First oil change
Old Oct 25, 2008 | 10:54 AM
Van de Bogart's Avatar
Default First oil change
I know this has been discussed before but today I read an article stating the opinion that you should do the first change at around 1000 miles. Theory is that there are contaminates from the manufacture of the engine that accumulate during this time that can harm the engine, hence the early change. I would be interested in other opinions and/or facts regarding the first change.
Old Oct 25, 2008 | 10:59 AM
GeorgiaHybrid's Avatar
Default Re: First oil change
I changed mine at the 2,500 and 5,000 mark. Since then, I just follow the 5,000 factory OCI.
Old Oct 25, 2008 | 11:08 AM
ekpolk's Avatar
The Regenerator
This is less of a critical issue than it used to be, at least with makes like Toyota, and especially with aluminum engines. The machining and manufacturing processes are so much cleaner and done with much more care than they used to be, that the engines typically come out much, much cleaner, and generating much less break-in wear than engines of days gone by. Some engines still generate a lot of junk when new, but many more modern engines read almost as clean as a well worn-in engine.
Check our our UOA database at BITOG and look for factory fill results. Just in the last couple days, a guy posted a UOA on a new BMW X5, and it's very clean except for slightly elevated aluminum.
Also keep in mind that the filter will take out the vast majority of break in particles in a damaging size range. The stuff that shows up in a UOA is way, waaaaaaay to small to have a serious added impact on abrasive wear (though it may be a result of abrasive wear).
Devonaut
Aug 3, 2006 01:29 AM
cb450sc
Jan 5, 2006 11:29 PM
merlin180
49
Dec 14, 2005 09:51 PM
kmh3
Sep 27, 2005 05:33 PM
Jason
Jun 10, 2004 01:57 AM
