Cruise contol
Old Aug 26, 2009 | 06:31 PM
carolinacamry's Avatar
Default Cruise contol
Does anyone else have problems with their cruise control? I can set mine and when I go down hill, the cruise control won't maintain the set speed. Sometimes the car will gain up to 5 mph. When I get to the bottom of the hill, it will take it a couple of seconds before it re-engages and takes the car back to the set speed. My son's Chrysler will keep the set speed within 1-2 mpgs all the time. Just wondered if this was normal for the TCH.
Old Aug 26, 2009 | 07:27 PM
BOFH's Avatar
Default Re: Cruise contol
I suspect it is because the TCH does not have engine braking unless you put it into 'B' mode. Cruise control only adjusts the accelerator, it will not brake the car if it goes faster than the set speed.
Old Aug 26, 2009 | 07:32 PM
Ok, that makes sense. Thanks!
Old Aug 26, 2009 | 07:47 PM
rburt07's Avatar
I have set my cruise control to 60 mph on a 3 mile long almost straight mountain downgrade. The car coast on up 85 mph, way above the set speed. Like you say, the cruise took over once it was back down to 60 mph.
Like BOFH said, it's up to you to apply the brakes on any hills if needed. Any braking would drop your cruise setting.
Old Aug 27, 2009 | 06:50 AM
jbollt's Avatar
I understand what the Frank is saying. I once drove a Chrysler rental car on a vacation, and it would actually downshift to a lower gear by itself while using cruise control to maintain the set speed on long downgrades. This was sometimes annoying, as the sorrounding traffic was speeding up with the hill, and I was becoming slower than the flow of traffic.
Old Aug 27, 2009 | 07:06 AM
haroldo's Avatar
Originally Posted by jbollt
...would ...downshift to a lower gear by itself while using cruise control to maintain the set speed on long downgrades. This was sometimes annoying, as the sorrounding traffic was speeding up with the hill, and I was becoming slower than the flow of traffic.
Cruise control has a 'coast' setting (override cruise control and let the car roll normally) for these instances.
Usually, the control stick is a four way control: quick movement up, quick down, long up, long down. I believe quick down enters coast mode and quick up resumes the contolled speed.
Civic Duty
Jul 24, 2005 08:48 AM
Sadie
May 9, 2005 07:07 AM
RoyalF
Dec 15, 2004 02:58 PM
videian
Jun 9, 2004 07:05 PM
