Complete list OBDII codes
It's not really DIY forum, but hey, who knows, some of us might find it useful, before running to dealers:
Ok Guys - Thanks to Marc M of the Tacoma forum, here is a list of the OBD-II Codes as listed on a Matrix owners site. Has been updated to the Master Sticky (or will be very shortly). So here goes - And please note: The P1xxx codes are all Toyota Specific, and the P0xxx are General and will relate to all cars. Diagnostic Codes - Toyota On-Board Diagnostics II OBDII OBD II TROUBLE CODES P0100 Mass or Volume Air Flow Circuit Malfunction P0101 Mass or Volume Air Flow Circuit Range/Performance Problem P0102 Mass or Volume Air Flow Circuit Low Input P0103 Mass or Volume Air Flow Circuit High Input P0104 Mass or Volume Air Flow Circuit Intermittent P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent P0110 Intake Air Temperature Circuit Malfunction P0111 Intake Air Temperature Circuit Range/Performance Problem P0112 Intake Air Temperature Circuit Low Input P0113 Intake Air Temperature Circuit High Input P0114 Intake Air Temperature Circuit Intermittent P0115 Engine Coolant Temperature Circuit Malfunction P0116 Engine Coolant Temperature Circuit Range/Performance Problem P0117 Engine Coolant Temperature Circuit Low Input P0118 Engine Coolant Temperature Circuit High Input P0119 Engine Coolant Temperature Circuit Intermittent P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Malfunction P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input P0123 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input P0124 Throttle/Pedal Position Sensor/Switch "A" Circuit Intermittent P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control P0126 Insufficient Coolant Temperature For Stable Operation P0130 O2Circuit Malfunction (Bank #1 Sensor #1) P0131 O2Sensor Circuit Low Voltage (Bank #1 Sensor #1) P0132 O2Sensor Circuit High Voltage (Bank #1 Sensor #1) P0133 O2Sensor Circuit Slow Response (Bank #1 Sensor #1) P0134 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #1) P0135 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #1) P0136 O2Sensor Circuit Malfunction (Bank #1 Sensor #2) P0137 O2Sensor Circuit Low Voltage (Bank #1 Sensor #2) P0138 O2Sensor Circuit High Voltage (Bank #1 Sensor #2) P0139 O2Sensor Circuit Slow Response (Bank #1 Sensor #2) P0140 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #2) P0141 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #2) P0142 O2Sensor Circuit Malfunction (Bank #1 Sensor #3) P0143 O2Sensor Circuit Low Voltage (Bank #1 Sensor #3) P0144 O2Sensor Circuit High Voltage (Bank #1 Sensor #3) P0145 O2Sensor Circuit Slow Response (Bank #1 Sensor #3) P0146 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #3) P0147 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #3) P0150 O2Sensor Circuit Malfunction (Bank #2 Sensor #1) P0151 O2Sensor Circuit Low Voltage (Bank #2 Sensor #1) P0152 O2Sensor Circuit High Voltage (Bank #2 Sensor #1) P0153 O2Sensor Circuit Slow Response (Bank #2 Sensor #1) P0154 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #1) P0155 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #1) P0156 O2Sensor Circuit Malfunction (Bank #2 Sensor #2) P0157 O2Sensor Circuit Low Voltage (Bank #2 Sensor #2) P0158 O2Sensor Circuit High Voltage (Bank #2 Sensor #2) P0159 O2Sensor Circuit Slow Response (Bank #2 Sensor #2) P0160 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #2) P0161 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #2) P0162 O2Sensor Circuit Malfunction (Bank #2 Sensor #3) P0163 