Constant squeal/high pitch noise
Old Jan 12, 2016 | 12:30 PM
2008hybridcamry's Avatar
Default Constant squeal/high pitch noise
Has anybody had a problem with a constant squeak in the rear wheels when your backing up and going at speeds under about 40? Sounds like a sound your brakes make when they are worn and you apply them but in my case it is constant until I get up to faster speeds. Help
Old Jan 12, 2016 | 01:56 PM
litespeed's Avatar
Professor Emeritus
Default Re: Constant squeal/high pitch noise
That sounds like the classic "seized slide pin" problem. Common on these cars if you do not do a regular service on the brakes. One or more of the slide pins on the calipers is more than likely seized and your pads are probably wearing at a weird angle. Pull the rear wheels, calipers and pads and have a look.
Old Jan 15, 2016 | 08:39 PM
ukrkoz's Avatar
glazed rotors. I had to de-glaze mine for the squeal to go away. Soft brake pads won't do this.
lincolnshibuya
Mar 20, 2013 08:29 AM
Slick
Feb 17, 2011 09:13 AM
Orcrone
Jun 6, 2007 03:39 AM
bmgoodman
Jul 27, 2006 08:13 PM
Jason
Hybrid & Related News
Apr 11, 2005 04:04 PM
