Complete list OBDII codes
Old Sep 3, 2012 | 08:32 AM
ukrkoz's Avatar
Default Complete list OBDII codes
It's not really DIY forum, but hey, who knows, some of us might find it useful, before running to dealers:
Ok Guys - Thanks to Marc M of the Tacoma forum, here is a list of the OBD-II Codes as listed on a Matrix owners site. Has been updated to the Master Sticky (or will be very shortly). So here goes - And please note: The P1xxx codes are all Toyota Specific, and the P0xxx are General and will relate to all cars.
Diagnostic Codes - Toyota
On-Board Diagnostics II OBDII
OBD II TROUBLE CODES
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Malfunction
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch "A" Circuit Intermittent
P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature For Stable Operation
P0130 O2Circuit Malfunction (Bank #1 Sensor #1)
P0131 O2Sensor Circuit Low Voltage (Bank #1 Sensor #1)
P0132 O2Sensor Circuit High Voltage (Bank #1 Sensor #1)
P0133 O2Sensor Circuit Slow Response (Bank #1 Sensor #1)
P0134 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #1)
P0135 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #1)
P0136 O2Sensor Circuit Malfunction (Bank #1 Sensor #2)
P0137 O2Sensor Circuit Low Voltage (Bank #1 Sensor #2)
P0138 O2Sensor Circuit High Voltage (Bank #1 Sensor #2)
P0139 O2Sensor Circuit Slow Response (Bank #1 Sensor #2)
P0140 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #2)
P0141 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #2)
P0142 O2Sensor Circuit Malfunction (Bank #1 Sensor #3)
P0143 O2Sensor Circuit Low Voltage (Bank #1 Sensor #3)
P0144 O2Sensor Circuit High Voltage (Bank #1 Sensor #3)
P0145 O2Sensor Circuit Slow Response (Bank #1 Sensor #3)
P0146 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #3)
P0147 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #3)
P0150 O2Sensor Circuit Malfunction (Bank #2 Sensor #1)
P0151 O2Sensor Circuit Low Voltage (Bank #2 Sensor #1)
P0152 O2Sensor Circuit High Voltage (Bank #2 Sensor #1)
P0153 O2Sensor Circuit Slow Response (Bank #2 Sensor #1)
P0154 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #1)
P0155 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #1)
P0156 O2Sensor Circuit Malfunction (Bank #2 Sensor #2)
P0157 O2Sensor Circuit Low Voltage (Bank #2 Sensor #2)
P0158 O2Sensor Circuit High Voltage (Bank #2 Sensor #2)
P0159 O2Sensor Circuit Slow Response (Bank #2 Sensor #2)
P0160 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #2)
P0161 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #2)
P0162 O2Sensor Circuit Malfunction (Bank #2 Sensor #3)
P0163 O2Sensor Circuit Low Voltage (Bank #2 Sensor #3)
P0164 O2Sensor Circuit High Voltage (Bank #2 Sensor #3)
P0165 O2Sensor Circuit Slow Response (Bank #2 Sensor #3)
P0166 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #3)
P0167 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #3)
P0170 Fuel Trim Malfunction (Bank #1)
P0171 System Too Lean (Bank #1)
P0172 System Too Rich (Bank #1)
P0173 Fuel Trim Malfunction (Bank #2)
P0174 System Too Lean (Bank #2)
P0175 System Too Rich (Bank #2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor "A" Circuit Malfunction
P0181 Fuel Temperature Sensor "A" Circuit Range/Performance
P0182 Fuel Temperature Sensor "A" Circuit Low Input
P0183 Fuel Temperature Sensor "A" Circuit High Input
P0184 Fuel Temperature Sensor "A" Circuit Intermittent
P0185 Fuel Temperature Sensor "B" Circuit Malfunction
P0186 Fuel Temperature Sensor "B" Circuit Range/Performance
P0187 Fuel Temperature Sensor "B" Circuit Low Input
P0188 Fuel Temperature Sensor "B" Circuit High Input
P0189 Fuel Temperature Sensor "B" Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 EngineOil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction — Cylinder #1
P0202 Injector Circuit Malfunction — Cylinder #2
P0203 Injector Circuit Malfunction — Cylinder #3
P0204 Injector Circuit Malfunction — Cylinder #4
P0205 Injector Circuit Malfunction — Cylinder #5
P0206 Injector Circuit Malfunction — Cylinder #6
P0207 Injector Circuit Malfunction — Cylinder #7
P0208 Injector Circuit Malfunction — Cylinder #8
P0209 Injector Circuit Malfunction — Cylinder #9
P0210 Injector Circuit Malfunction — Cylinder #10
P0211 Injector Circuit Malfunction — Cylinder #11
P0212 Injector Circuit Malfunction — Cylinder #12
P0213 Cold Start Injector #1 Malfunction
P0214 Cold Start Injector #2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Over Temperature Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Over Speed Condition
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Malfunction
P0221 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance Problem
P0222 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input
P0224 Throttle/Pedal Position Sensor/Switch "B" Circuit Intermittent
P0225 Throttle/Pedal Position Sensor/Switch "C" Circuit Malfunction
P0226 Throttle/Pedal Position Sensor/Switch "C" Circuit Range/Performance Problem
P0227 Throttle/Pedal Position Sensor/Switch "C" Circuit Low Input
P0228 Throttle/Pedal Position Sensor/Switch "C" Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch "C" Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Over Boost Condition
P0261 Cylinder #1 Injector Circuit Low
P0262 Cylinder #1 Injector Circuit High
P0263 Cylinder #1 Contribution/Balance Fault
P0264 Cylinder #2 Injector Circuit Low
P0265 Cylinder #2 Injector Circuit High
P0266 Cylinder #2 Contribution/Balance Fault
P0267 Cylinder #3 Injector Circuit Low
P0268 Cylinder #3 Injector Circuit High
