Disable TRAC....quick winter time tip
Old Dec 29, 2010 | 08:36 AM
wwest's Avatar
Default Re: Disable TRAC....quick winter time tip
Originally Posted by ukrkoz
yes sir! exactly same spot - james/madison exit. you have to take R into james, and it's 2 1/2 consecutive very steep inclines, and red light normally catches you on the 1st light. madison is not that bad. it's james and cherry that do this. and i go there routinely for work.
sort of fun to take them in my silverado. left on brakes, right on gas, step on gas and slowly release brakes - whoo-hoo!
But just a real ***** with a stick shift....
Release the e-brake in synchroniation.........
Old Jan 5, 2011 | 06:04 PM
ukrkoz's Avatar
so, i was in north Seattle, sitting uphill today. left on brake pedal, right on gas, as always. then i remembered of this post, took my left off the brake pedal, and placed right one on it, just like everyone else does.
then, taking off, i released brake pedal and switched to gas pedal.
SHE DID NOT ROLL BACK, AND ICE STARTED RIGHT AWAY.
apparently, she is smart enough to hold brakes on steep hills!
Old Jan 6, 2011 | 03:42 PM
acco20's Avatar
http://townhall-talk.edmunds.com/WebX?14@@.ef31962/4632 here is another method that I have not tried but I understand works well...
Old Jan 7, 2011 | 12:29 PM
GreenRedTCH's Avatar
Or, if you have a Ford Fusion Hybrid, just push the "TC Off" button . This allows you to spin the wheels, but limits wheelspin to 40 virtual MPH, and engine speed to 2000 RPM (yes, we have a tachometer too ). I did this once when stuck on some especially slippery graupel. The wheels spun for about a second and the car was free. Before I disabled TC, it felt like the accelerator just wasn't connected to anything. So it looks like Ford has a better idea. [Ducks behind curtain to avoid rotten tomatoes .]
Old Jan 7, 2011 | 11:23 PM
wwest's Avatar
I like to think you mean "TC disable", not VSC. Many new FWD and/or F/awd vehicles have this TC off feature, RWD's alsway have had.
Old Jan 7, 2011 | 11:58 PM
Indeed you are correct. I got my acronyms mixed up. Error has been corrected. Thanks!
haroldo
Feb 20, 2011 11:47 AM
mikieboyblue
Apr 21, 2008 09:59 AM
haroldo
Mar 24, 2008 07:41 AM
Orcrone
Jun 8, 2006 03:29 PM
tbaleno
Dec 22, 2005 09:03 PM
