Does your TCH lurch forward when you brake?
Old Jul 19, 2007 | 03:15 PM
KimikoPi's Avatar
Default Does your TCH lurch forward when you brake?
Before I drove my new TCH, I drove my mom's old Camry LE. I never felt the sensation that the car would jump forward slightly when I braked. But in my TCH, I feel it all the time. Is this normal? It is actually moving forward or is it just some strange sensation due to the technology? Now I try to brake earlier than I would.
Old Jul 19, 2007 | 04:23 PM
TomS's Avatar
Default Re: Does your TCH lurch forward when you brake?
It is caused by the system switching from regenerative braking to actual applying the brakes near the end of the braking cycle. You will eventually learn to brake in a way that reduces the slight lurching at the end.
Old Apr 9, 2008 | 10:50 AM
mjc49's Avatar
Enthused Driver
Resurrecting this thread since this is something I've been troubled with. It happens to me when I first start to brake, not when switching between regenerative and standard braking. I gently apply the brake and I feel as if there is a momentary additional push forward before the braking takes affect. It really freaked me out the first it happened.
Old Apr 9, 2008 | 01:54 PM
SPL's Avatar
SPL
mjc49 — If you hit a small (or large) bump while braking, it seems to momentarily disable the regenerative component of the braking. This is probably due to the wheel sensors reporting a sudden change in the rotational velocity of one or more wheels, as if a wheel had started slipping. The surge you feel (occasionally, I trust?) may be this sudden momentary reduction in braking effort.
Stan
Old Apr 9, 2008 | 07:37 PM
mjc49's Avatar
Enthused Driver
Thanks Stan. I haven't noticed if bumps are in teh equation, but I'll watch for that.
Old Apr 14, 2008 | 08:31 AM
Droid13's Avatar
HSD Organic Interface
In my experience this tends to be a lot more noticeable in the winter even on dry roads when tires and road are cold and road is sometimes covered with debris from winter salting or deteriorating pavement. It seems even minor bumps under these conditions will cause the regen to kick off whereas on a warm summer day it takes a lot worse road conditions to trigger the same...
Old Apr 14, 2008 | 09:26 AM
Noni's Avatar
I find this lurch most notiable when I am braking to disengage cruise control. First of all you have to actually press the brake more than I ever have in any other car, usually a tap should work. But I can feel a slight acceleration. It's irritating enough to start using the disengage cruise lever instead of the brake.
Old Apr 14, 2008 | 09:43 AM
mikieboyblue's Avatar
Yes. I agree. I stopped using the brake pedal to disengage the cruise control. I know "cancel" it....(unless I am braking for a reason).
Old Apr 14, 2008 | 10:26 AM
Moptop's Avatar
Since I read this post I am trying to be aware if this happens on my car as well. So far I have not noticed any lurching during braking. Perhaps I might have the right road conditions or it may have been something Toyota was aware of and tweaked for the 09 year.
Old Apr 14, 2008 | 10:32 AM
chris_h's Avatar
I have a 2007 TCH and I have never noticed this.