P0269 Cylinder #3 Contribution/Balance Fault
P0270 Cylinder #4 Injector Circuit Low
P0271 Cylinder #4 Injector Circuit High
P0272 Cylinder #4 Contribution/Balance Fault
P0273 Cylinder #5 Injector Circuit Low
P0274 Cylinder #5 Injector Circuit High
P0275 Cylinder #5 Contribution/Balance Fault
P0276 Cylinder #6 Injector Circuit Low
P0277 Cylinder #6 Injector Circuit High
P0278 Cylinder #6 Contribution/Balance Fault
P0279 Cylinder #7 Injector Circuit Low
P0280 Cylinder #7 Injector Circuit High
P0281 Cylinder #7 Contribution/Balance Fault
P0282 Cylinder #8 Injector Circuit Low
P0283 Cylinder #8 Injector Circuit High
P0284 Cylinder #8 Contribution/Balance Fault
P0285 Cylinder #9 Injector Circuit Low
P0286 Cylinder #9 Injector Circuit High
P0287 Cylinder #9 Contribution/Balance Fault
P0288 Cylinder #10 Injector Circuit Low
P0289 Cylinder #10 Injector Circuit High
P0290 Cylinder #10 Contribution/Balance Fault
P0291 Cylinder #11 Injector Circuit Low
P0292 Cylinder #11 Injector Circuit High
P0293 Cylinder #11 Contribution/Balance Fault
P0294 Cylinder #12 Injector Circuit Low
P0295 Cylinder #12 Injector Circuit High
P0296 Cylinder #12 Contribution/Balance Fault
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder #1 — Misfire Detected
P0302 Cylinder #2 — Misfire Detected
P0303 Cylinder #3 — Misfire Detected
P0304 Cylinder #4 — Misfire Detected
P0305 Cylinder #5 — Misfire Detected
P0306 Cylinder #6 — Misfire Detected
P0307 Cylinder #7 — Misfire Detected
P0308 Cylinder #8 — Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor #1 — Circuit Malfunction (Bank #1 or Single Sensor)
P0326 nock Sensor #1 — Circuit Range/Performance (Bank #1 or Single Sensor)
P0327 Knock Sensor #1 — Circuit Low Input (Bank #1 or Single Sensor)
P0328 Knock Sensor #1 — Circuit High Input (Bank #1 or Single Sensor)
P0329 Knock Sensor #1 — Circuit Input Intermittent (Bank #1 or Single Sensor)
P0330 Knock Sensor #2 — Circuit Malfunction (Bank #2)
P0331 Knock Sensor #2 — Circuit Range/Performance (Bank #2)
P0332 Knock Sensor #2 — Circuit Low Input (Bank #2)
P0333 Knock Sensor #2 — Circuit High Input (Bank #2)
P0334 Knock Sensor #2 — Circuit Input Intermittent (Bank #2)
P0335 Crankshaft Position Sensor "A" Circuit Malfunction
P0336 Crankshaft Position Sensor "A" Circuit Range/Performance
P0337 Crankshaft Position Sensor "A" Circuit Low Input
P0338 Crankshaft Position Sensor "A" Circuit High Input
P0339 Crankshaft Position Sensor "A" Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil "A" Primary/Secondary Circuit Malfunction
P0352 Ignition Coil "B" Primary/Secondary Circuit Malfunction
P0353 Ignition Coil "C" Primary/Secondary Circuit Malfunction
P0354 Ignition Coil "D" Primary/Secondary Circuit Malfunction
P0355 Ignition Coil "E" Primary/Secondary Circuit Malfunction
P0356 Ignition Coil "F" Primary/Secondary Circuit Malfunction
P0357 Ignition Coil "G" Primary/Secondary Circuit Malfunction
P0358 Ignition Coil "H" Primary/Secondary Circuit Malfunction
P0359 Ignition Coil "I" Primary/Secondary Circuit Malfunction
P0360 Ignition Coil "J" Primary/Secondary Circuit Malfunction
P0361 Ignition Coil "K" Primary/Secondary Circuit Malfunction
P0362 Ignition Coil "L" Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal "A" Malfunction
P0371 Timing Reference High Resolution Signal "A" Too Many Pulses
P0372 Timing Reference High Resolution Signal "A" Too Few Pulses
P0373 Timing Reference High Resolution Signal "A" Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal "A" No Pulses
P0375 Timing Reference High Resolution Signal "B" Malfunction
P0376 Timing Reference High Resolution Signal "B" Too Many Pulses
P0377 Timing Reference High Resolution Signal "B" Too Few Pulses
P0378 Timing Reference High Resolution Signal "B" Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal "B" No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Glow Plug/Heater Circuit "B" Malfunction
P0385 Crankshaft Position Sensor "B" Circuit Malfunction
P0386 Crankshaft Position Sensor "B" Circuit Range/Performance
P0387 Crankshaft Position Sensor "B" Circuit Low Input
P0388 Crankshaft Position Sensor "B" Circuit High Input
P0389 Crankshaft Position Sensor "B" Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor "A" Circuit Low
P0406 Exhaust Gas Recirculation Sensor "A" Circuit High
P0407 Exhaust Gas Recirculation Sensor "B" Circuit Low
P0408 Exhaust Gas Recirculation Sensor "B" Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve "A" Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve "A" Circuit Open
P0414 Secondary Air Injection System Switching Valve "A" Circuit Shorted
P0415 Secondary Air Injection System Switching Valve "B" Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve "B" Circuit Open
P0417 Secondary Air Injection System Switching Valve "B" Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank #1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank #1)
P0422 Main Catalyst Efficiency Below Threshold (Bank #1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank #1)
P0424 Heated Catalyst Temperature Below Threshold (Bank #1)
P0430 Catalyst System Efficiency Below Threshold (Bank #2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank #2)
P0432 Main Catalyst Efficiency Below Threshold (Bank #2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank #2)
P0434 Heated Catalyst Temperature Below Threshold (Bank #2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (Small Leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (Gross Leak)
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan #1 Control Circuit Malfunction
