Does your cabin air filter look like this?
Old Jun 19, 2008 | 04:51 PM
acco20's Avatar
Default Re: Does your cabin air filter look like this?
Originally Posted by GeorgiaHybrid
Acco20,
There is a return limiter on the right side of the glove box that is visible when open. Gently remove it to the right away from the glove box where is pushed over a plastic stud. Empty everything from the glove box (unless you want it on the floorboards).
Either pull on the center section at the back to deform the rear of the glove box (and pull the sides to the middle) or grasp the rear sides of the glove box, pull to the center and disengage the stops on each side of the glove box. This will allow it to swing down to gain access to the filter.
Remove the filter cover that is exposed and remove the filter. Reverse to install. Bosch has a very good cabin filter install guide on their website that covers most cars on the road. Download a copy of it for future vehicles that you need to change.
Thank you very much, I will try it very soon.
dgyimao
Dec 31, 2009 09:38 AM
sanosteam
Dec 26, 2009 07:17 AM
wiredup
Sep 8, 2009 10:23 PM
bugs
May 26, 2009 12:05 AM
EOppie
Nov 26, 2007 03:24 PM
