Effects of Terrain (Region) on Mileage
Old Jun 4, 2008 | 10:58 AM
Sooty's Avatar
Default Re: Effects of Terrain (Region) on Mileage
Originally Posted by chestr
My commute came out to 16.68 miles with elevations from -16 to 259 ft.
I should be so lucky.
I would expect vehicles at sea level like yourself to get better mileage than someone like me.
My commute is 12.96 miles but elevations vary between 3,503' and 3,956'
Old Jun 4, 2008 | 05:31 PM
H2O Doctor's Avatar
Arrow Re: Effects of Terrain (Region) on Mileage
Originally Posted by haroldo
While the car's engine works harder going uphill than it does going down, the swing in MPG might also be due to the slope of the gas in the tank when you are going uphill versus down. When you are going uphill, the gas sloshes to the back of the tank and, depending on where the sensor is located, the car is fooled into thinking you have more (or less) gas than you really have. If it thinks you have more gas, the the calculated mileage statistics (on the dash) will show an increased efficiency.
The gauges range from being a little inaccurate to very innacurate.
Best to take the miles per tank and divide by the gas station's meter to determine mileage.
Anything else (gauges and dials in car) is guesstimates, at best.
I have found the MFD to be very accurate. I'm sure you're not familiar with the grapevine. There is a large increase in elevation to reach the summit and then you drive for quite a few miles before descending. I took readings when the car was at level spots so you're idea that it was the slope was not a factor. It looks at fuel consumed not at level in the tank.
Old Jun 5, 2008 | 03:48 AM
jayw_TCH's Avatar
I choose another route home yesterday. (This is my 40 mile one way commute I do twice a week.) Thanks to the elevation map, I noticed another route that doesn't drop down 300 feet in the middle of the commute. On nearly a half tank, according to the Fuel computer, I am at 40 MPG exactly.
Thanks for posting that elevation map!
Old Jun 5, 2008 | 06:43 AM
coolshock1's Avatar
Driving in stealth mode
No problem. I am glad to finally return the helps as so many others have helped me. I never paid attention to the hills until I got my TCH.
Old Jun 6, 2008 | 09:35 AM
SPL's Avatar
SPL
My understanding is that the fuel usage is computed by the engine ECU from the fuel-injector pulse data. The amount of fuel injected per pulse is known by the ECU. The FE in mpg (or the FC in L/100 km) is then computed from the amount of fuel used and distance covered. The fuel tank gauge, and its (in)accuracy, play no role in this computation.
Stan
Old Jun 6, 2008 | 12:25 PM
FastMover's Avatar
Old Boomer Techie
Stan
Correct! The same technique has been used in general aviation piston powered aircraft that are fuel injected for many years. The only difference is that the fuel used is related to time and expressed as Gallons per Hour (GPH) or, for diesels or other aircraft that use Jet A, Pounds per Hour (PPH). This is then used with the caluclated ground speed to calculate range remaining, usually in Nautical Miles (NM). The accuracy can be quite good, and is actually required by regulations to be within 2%.
Jefferson
Jul 22, 2008 06:32 AM
PriusNut
Oct 4, 2006 06:14 AM
ericbecky
Jun 4, 2004 02:20 PM