P0481 Cooling Fan #2 Control Circuit Malfunction
P0482 Cooling Fan #3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Circuit Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Low Voltage
P0523 Engine Oil Pressure Sensor/Switch High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 A/C Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565 CruiseControl On Signal Malfunction
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch "A" Circuit Malfunction
P0572 Cruise Control/Brake Switch "A" Circuit Low
P0573 Cruise Control/Brake Switch "A" Circuit High
P0574 Through P0580 Reserved for Cruise Codes
P0600 Serial Communication Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 PCM Processor Fault
P0608 Control Module VSS Output "A" Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfunction
P0656 Fuel Level Output Circuit Malfunction
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch "B" Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 TransmissionFluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch "B" Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Circuit Range/Performance
P0722 Output Speed Sensor Circuit No Signal
P0723 Output Speed Sensor Circuit Intermittent
P0724 Torque Converter/Brake Switch "B" Circuit High
P0725 Engine Speed Input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear #1 Incorrect Ratio
P0732 Gear #2 Incorrect Ratio
P0733 Gear #3 Incorrect Ratio
P0734 Gear #4 Incorrect Ratio
P0735 Gear #5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0740 Torque Converter Clutch Circuit Malfunction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid "A" Malfunction
P0751 Shift Solenoid "A" Performance or Stuck Off
P0752 Shift Solenoid "A" Stuck On
P0753 Shift Solenoid "A" Electrical
P0754 Shift Solenoid "A" Intermittent
P0755 Shift Solenoid "B" Malfunction
P0756 Shift Solenoid "B" Performance or Stuck Off
P0757 Shift Solenoid "B" Stuck On
P0758 Shift Solenoid "B" Electrical
P0759 Shift Solenoid "B" Intermittent
P0760 Shift Solenoid "C" Malfunction
P0761 Shift Solenoid "C" Performance Or Stuck Off
P0762 Shift Solenoid "C" Stuck On
P0763 Shift Solenoid "C" Electrical
P0764 Shift Solenoid "C" Intermittent
P0765 Shift Solenoid "D" Malfunction
P0766 Shift Solenoid "D" Performance Or Stuck Off
P0767 Shift Solenoid "D" Stuck On
P0768 Shift Solenoid "D" Electrical
P0769 Shift Solenoid "D" Intermittent
P0770 Shift Solenoid "E" Malfunction
P0771 Shift Solenoid "E" Performance Or Stuck Off
P0772 Shift Solenoid "E" Stuck On
P0773 Shift Solenoid "E" Electrical
P0774 Shift Solenoid "E" Intermittent
P0780 Shift Malfunction
P0781 1–2 Shift Malfunction
P0782 2–3 Shift Malfunction
P0783 3–4 Shift Malfunction
P0784 4–5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1–4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 1–4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P1100 Barometric Pressure Sensor Circuit Fault
P1120 Accelerator Pedal Position Sensor Circuit Malfunction
P1121 Accelerator Pedal Position Sensor Range/Performance Problem
P1125 Throttle Control Motor Circuit Malfunction
P1126 Magnetic Clutch Circuit Malfunction
P1127 ETCS Actuator Power Source Circuit Malfunction
P1128 Throttle Control Motor Lock Malfunction
P1129 Electric Throttle Control System Malfunction
P1130 A/F Sensor Circuit Range / Performance Malfunction (Bank #1 Sensor #1)
P1133 A/F Sensor Circuit Response Malfunction (Bank #1 Sensor #1)
P1135 A/F Sensor Heater Circuit Malfunction (Bank #1 Sensor #1)
P1150 A/F Sensor Circuit Range / Performance Malfunction (Bank #2 Sensor #1)
P1153 A/F Sensor Circuit Response Malfunction (Bank #2 Sensor #1)
P1155 A/F Sensor Heater Circuit Malfunction (Bank #2 Sensor #1)
P1200 Fuel Pump Relay Circuit Fault
P1300 Igniter Circuit Fault (Bank #1)
P1305 Igniter Circuit Fault (Bank #2)
P1310 Igniter Circuit Fault (Bank #3)
P1315 Igniter Circuit Fault (Bank #4)
P1320 Igniter Circuit Fault (Bank #5)
P1325 Igniter Circuit Fault (Bank #6)
P1330 Igniter Circuit Fault (Bank #7)
P1335 Crankshaft Position Sensor Circuit Fault (during engine running)
P1340 Igniter Circuit Fault (Bank #8)
P1400 Sub-Throttle Position Sensor Circuit Fault
P1401 Sub-Throttle Position Sensor Performance
P1500 Starter Signal Circuit Fault
P1510 Air Volume Too Low With Supercharger On
P1520 Stop Light Switch Signal Malfunction
P1600 ECM Battery Back-up Circuit Fault
P1633 ECM Malfunction (ETCS Circuit)
P1605 Knock Control CPU Fault
P1700 Vehicle Speed Sensor Circuit Fault
P1705 Direct Clutch Speed Sensor Circuit Fault
P1765 Linear Shift Solenoid Circuit Fault
P1780 Park Neutral Position Switch Fault
__________________
Old Sep 3, 2012 | 09:13 AM
GeorgiaHybrid's Avatar
Default Re: Complete list OBDII codes
P0xxx codes are "generic" and required to be generated per OBD II standards. The P1xxx codes are specific to a maker (in this case, Toyota) AND to a specific car. That is the reason that list does not have the P1420 series codes from a Camry Hybrid
Old Sep 3, 2012 | 02:13 PM
ukrkoz's Avatar
OK, for purists:
here are ALL possible codes, specific and non specific. What we gonna do without Motherhttp:
//alflash.com.ua/OBDII/DTCe1.pdf Russia...
Old Sep 3, 2012 | 02:45 PM
ukrkoz's Avatar
And all Hybrid Camry specific codes:
(once again, thank you, Mother Russia)
AIR BAG RESTRAINT DTCS
HYBRID DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION
DTC Description
B1000 Center Airbag Sensor Assembly Malfunction
B1603 Front Satellite Sensor Bus RH Initialization Incomplete
B1608 Front Satellite Sensor Bus LH Initialization Incomplete
