Engine Brake
Old Jul 7, 2011 | 10:55 AM
dcw888's Avatar
Default Engine Brake
Hi,
I have a question for all Camry Hybrid users. When I am in EV mode, does shifting my transmission to B start the engine?
Thanks!
Old Jul 7, 2011 | 02:26 PM
skywagon's Avatar
Default Re: Engine Brake
Naw, just put her in F !
Old Jul 7, 2011 | 03:31 PM
SteveHansen's Avatar
Pragmatist
No. In "B", the engine turns, but it is being powered by the wheels.
The "B" mode is for "engine Braking", and is intended for going down long grades. If you use only the regular brakes for going down a very long grade, it can overheat the brakes. To avoid this, drivers of traditional gas vehicles use a low gear so the engine friction would absorb the energy instead of the brakes. The "B" mode just simulates that traditional usage.
Basically, if you live in the mountains west of Denver, you will need to use B mode.
Old Jul 7, 2011 | 08:03 PM
ukrkoz's Avatar
B mode engages engine. Engine turns "passively" with throttle closed and allegedly no fuel supplied to it. That's the noise you here, engine spun.
So, in a manner of speech, B does "start" the engine, but on the other hand, no, it does not start it, as in "no combustion" is being initiated. It is strictly inertia braking.
Eggsaladsndwich
Feb 10, 2014 04:48 PM
mercynight
Jun 16, 2013 06:03 PM
ranger01
Oct 28, 2010 12:36 PM
phenderson
Dec 23, 2008 09:51 PM
ptung07
Aug 14, 2008 09:44 AM
