Does Battery Ever Fully Charge?
Old Mar 8, 2007 | 11:46 AM
hamm3r's Avatar
Default Re: Does Battery Ever Fully Charge?
https://www.greenhybrid.com/discuss/...t=fully+charge
Old Mar 8, 2007 | 02:41 PM
nash's Avatar
I've seen the battery at full charge after coasting down a long hill while lightly riding the brakes. I've also seen it go down to 1 bar a few times when creeping along in rush hour traffic for miles. Normally the ICE starts shortly after it drops to 2 bars, but twice I've seen it drop to 1 bar when just creeping without my foot on the gas.
Old Mar 8, 2007 | 04:35 PM
jbollt's Avatar
Nash, you took this pix while driving at 33MPH???? Oh, I know,your backseat passenger reached over your shoulder....got it!
Old Mar 8, 2007 | 05:47 PM
skywagon's Avatar
According to Toyota full is still only 80%.
Old Mar 8, 2007 | 08:36 PM
nash's Avatar
backseat passenger ... Yeah! The backseat passenger took it
Skywagon, good point. I was referencing the battery gauge reading 100%
Old Mar 9, 2007 | 03:22 PM
C11634's Avatar
Originally Posted by scottzorch
I regularly get it down to 1-2 bars by running in forced-EV mode in heavy traffic. On a bad day, it'll drop low enough to need to run the engine to charge; normally, I'll get past the usual jam before that point and recharge on open road.
What is forced-EV mode ? I have to be super feather foot just to keep the engine from turning on, I would love to be able to force into EV mode.
Old Mar 9, 2007 | 05:53 PM
tnsig's Avatar
The easiest way to get into EV mode after the engine is warm is to get the car's speed up to around 40 MPH and then let your foot off the gas pedal and then slightly push down on the gas pedal. As you mentioned you need to have a light foot otherwise the ICE will kick in. On level ground I can keep it going about 40 MPH until I hit an incline...
Old Mar 9, 2007 | 06:16 PM
Droid13's Avatar
HSD Organic Interface
Switching the climate control system off makes it easier too, or at least avoid high heat/cool or defroster settings.
Curated Content Editor
Dec 10, 2014 11:00 AM
spinner
Jul 9, 2008 06:18 AM
mnsweeps
Toyota Highlander Hybrid
Apr 25, 2008 04:05 PM
07camry
Aug 13, 2007 10:18 AM