B1610 Front Airbag Sensor RH Malfunction
B1612 Lost Communication with Front Airbag Sensor RH
B1613 Front Airbag Sensor RH Initialization Incomplete
B1615 Front Airbag Sensor LH Malfunction
B1617 Lost Communication with Front Airbag Sensor LH
B1618 Front Airbag Sensor LH Initialization Incomplete
B1620 Driver Side - Side Airbag Sensor Malfunction
B1622 Lost Communication with Driver Side -Side Airbag Sensor Assembly
B1623 Driver Side - Side Airbag Sensor Assembly Initialization Incomplete
B1625 Front Passenger Side - Side Airbag Sensor Malfunction
B1627 Lost Communication with Front Passenger Side - Side Airbag Sensor Assembly
B1628 Front Passenger Side - Side Airbag Sensor Assembly Initialization Incomplete
B1630 Driver Side Rear Airbag Sensor Malfunction
B1632 Lost Communication with Driver Side Rear Airbag Sensor
B1633 Driver Side Rear Airbag Sensor Initialization Incomplete
B1635 Front Passenger Side Rear Airbag Sensor Malfunction
B1637 Lost Communication with Passenger Side Rear Airbag Sensor
B1638 Passenger Side Rear Airbag Sensor Initialization Incomplete
B1642 Lost Communication with Driver Side Satellite Sensor Bus
B1643 Driver Side Satellite Sensor Bus Initialization Incomplete
B1647 Lost Communication with Front Passenger Side Satellite Sensor Bus
B1648 Front Passenger Side Satellite Sensor Bus Initialization Incomplete
B1650 Occupant Classification System Malfunction
B1653 Seat Position Airbag Sensor Circuit Malfunction
B1655 Driver Side Seat Belt Buckle Switch Circuit Malfunction
B1660 Passenger Airbag ON/OFF Indicator Circuit Malfunction
B1771 Passenger Side Buckle Switch Circuit Malfunction
B1780 Front Occupant Classification Sensor LH Circuit Malfunction
B1781 Front Occupant Classification Sensor RH Circuit Malfunction
B1782 Rear Occupant Classification Sensor LH Circuit Malfunction
B1783 Rear Occupant Classification Sensor RH Circuit Malfunction
B1785 Front Occupant Classification Sensor LH Collision Detection
B1786 Front Occupant Classification Sensor RH Collision Detection
B1787 Rear Occupant Classification Sensor LH Collision Detection
B1788 Rear Occupant Classification Sensor RH Collision Detection
B1790 Center Airbag Sensor Assembly Communication Circuit Malfunction
B1793 Occupant Classification Sensor Power Supply Circuit Malfunction
B1794 Open in Occupant Classification ECU Battery Positive Line
B1795 Occupant Classification ECU Malfunction
B1796 Sleep Operation Failure of Occupant Classification ECU
B1800 Short in Driver Side Squib Circuit
B1801 Open in Driver Side Squib Circuit
B1802 Short to GND in Driver Side Squib Circuit
B1803 Short to B+ in Driver Side Squib Circuit
B1805 Short in Front Passenger Side Squib Circuit
B1806 Open in Front Passenger Side Squib Circuit
B1807 Short to GND in Front Passenger Side Squib Circuit
B1808 Short to B+ in Front Passenger Side Squib Circuit
B1810 Short in Driver Side Squib 2nd Step Circuit
B1811 Open in Driver Side Squib 2nd Step Circuit
B1812 Short to GND in Driver Side Squib 2nd Step Circuit
B1813 Short to B+ in Driver Side Squib 2nd Step Circuit
B1815 Short in Front Passenger Side Squib 2nd Step Circuit
B1816 Open in Front Passenger Side Squib 2nd Step Circuit
B1817 Short to GND in Front Passenger Side Squib 2nd Step Circuit
B1818 Short to B+ in Front Passenger Side Squib 2nd Step Circuit
B1820 Short in Front Driver Side - Side Squib Circuit
B1821 Open in Front Driver Side - Side Squib Circuit
B1822 Short to GND in Front Driver Side - Side Squib Circuit
B1823 Short to B+ in Front Driver Side - Side Squib Circuit
B1825 Short in Front Passenger Side - Side Squib Circuit
B1826 Open in Front Passenger Side - Side Squib Circuit
B1827 Short to GND in Front Passenger Side -Side Squib Circuit
B1828 Short to B+ in Front Passenger Side - Side Squib Circuit
B1830 Short in Driver Side Curtain Shield Squib Circuit
B1831 Open in Driver Side Curtain Shield Squib Circuit
B1832 Short to GND in Driver Side Curtain Shield Squib Circuit
B1833 Short to B+ in Driver Side Curtain Shield Squib Circuit
B1835 Short in Front Passenger Side Curtain Shield Squib Circuit
B1836 Open in Front Passenger Side Curtain Shield Squib Circuit
B1837 Short to GND in Front Passenger Side Curtain Shield Squib Circuit
B1838 Short to B+ in Front Passenger Side Curtain Shield Squib Circuit
B1860 Short in Driver Side Knee Airbag Squib Circuit
B1861 Open in Driver Side Knee Airbag Squib Circuit
B1862 Short to GND in Driver Side Knee Airbag Squib Circuit
B1863 Short to B+ in Driver Side Knee Airbag Squib Circuit
B1900 Short in Front Driver Side Pretensioner Squib Circuit
B1901 Open in Front Driver Side Pretensioner Squib Circuit
B1902 Short to GND in Front Driver Side Pretensioner Squib Circuit
B1903 Short to B+ in Front Driver Side Pretensioner Squib Circuit
B1905 Short in Front Passenger Side Pretensioner Squib Circuit
B1906 Open in Front Passenger Side Pretensioner Squib Circuit
B1907 Short to GND in Front Passenger Side Pretensioner Squib Circuit
B1908 Short to B+ in Front Passenger Side Pretensioner Squib Circuit
ANTI-LOCK BRAKE DTCS
DTC Description
C0200 Front Speed Sensor RH Circuit
C0205 Front Speed Sensor LH Circuit
C0210 Rear Speed Sensor RH Circuit
C0215 Rear Speed Sensor LH Circuit
C0371 Yaw Rate Sensor (Test Mode DTC)
C1202 Master Reservoir Level Malfunction
C1203 ECM Communication Circuit Malfunction
C1210 Zero Point Calibration of Yaw Rate Sensor Undone
C1231 Steering Angle Sensor Circuit Malfunction
C1234 Yaw Rate Sensor Malfunction
C1235 Foreign Object is Attached on Tip of Front Speed Sensor RH
