
RedCamry
Re: Fresh Air
Turn off the climate system and open a window or the sun roof if you have one.
Re: Fresh Air
I can relate to this one. Sorry, I haven't discovered a solution either.
Usually I like the temp cooler than hotter. 65 just isn't cool enough for those cool spring or fall days. So I usually leave the system off.
I also found that with the system off, and after the car warms up, I feel some hot air "bleeding" though the vents. Ick!
The other nice thing about having the system off is noise! We have quiet cars - it's nice to enjoy the silence when you are stopped.
Re: Fresh Air
Open all windows, slide moon roof all the way back, and hold open all doors at max spped for max fresh air!
-- Alan
Guss
13
01-24-2010 02:22 PM
GrendelKhan
10-29-2007 02:44 PM
