Doors not locking on my '07 TCH
Old Aug 28, 2009 | 06:31 PM
Geckoboy's Avatar
Default Doors not locking on my '07 TCH
Hi,
This is the second occurence of my doors not locking after I put my car in park, turn off the engine, and leave the car.. I press the button on the drivers side handle and the doors will not lock. I walk over to the passenger side and press that button and it does not lock. I just my keyfob to lock the doors and still a no go. If I press the unlock button on my keyfob, you hear the click of the car unlocking the doors and then the 2 beeps to signal that the doors are unlocked. However, when I press the lock button on the keyfob, there is just silence.
I get in my car and press on the door lock button on the armrest and again, silence, the doors do not lock. So eventually I have to get out and lock each door manually.
Interestingly enough, it's random. I could get back to my car minutes or an hour later, and i can hit the unlock button and then the lock button and I will hear my car unlock and lock.
Has anyone experienced this? Any known user-able fixes?
Thanks!
Old Aug 28, 2009 | 07:06 PM
Droid13's Avatar
HSD Organic Interface
Default Re: Doors not locking on my '07 TCH
Normally when the car won't lock because of key detection or car left in "ready", I believe it provides lots of warning beeps, but that doesn't sound like your problem. Maybe a sticky switch somewhere, like on the shifter in P or something like that. Maybe cycle the power and shift out in back into P next time it happens and see if that changes anything...
Old Aug 29, 2009 | 05:09 AM
haroldo's Avatar
This is a warranty item, although recreating this in front of the dealer will be a tough one. If you're cell phone takes good video, I'd suggest recording this the next time it happens.
I had a strange radio display once and used a photo to prove to the dealer that it needed to be replaced. Given that this is a tad bit more serious than a radio and should be dealt with, your recorded proof is going to be the only way they'll believe you.
Old Aug 29, 2009 | 08:03 AM
Squint's Avatar
Malcontent
I think the car still complains if you turn it off without putting it in P.
Is it possible a low battery in the fob could cause this? If it's not being detected due to a low battery, putting the black square button on the handles won't lock the car and it would also explain why pressing the lock button on the fob doesn't lock the car either.
Old Aug 29, 2009 | 11:13 AM
Geckoboy's Avatar
I don't believe this is a low battery issue. The car also does not lock when I try to lock the door from the door lock button on the door (above the window switches).
My car is out of warranty so unfortunately any dealer fixes will be out of pocket. I'm hoping to get this resolved on my own, but will take to the dealer if necessary since I dont want to go around all four doors to manually lock it everytime I get out of the car.
Old Aug 29, 2009 | 11:18 AM
Frodo's Avatar
Does the car give you the 'door open' beep? The simple fault may be a switch out of adjustment and being interpreted as a open door.
Old Aug 29, 2009 | 05:23 PM
David Price's Avatar
Happy 07 TCH Owner
It sounds like it could be a lose connector inside the door panel, if it is it's easy to fix.
Old Aug 30, 2009 | 05:12 AM
rburt07's Avatar
I have had similar problems with the doors locking. I open the drivers door to exit and press the door lock switch. I hear the the doors lock and then immediately unlock. I look inside the car and see the car's clock is still lit up. I press the power/start button till the clock goes dark. Standing with the drivers door open, I press the lock button again, now the doors lock properly.
Old Aug 30, 2009 | 11:59 AM
sivilyar's Avatar
Mine did that too for two weeks until I found my spare keyfob in it...
No warning just wont lock and make a long annoing beep when I try to lock.
Old Sep 5, 2009 | 05:01 PM
donvaz's Avatar
Apparently there is service bulletin for this. I just returned from the dealership and the tech told me that they had to upgrade the software to resolve a door locking issue with the 2007. My car was in for a totally unrelated matter and I never had an issue with my door locks.