C1236 Foreign Object is Attached on Tip of Front Speed Sensor LH
C1238 Foreign Object is Attached on Tip of Rear Speed Sensor RH
C1239 Foreign Object is Attached on Tip of Rear Speed Sensor LH
C1241 Low Battery Positive Voltage
C1242 Open in IG1/IG2 Power Source Circuit
C1243 Acceleration Sensor Stuck Malfunction
C1244 Open or Short in Acceleration Sensor Circuit
C1245 Acceleration Sensor Output Malfunction
C1246 Master Cylinder Pressure Sensor Malfunction
C1247 Stroke Sensor Malfunction
C1249 Open in Stop Light Switch Circuit
C1252 Brake Booster Pump Motor on Time Abnormally Long
C1253 Pump Motor Relay Malfunction
C1256 Accumulator Low Pressure
C1259 HV System Regenerative Malfunction
C1271 Low Output Signal of Front Speed Sensor RH (Test Mode DTC)
C1272 Low Output Signal of Front Speed Sensor LH (Test Mode DTC)
C1273 Low Output Signal of Rear Speed Sensor RH (Test Mode DTC)
C1274 Low Output Signal of Rear Speed Sensor LH (Test Mode DTC)
C1275 Abnormal Change in Output Signal of Front Speed Sensor RH (Test Mode DTC)
C1276 Abnormal Change in Output Signal of Front Speed Sensor LH (Test Mode DTC)
C1277 Abnormal Change in Output Signal of Rear Speed Sensor RH (Test Mode DTC)
C1278 Abnormal Change in Output Signal of Rear Speed Sensor LH (Test Mode DTC)
C1279 Acceleration Sensor Output Voltage Malfunction (Test Mode DTC)
C1281 Master Cylinder Pressure Sensor Output Malfunction (Test Mode DTC)
C1290 Steering Angle Sensor Zero Point Malfunction
C1300 Skid Control ECU Malfunction
C1304 EPS Control System Malfunction
C1310 Malfunction in HV system
C1311 Open in Main Relay 1 Circuit
C1312 Short in Main Relay 1 Circuit
C1313 Open in Main Relay 2 Circuit
C1314 Short in Main Relay 2 Circuit
C1315 SMC1 Changeover Solenoid Malfunction
C1316 SMC2 Changeover Solenoid Malfunction
C1319 SCSS Changeover Solenoid Malfunction
C1336 Zero Point Calibration of Acceleration Sensor Undone
C1341 Front Hydraulic System RH Malfunction
C1342 Front Hydraulic System LH Malfunction
C1343 Rear Hydraulic System RH Malfunction
C1344 Rear Hydraulic System LH Malfunction
C1345 Linear Solenoid Valve Offset Learning Undone
C1346 Stroke Sensor Zero Point Learning Malfunction (Test Mode DTC)
C1352 Front Increasing Pressure Solenoid RH Malfunction
C1353 Front Increasing Pressure Solenoid LH Malfunction
C1354 Rear Increasing Pressure Solenoid RH Malfunction
C1355 Rear Increasing Pressure Solenoid LH Malfunction
C1356 Front Decreasing Pressure Solenoid RH Malfunction
C1357 Front Decreasing Pressure Solenoid LH Malfunction
C1358 Rear Decreasing Pressure Solenoid RH Malfunction
C1359 Rear Decreasing Pressure Solenoid LH Malfunction
C1364 Wheel Cylinder Pressure Sensor Malfunction
C1365 Accumulator Pressure Sensor Malfunction
C1368 Linear Solenoid Valve Offset Malfunction
C1377 Capacitor Malfunction
C1378 Capacitor Communication Malfunction
C1381 Yaw Rate and/or Acceleration Sensor Power Supply Voltage Malfunction
C1391 Accumulator Leak Malfunction
C1392 Stroke Sensor Zero Point Calibration Undone
U0073 Control Module Communication Bus OFF
U0123 Lost Communication with Yaw Rate Sensor Module
U0124 Lost Communication with Lateral Acceleration Sensor Module
U0126 Lost Communication with Steering Angle Sensor Module
U0131 Lost Communication with Power Steering Control Module
U0293 Communication Error from HV ECU
AUTOMATIC TRANSMISSION DTCS
U250E DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION
DTC Description
P0710 Transmission Fluid Temperature Sensor "A" Circuit
P0711 Transmission Fluid Temperature Sensor "A" Performance
P0712 Transmission Fluid Temperature Sensor "A" Circuit Low Input
P0713 Transmission Fluid Temperature Sensor "A" Circuit High Input
P0717 Turbine Speed Sensor Circuit No Signal
P0724 Brake Switch "B" Circuit High
P0741 Torque Converter Clutch Solenoid Performance (Shift Solenoid Valve DSL)
P0746 Pressure Control Solenoid "A" Performance (Shift Solenoid Valve SL1)
P0748 Pressure Control Solenoid "A" Electrical (Shift Solenoid Valve SL1)
P0766 Shift Solenoid "D" Performance (Shift Solenoid Valve S4)
P0771 Shift Solenoid "E" Performance (Shift Solenoid Valve SR)
P0776 Pressure Control Solenoid "B" Performance (Shift Solenoid Valve SL2)
P0778 Pressure Control Solenoid "B" Electrical (Shift Solenoid Valve SL2)
P0793 Intermediate Shaft Speed Sensor "A"
P0796 Pressure Control Solenoid "C" Performance (Shift Solenoid Valve SL3)
P0798 Pressure Control Solenoid "C" Electrical (Shift Solenoid Valve SL3)
P0982 Shift Solenoid "D" Control Circuit Low (Shift Solenoid Valve S4)
P0983 Shift Solenoid "D" Control Circuit High (Shift Solenoid Valve S4)
P0985 Shift Solenoid "E" Control Circuit Low (Shift Solenoid Valve SR)
P0986 Shift Solenoid "E" Control Circuit High (Shift Solenoid Valve SR)
P2714 Pressure Control Solenoid "D" Performance (Shift Solenoid Valve SLT)
P2716 Pressure Control Solenoid "D" Electrical (Shift Solenoid Valve SLT)
P2769 Torque Converter Clutch Solenoid Circuit Low (Shift Solenoid Valve DSL)
P2770 Torque Converter Clutch Solenoid Circuit High (Shift Solenoid Valve DSL)
U660E DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION
DTC Description
P0500 Vehicle Speed Sensor "A"
P0617 Starter Relay Circuit High
P0715 Input / Turbine Speed Sensor Circuit Malfunction
P0717 Input Speed Sensor Circuit No Signal
P0741 Torque Converter Clutch Solenoid Performance (Shift Solenoid Valve SL)
P0791 Intermediate Shaft Speed Sensor "A" Circuit
P0872 Transmission Fluid Pressure Switch No.1 Circuit Low
P0873 Transmission Fluid Pressure Switch No.1 Circuit High
P0877 Transmission Fluid Pressure Switch No.2 Circuit Low
