Dual exhaust on a TCH
Old Nov 29, 2008 | 07:37 PM
carolinacamry's Avatar
Default Dual exhaust on a TCH
Anybody added dual exhaust on a TCH without buying one of the after market kits with dual cutouts? I want to add another exhaust tip, functional or not, don't matter to me. Just really like the look of duals. How did you cut out the left side? Where did you get the exhaust tip to match the OEM one?
Frank
Old Nov 29, 2008 | 07:57 PM
GeorgiaHybrid's Avatar
Default Re: Dual exhaust on a TCH
Frank,
There is one guy at ToyotaNation that added a fake dual exhaust on his hybrid. He added a body kit to the car and wanted the SE "look". You might be able to add a SE bumper cover and take the car to a muffler shop to add a fake or functional exhaust tip to match or replace the factory look.
Old Dec 2, 2008 | 04:29 PM
UWAdventurer's Avatar
I added the Razzi kit to my TCH and it has the two cutouts. To cut the existing body, to allow me to install the fake exhaust tip on the drivers side, I used tin snips. Made a very nice cut in the original plastic bumper. The instructions said to use a utility knife. I thought that would be too hard to control, the tin snips did a great job. I also thought about a hole saw, decided the tin snips would do better.
FYI, you can buy the Razzi body kit as seperate pieces. Just the front, either side or just the back.
Hope this helps.
Old Dec 2, 2008 | 04:32 PM
Forgot to mention the tips I installed I got from Razzi also. I had to remove the original tip and install both I purchased from Razzi. Slightly different shape than the OEM, more oval.
ntguru
Jan 21, 2015 08:07 PM
vin888
May 20, 2008 09:12 AM
UWAdventurer
Apr 13, 2008 06:19 AM
gonavy
Jan 26, 2007 08:42 PM
indylisa_04pri_06feh
Introductions
Jan 11, 2006 11:32 PM
