Dings in Deck Lid
Old Sep 2, 2008 | 09:38 AM
LEAKYTCH's Avatar
Default Dings in Deck Lid
I have 3 really small, almost imperceptible dings in my deck lid. I think I can gently press them out from underneath, but I need to remove the inside fabric liner underneath the deck lid. It has some sort of plastic fasteners. Does anybody know how you remove/reattach those fasteners? Is there any trick to it or do you need any special tool?
Old Sep 2, 2008 | 09:59 AM
mikieboyblue's Avatar
Default Re: Dings in Deck Lid
What is the deck lid?
Old Sep 2, 2008 | 10:15 AM
tbone526's Avatar
NASCAR term for the top of the trunk.
Old Sep 2, 2008 | 11:30 AM
GeorgiaHybrid's Avatar
Leaky,
Driving my daughter's Civic today but I'm fairly certain that the center "button" pulls out to remove the fastener. If not, the center section pushs in. I've had mine out but don't remember which way I had to go.
Old Sep 2, 2008 | 02:31 PM
TCH80226's Avatar
0__o
If that fails, pull the liner and bust them off:
Item: Trunk lid, Interior trim, Trunk lid trim, Clip, Us built
Price: $1.03 each at http://www.toyotapartscheap.com
Old Sep 2, 2008 | 04:17 PM
SteveHansen's Avatar
Pragmatist
The outer ring has prongs that are expanded by a finger that is attached to the middle piece. To remove, just pull on the middle piece using fingernails or very thin tools like table knives. It doesn't take much force, so I do it with fingernails.
Be careful to keep track of them all. They can be reused, and they cost more than it seems like they should.
To put them back in, pull the middle piece out about 3/8 inch, until the prongs on the outer sleeve will fit through the hole again. Pushing the middle in expands the prongs to hold it in.
Old Sep 2, 2008 | 05:33 PM
billc918's Avatar
Check a local autoparts store like "Advance Auto Parts" or "AutoZone". I purchased a tool from one of these stores(for about $5 or $6) to remove the plastic fasteners without damaging them. I used this tool several times on another car with similar fasteners on the trunk lid. It worked fine.
Old Sep 2, 2008 | 05:53 PM
billc918's Avatar
geek
Mar 14, 2009 07:11 PM
LouBeck
Jul 3, 2007 09:02 PM
shoebox303
Oct 26, 2006 07:10 AM
SanDiegoBlue
Jul 7, 2006 06:43 PM
mwong99
Mar 13, 2006 11:59 AM