P0878 Transmission Fluid Pressure Switch No.2 Circuit High
P0989 Transmission Fluid Pressure Switch No.3 Circuit Low
P0990 Transmission Fluid Pressure Switch No.3 Circuit High
P2757 Torque Converter Clutch Pressure Control Solenoid Performance (Shift Solenoid Valve SLU)
P2759 Torque Converter Clutch Pressure Control Solenoid Control Circuit Electrical (Shift Solenoid Valve SLU)
P2769 Short in Torque Converter Clutch Solenoid Circuit (Shift Solenoid Valve SL)
P2808 Pressure Control Solenoid "G" Performance or Stuck OFF (Shift Solenoid Valve SL4)
P2770 Open in Torque Converter Clutch Solenoid Circuit (Shift Solenoid Valve SL)
P2810 Pressure Control Solenoid "G" Electrical (Shift Solenoid Valve SL4)
U0100 Lost Communication with ECM/PCM "A"
CAN COMMUNICATION DTCS
DTC Description
B1207 Certification ECU Communication Malfunction
B1247 Tire Pressure Monitor Receiver Communication Stop
B2326 CAN MS Bus Line Communication Malfunction
CRUISE CONTROL DTCS
DTC Description
P0571 Brake Switch "A" Circuit
P0607 Control Module Performance
DOOR LOCK DTCS
DTC Description
B1242 Wireless Door Lock Tuner Circuit Malfunction
ENGINE IMMOBILIZER DTCS (A00287573)
W/ SMART KEY SYSTEM
W/ SMART KEY SYSTEM DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION
DTC Description
B2784 Antenna Coil Open/Short
B2785 Communication Malfunction between ECUs Connected by LIN
B2786 No Response from Steering Lock ECU
B2789 No Response from ID BOX
B278A Short to GND in Immobilizer System Power Source Circuit
B2790 ID BOX EEPROM Malfunction
B2791 Communication Condition Failure between ECM
B2799 Engine Immobilizer System
W/O SMART KEY SYSTEM
W/O SMART KEY SYSTEM DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION
DTC Description
B2780 Push Switch/Key Unlock Warning Switch Malfunction
B2793 Transponder Chip Malfunction
B2794 Unmatched Encryption Code
B2795 Unmatched Key Code
B2796 No Communication in Immobilizer System
B2797 Communication Malfunction No. 1
B2798 Communication Malfunction No. 2
ENGINE IMMOBILIZER (HYBRID) DTCS (A00304747)
ENGINE IMMOBILIZER (HYBRID) DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION
DTC Description
B2799 Engine Immobilizer System Malfunction
ENGINE PERFORMANCE DTCS
DTC Description
P0010 Camshaft Position "A" Actuator Circuit (Bank 1)
P0011 Camshaft Position "A" - Timing Over - Advanced or System Performance (Bank 1)
P0012 Camshaft Position "A" - Timing Over-Retarded (Bank 1)
P0016 Crankshaft Position -Camshaft Position Correlation (Bank 1 Sensor A)
P0031 Oxygen (A/F) Sensor Heater Control Circuit Low (Bank 1 Sensor 1)
P0032 Oxygen (A/F) Sensor Heater Control Circuit High (Bank 1 Sensor 1)
P0037 Oxygen Sensor Heater Control Circuit Low (Bank 1 Sensor 2)
P0038 Oxygen Sensor Heater Control Circuit High (Bank 1 Sensor 2)
P0101 Mass Air Flow Circuit Range / Performance Problem
P0111 Intake Air Temperature Sensor Gradient Too High
P0116 Engine Coolant Temperature Circuit Range / Performance Problem
P0120 Throttle / Pedal Position Sensor / Switch "A" Circuit Malfunction
P0121 Throttle / Pedal Position Sensor / Switch "A" Circuit Range / Performance Problem
P0122 Throttle / Pedal Position Sensor / Switch "A" Circuit Low Input
P0123 Throttle / Pedal Position Sensor / Switch "A" Circuit High Input
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
P0136 Oxygen Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137 Oxygen Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 Oxygen Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 Oxygen Sensor Circuit Slow Response(Bank 1 Sensor 2)
P0141 Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0171 System Too Lean (Bank 1)
P0172 System Too Rich (Bank 1)
P0220 Throttle / Pedal Position Sensor / Switch "B" Circuit
P0222 Throttle / Pedal Position Sensor / Switch "B" Circuit Low Input
P0223 Throttle / Pedal Position Sensor / Switch "B" Circuit High Input
P0300 Random / Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0340 Camshaft Position Sensor "A" Circuit (Bank 1 or Single Sensor)
P0351 Ignition Coil "A" Primary / Secondary Circuit
P0352 Ignition Coil "B" Primary / Secondary Circuit
P0353 Ignition Coil "C" Primary / Secondary Circuit
P0354 Ignition Coil "D" Primary / Secondary Circuit
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P043E Evaporative Emission System Reference Orifice Clog Up
P043F Evaporative Emission System Reference Orifice High Flow
P0450 Evaporative Emission Control System Pressure Sensor / Switch
P0451 Evaporative Emission Control System Pressure Sensor Range / Performance
P0452 Evaporative Emission Control System Pressure Sensor/ Switch Low Input
P0453 Evaporative Emission Control System Pressure Sensor / Switch High Input
P050A Cold Start Idle Air Control System Performance
P0606 ECM/PCM Processor
P0657 Actuator Supply Voltage Circuit / Open
P1420 Evaporative Emission Canister Small Leak
P1421 Evaporative Emission Canister Gross Leak
P1422 Fuel Tank Small Leak
P1423 Fuel Tank Gross Leak
P1451 Fuel Tank Pressure Sensor Range/ Performance
P1452 Fuel Tank Pressure Sensor Low Input
P1453 Fuel Tank Pressure Sensor High Input
P2102 Throttle Actuator Control Motor Circuit Low
P2103 Throttle Actuator Control Motor Circuit High
P2111 Throttle Actuator Control System -Stuck Open
P2112 Throttle Actuator Control System -Stuck Closed
P2118 Throttle Actuator Control Motor Current Range / Performance
P2119 Throttle Actuator Control Throttle Body Range / Performance
P2135 Throttle / Pedal Position Sensor / Switch "A" / "B" Voltage Correlation
P2195 Oxygen (A/F) Sensor Signal Stuck Lean (Bank 1 Sensor 1)
P2196 Oxygen (A/F) Sensor Signal Stuck Rich (Bank 1 Sensor 1)
P2237 Oxygen (A/F) Sensor Pumping Current Circuit / Open (Bank 1 Sensor 1)
P2238 Oxygen (A/F) Sensor Pumping Current Circuit Low (Bank 1 Sensor 1)
P2239 Oxygen (A/F) Sensor Pumping Current Circuit High (Bank 1 Sensor 1)
P2252 Oxygen (A/F) Sensor Reference Ground Circuit Low (Bank 1 Sensor 1)
P2253 Oxygen (A/F) Sensor Reference Ground Circuit High (Bank 1 Sensor 1)
P2401 Evaporative Emission Leak Detection Pump Stuck OFF
P2402 Evaporative Emission Leak Detection Pump Stuck ON
P2419 Evaporative Emission System Switching Valve Control Circuit Low
P2420 Evaporative Emission System Switching Valve Control Circuit High
P2450 Fuel Vapor-containment Valve Stuck Open
P2451 Fuel Vapor-containment Valve Stuck Close
P2610 ECM / PCM Internal Engine Off Timer Performance
P2A00 A/F Sensor Circuit Slow Response (Bank 1 Sensor 1)
P3190 Poor Engine Power
P3191 Engine does not Start
P3193 Fuel Run Out
U0001 High Speed CAN Communication Circuit
U0293 Lost Communication with HV ECU
HVAC (HYBRID) DTCS (A00304768)
HVAC (HYBRID) DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION
DTC Description
B1411 Room Temperature Sensor Circuit
B1412 Ambient Temperature Sensor Circuit
B1413 Evaporator Temperature Sensor Circuit
B1421 Solar Sensor Circuit (Passenger Side)
B1423 Pressure Sensor Circuit
B1424 Solar Sensor Circuit (Driver Side)
B1441 Air Mix Damper Control Servo Motor Circuit (Passenger Side)
B1442 Air Inlet Damper Control Servo Motor Circuit
B1443 Air Outlet Damper Control Servo Motor Circuit
B1446 Air Mix Damper Control Servo Motor Circuit (Driver Side)
B1471 A/C Inverter High Voltage Power Resource System Malfunction
B1472 A/C Inverter High Voltage Output System Malfunction
B1473 A/C Inverter Start-up Signal System Malfunction
B1474 A/C Inverter Malfunction
B1475 A/C Inverter Cooling / Heating System Malfunction
B1476 A/C Inverter Load System Malfunction
B1477 A/C Inverter Low Voltage Power Resource System Malfunction
B1497 BUS IC Communication Malfunction
B1498 Communication Malfunction (A/C Inverter Local)
B1499 Multiplex Communication Circuit
P0AA6 Hybrid Battery Voltage System Isolation Fault
ukrkoz's Avatar
Had to cut it in two pieces:
HYBRID BATTERY CONTROL DTCS (A00304769)
HYBRID BATTERY CONTROL DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION
DTC Description
P0A1F Battery Energy Control Module
P0A7F Hybrid Battery Pack Deterioration
P0A80 Replace Hybrid Battery Pack
P0A82 Hybrid Battery Pack Cooling Fan 1
P0A84 Hybrid Battery Pack Cooling Fan 1
P0A85 Hybrid Battery Pack Cooling Fan 1
P0A95 High Voltage Fuse
P0A9C Hybrid Battery Temperature Sensor "A"
P0A9D Hybrid Battery Temperature Sensor "A" Circuit Low
P0A9E Hybrid Battery Temperature Sensor "A" Circuit High
P0AAC Hybrid Battery Pack Air Temperature Sensor "A" Circuit
P0ABF Hybrid Battery Pack Current Sensor Circuit
P0AC0 Hybrid Battery Pack Current Sensor Circuit Range/Performance
P0AC1 Hybrid Battery Pack Current Sensor Circuit Low
P0AC2 Hybrid Battery Pack Current Sensor Circuit High
P0AFA Hybrid Battery System Voltage Low
P3011 Battery Block 1 Becomes Weak
P3012 Battery Block 2 Becomes Weak
P3013 Battery Block 3 Becomes Weak
P3014 Battery Block 4 Becomes Weak
P3015 Battery Block 5 Becomes Weak
P3016 Battery Block 6 Becomes Weak
P3017 Battery Block 7 Becomes Weak
P3018 Battery Block 8 Becomes Weak
P3019 Battery Block 9 Becomes Weak
P3020 Battery Block 10 Becomes Weak
P3021 Battery Block 11 Becomes Weak
P3022 Battery Block 12 Becomes Weak
P3023 Battery Block 13 Becomes Weak
P3024 Battery Block 14 Becomes Weak
P3025 Battery Block 15 Becomes Weak
P3026 Battery Block 16 Becomes Weak
P3027 Battery Block 17 Becomes Weak
U029A Lost Communication with Hybrid Battery Pack Sensor module
LIGHTING DTCS
DTC Description
B1244 Light Sensor Circuit Malfunction
METER DTCS
DTC Description
U0129 Lost Communication with Skid Control ECU
P311 HYBRID VEHICLE CONTROL DTCS (A00304757)
P311 HYBRID VEHICLE CONTROL DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION
DTC Description
P0343 Camshaft Position Sensor "A" Circuit High Input
P0516 Battery Temperature Sensor Circuit Low
P0517 Battery Temperature Sensor Circuit High
P062F EEPROM Malfunction
P0630 VIN not Programmed or Mismatch - ECM/PCM
P0851 Park/Neutral Switch Input Circuit Low
P0A01 Motor Electronics Coolant Temperature Sensor Circuit Range/Performance
P0A02 Motor Electronics Coolant Temperature Sensor Circuit Low
P0A03 Motor Electronics Coolant Temperature Sensor Circuit High
P0A08 DC/DC Converter Status Circuit
P0A09 DC/DC Converter Status Circuit Low Input
P0A0D High Voltage System Inter-Lock Circuit High
P0A0F Engine Failed to Start
P0A10 DC/DC Converter Status Circuit High Input
P0A1A Generator Control Module
P0A1B Drive Motor "A" Control Module
P0A1D Hybrid Powertrain Control Module
P0A2B Drive Motor "A" Temperature Sensor Circuit Range/Performance
P0A2C Drive Motor "A" Temperature Sensor Circuit Low
P0A2D Drive Motor "A" Temperature Sensor Circuit High
P0A37 Generator Temperature Sensor Circuit Range/Performance
P0A38 Generator Temperature Sensor Circuit Low
P0A39 Generator Temperature Sensor Circuit High
P0A3F Drive Motor "A" Position Sensor Circuit
P0A40 Drive Motor "A" Position Sensor Circuit Range/Performance
P0A41 Drive Motor "A" Position Sensor Circuit Low
P0A4B Generator Position Sensor Circuit
P0A4C Generator Position Sensor Circuit Range/Performance
P0A4D Generator Position Sensor Circuit Low
P0A51 Drive Motor "A" Current Sensor Circuit
P0A60 Drive Motor "A" Phase V Current
P0A63 Drive Motor "A" Phase W Current
P0A72 Generator Phase V Current
P0A75 Generator Phase W Current
P0A78 Drive Motor "A" Inverter Performance
P0A7A Generator Inverter Performance
P0A90 Drive Motor "A" Performance
P0A92 Hybrid Generator Performance
P0A93 Inverter Cooling System Performance
P0A94 DC/DC Converter Performance
P0AA1 Hybrid Battery Positive Contractor Circuit Stuck Closed
P0AA4 Hybrid Battery Negative Contractor Circuit Stuck Closed
P0AA7 Hybrid Battery Voltage Isolation Sensor Circuit
P0ADB Hybrid Battery Positive Contractor Control Circuit Low
P0ADC Hybrid Battery Positive Contractor Control Circuit High
P0ADF Hybrid Battery Negative Contractor Control Circuit Low
P0AE0 Hybrid Battery Negative Contractor Control Circuit High
P0AE2 Hybrid Battery Precharge Contractor Circuit Stuck Closed
P0AE6 Hybrid Battery Precharge Contractor Control Circuit Low
P0AE7 Hybrid Battery Precharge Contractor Control Circuit High
P0AEE Motor Inverter Temperature Sensor "A" Circuit Range/Performance
P0AEF Drive Motor Inverter Temperature Sensor "A" Circuit Low
P0AF0 Drive Motor Inverter Temperature Sensor "A" Circuit High
P1555 Reactor Temperature Sensor Circuit Low
P1556 Reactor Temperature Sensor Circuit High
P1606 Collision Detection
P2120 Throttle/Pedal Position Sensor/Switch "D" Circuit
P2121 Throttle/Pedal Position Sensor/Switch "D" Circuit Range/Performance
P2122 Throttle/Pedal Position Sensor/Switch "D" Circuit Low Input
P2123 Throttle/Pedal Position Sensor/Switch "D" Circuit High Input
P2125 Throttle/Pedal Position Sensor/Switch "E" Circuit
P2126 Throttle/Pedal Position Sensor/Switch "E" Circuit Range/Performance
P2127 Throttle/Pedal Position Sensor/Switch "E" Circuit Low Input
P2128 Throttle/Pedal Position Sensor/Switch "E" Circuit High Input
P2138 Throttle/Pedal Position Sensor/Switch "D"/"E" Voltage Correlation
P2511 ECM/PCM Power Relay Sense Circuit Intermittent
P2519 A/C Request "A" Circuit
P2532 Ignition Switch Run Position Circuit High
P3000 HV Battery Malfunction
P3004 Power Cable Malfunction
P3107 Airbag ECU Communication Circuit Malfunction
P3108 A/C Amplifier Communication Circuit Malfunction
P3110 IGCT Relay Malfunction
P3137 Collision Sensor Low Input
P3138 Collision Sensor High Input
P3147 Transmission Malfunction
P3221 Generator Inverter Temperature Sensor Circuit Range/Performance
P3222 Generator Inverter Temperature Sensor Circuit High/Low
P3223 Generator Inverter Temperature Sensor Circuit High
P3226 DC/DC Boost Converter Temperature Sensor
P3227 Converter Temperature Sensor Circuit Low
P3228 Converter Temperature Sensor Circuit High
P3232 Open or Short to B+ in Blocking of HV Gate Connection
P3233 Short to B+ in Blocking of HV Gate Connection
U0110 Lost Communication with Driver Motor Control Module
U0129 Lost Communication with Brake System Control Module
U0140 Lost Communication with Body Control Module
U0151 Lost Communication with Airbag ECU
U0164 Lost Communication with A/C ECU
U0424 Invalid Data Received from HVAC Control Module
POWER STEERING (HYBRID) DTCS (A00304772)
POWER STEERING (HYBRID) DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION
DTC Description
C1511 Torque Sensor Circuit Malfunction
C1512 Torque Sensor Circuit Malfunction
C1513 Torque Sensor Circuit Malfunction
C1515 Torque Sensor Zero Point Adjustment Undone
C1516 Torque Sensor Zero Point Adjustment Incomplete
C1521 Motor Circuit Malfunction
C1522 Motor Circuit Malfunction
C1523 Motor Circuit Malfunction
C1524 Motor Circuit Malfunction
C1525 Rotation Angle Sensor Initialization Undone
C1526 Rotation Angle Sensor Initialization Incomplete
C1528 Motor Rotation Angle Sensor Malfunction
C1531 ECU Malfunction
C1532 ECU Malfunction
C1533 ECU Malfunction
C1534 ECU Malfunction
C1541 Vehicle Speed Signal Malfunction
C1551 IG Power Supply Voltage Malfunction
C1552 PIG Power Supply Voltage Malfunction
C1554 Power Supply Relay Failure
C1555 Motor Relay Welding Failure
C1581 Assist Map Number Un-Writing
SLIDING ROOF DTCS
DTC Description
B2341 Sensor (Motor) Failure
B2342 Switch Failure
B2343 Position Initialization Incomplete
B2344 Position Failure
STEERING COLUMN (HYBRID) DTCS
DTC Description
B2781 Open/Short in Steering Lock ECU
B2782 Power Source Control ECU Malfunction
B2788 IG2 Signal Malfunction
WHEEL & TIRE DTCS
DTC Description
C2111 Transmitter ID1 Operation Stop
C2112 Transmitter ID2 Operation Stop
C2113 Transmitter ID3 Operation Stop
C2114 Transmitter ID4 Operation Stop
C2121 No Signal from Transmitter ID1 in Main Mode
C2122 No Signal from Transmitter ID2 in Main Mode
C2123 No Signal from Transmitter ID3 in Main Mode
C2124 No Signal from Transmitter ID4 in Main Mode
C2126 Transmitter ID not Received in Main Mode
C2141 Transmitter ID1 Error
C2142 Transmitter ID2 Error
C2143 Transmitter ID3 Error
C2144 Transmitter ID4 Error
C2165 Abnormal Temperature Inside ID1 Tire
C2166 Abnormal Temperature Inside ID2 Tire
C2167 Abnormal Temperature Inside ID3 Tire
C2168 Abnormal Temperature Inside ID4 Tire
C2171 Transmitter ID not Registered
C2176 Receiver Error
C2177 Initialization not Completed
C2179 Tire Pressure Monitor ECU Communication Stop
C2181 Transmitter ID1 not Received (Test Mode DTC)
C2182 Transmitter ID2 not Received (Test Mode DTC)
C2183 Transmitter ID3 not Received (Test Mode DTC)
C2184 Transmitter ID4 not Received (Test Mode DTC)
C2191 Vehicle Speed Signal Error (Test Mode DTC)
twolostminds
Feb 18, 2018 11:10 PM
08hybridok
Feb 12, 2014 04:05 PM
jbarneshb
Sep 10, 2011 03:30 PM
FmrLCpl
May 19, 2010 11:31 PM
end
Oct 12, 2007 11:52 AM