O2Sensor Circuit Low Voltage (Bank #2 Sensor #3) P0164 O2Sensor Circuit High Voltage (Bank #2 Sensor #3) P0165 O2Sensor Circuit Slow Response (Bank #2 Sensor #3) P0166 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #3) P0167 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #3) P0170 Fuel Trim Malfunction (Bank #1) P0171 System Too Lean (Bank #1) P0172 System Too Rich (Bank #1) P0173 Fuel Trim Malfunction (Bank #2) P0174 System Too Lean (Bank #2) P0175 System Too Rich (Bank #2) P0176 Fuel Composition Sensor Circuit Malfunction P0177 Fuel Composition Sensor Circuit Range/Performance P0178 Fuel Composition Sensor Circuit Low Input P0179 Fuel Composition Sensor Circuit High Input P0180 Fuel Temperature Sensor "A" Circuit Malfunction P0181 Fuel Temperature Sensor "A" Circuit Range/Performance P0182 Fuel Temperature Sensor "A" Circuit Low Input P0183 Fuel Temperature Sensor "A" Circuit High Input P0184 Fuel Temperature Sensor "A" Circuit Intermittent P0185 Fuel Temperature Sensor "B" Circuit Malfunction P0186 Fuel Temperature Sensor "B" Circuit Range/Performance P0187 Fuel Temperature Sensor "B" Circuit Low Input P0188 Fuel Temperature Sensor "B" Circuit High Input P0189 Fuel Temperature Sensor "B" Circuit Intermittent P0190 Fuel Rail Pressure Sensor Circuit Malfunction P0191 Fuel Rail Pressure Sensor Circuit Range/Performance P0192 Fuel Rail Pressure Sensor Circuit Low Input P0193 Fuel Rail Pressure Sensor Circuit High Input P0194 Fuel Rail Pressure Sensor Circuit Intermittent P0195 EngineOil Temperature Sensor Malfunction P0196 Engine Oil Temperature Sensor Range/Performance P0197 Engine Oil Temperature Sensor Low P0198 Engine Oil Temperature Sensor High P0199 Engine Oil Temperature Sensor Intermittent P0200 Injector Circuit Malfunction P0201 Injector Circuit Malfunction — Cylinder #1 P0202 Injector Circuit Malfunction — Cylinder #2 P0203 Injector Circuit Malfunction — Cylinder #3 P0204 Injector Circuit Malfunction — Cylinder #4 P0205 Injector Circuit Malfunction — Cylinder #5 P0206 Injector Circuit Malfunction — Cylinder #6 P0207 Injector Circuit Malfunction — Cylinder #7 P0208 Injector Circuit Malfunction — Cylinder #8 P0209 Injector Circuit Malfunction — Cylinder #9 P0210 Injector Circuit Malfunction — Cylinder #10 P0211 Injector Circuit Malfunction — Cylinder #11 P0212 Injector Circuit Malfunction — Cylinder #12 P0213 Cold Start Injector #1 Malfunction P0214 Cold Start Injector #2 Malfunction P0215 Engine Shutoff Solenoid Malfunction P0216 Injection Timing Control Circuit Malfunction P0217 Engine Over Temperature Condition P0218 Transmission Over Temperature Condition P0219 Engine Over Speed Condition P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Malfunction P0221 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance Problem P0222 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input P0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input P0224 Throttle/Pedal Position Sensor/Switch "B" Circuit Intermittent P0225 Throttle/Pedal Position Sensor/Switch "C" Circuit Malfunction P0226 Throttle/Pedal Position Sensor/Switch "C" Circuit Range/Performance Problem P0227 Throttle/Pedal Position Sensor/Switch "C" Circuit Low Input P0228 Throttle/Pedal Position Sensor/Switch "C" Circuit High Input P0229 Throttle/Pedal Position Sensor/Switch "C" Circuit Intermittent P0230 Fuel Pump Primary Circuit Malfunction P0231 Fuel Pump Secondary Circuit Low P0232 Fuel Pump Secondary Circuit High P0233 Fuel Pump Secondary Circuit Intermittent P0234 Engine Over Boost Condition P0261 Cylinder #1 Injector Circuit Low P0262 Cylinder #1 Injector Circuit High P0263 Cylinder #1 Contribution/Balance Fault P0264 Cylinder #2 Injector Circuit Low P0265 Cylinder #2 Injector Circuit High P0266 Cylinder #2 Contribution/Balance Fault P0267 Cylinder #3 Injector Circuit Low P0268 Cylinder #3 Injector Circuit High P0269 Cylinder #3 Contribution/Balance Fault P0270 Cylinder #4 Injector Circuit Low P0271 Cylinder #4 Injector Circuit High P0272 Cylinder #4 Contribution/Balance Fault P0273 Cylinder #5 Injector Circuit Low P0274 Cylinder #5 Injector Circuit High P0275 Cylinder #5 Contribution/Balance Fault P0276 Cylinder #6 Injector Circuit Low P0277 Cylinder #6 Injector Circuit High P0278 Cylinder #6 Contribution/Balance Fault P0279 Cylinder #7 Injector Circuit Low P0280 Cylinder #7 Injector Circuit High P0281 Cylinder #7 Contribution/Balance Fault P0282 Cylinder #8 Injector Circuit Low P0283 Cylinder #8 Injector Circuit High P0284 Cylinder #8 Contribution/Balance Fault P0285 Cylinder #9 Injector Circuit Low P0286 Cylinder #9 Injector Circuit High P0287 Cylinder #9 Contribution/Balance Fault P0288 Cylinder #10 Injector Circuit Low P0289 Cylinder #10 Injector Circuit High P0290 Cylinder #10 Contribution/Balance Fault P0291 Cylinder #11 Injector Circuit Low P0292 Cylinder #11 Injector Circuit High P0293 Cylinder #11 Contribution/Balance Fault P0294 Cylinder #12 Injector Circuit Low P0295 Cylinder #12 Injector Circuit High P0296 Cylinder #12 Contribution/Balance Fault P0300 Random/Multiple Cylinder Misfire Detected P0301 Cylinder #1 — Misfire Detected P0302 Cylinder #2 — Misfire Detected P0303 Cylinder #3 — Misfire Detected P0304 Cylinder #4 — Misfire Detected P0305 Cylinder #5 — Misfire Detected P0306 Cylinder #6 — Misfire Detected P0307 Cylinder #7 — Misfire Detected P0308 Cylinder #8 — Misfire Detected P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance P0322 Ignition/Distributor Engine Speed Input Circuit No Signal P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent P0325 Knock Sensor #1 — Circuit Malfunction (Bank #1 or Single Sensor) P0326 nock Sensor #1 — Circuit Range/Performance (Bank #1 or Single Sensor) P0327 Knock Sensor #1 — Circuit Low Input (Bank #1 or Single Sensor) P0328 Knock Sensor #1 — Circuit High Input (Bank #1 or Single Sensor) P0329 Knock Sensor #1 — Circuit Input Intermittent (Bank #1 or Single Sensor) P0330 Knock Sensor #2 — Circuit Malfunction (Bank #2) P0331 Knock Sensor #2 — Circuit Range/Performance (Bank #2) P0332 Knock Sensor #2 — Circuit Low Input (Bank #2) P0333 Knock Sensor #2 — Circuit High Input (Bank #2) P0334 Knock Sensor #2 — Circuit Input Intermittent (Bank #2) P0335 Crankshaft Position Sensor "A" Circuit Malfunction P0336 Crankshaft Position Sensor "A" Circuit Range/Performance P0337 Crankshaft Position Sensor "A" Circuit Low Input P0338 Crankshaft Position Sensor "A" Circuit High Input P0339 Crankshaft Position Sensor "A" Circuit Intermittent P0340 Camshaft Position Sensor Circuit Malfunction P0341 Camshaft Position Sensor Circuit Range/Performance P0342 Camshaft Position Sensor Circuit Low Input P0343 Camshaft Position Sensor Circuit High Input P0344 Camshaft Position Sensor Circuit Intermittent P0350 Ignition Coil Primary/Secondary Circuit Malfunction P0351 Ignition Coil "A" Primary/Secondary Circuit Malfunction P0352 Ignition Coil "B" Primary/Secondary Circuit Malfunction P0353 Ignition Coil "C" Primary/Secondary Circuit Malfunction P0354 Ignition Coil "D" Primary/Secondary Circuit Malfunction P0355 Ignition Coil "E" Primary/Secondary Circuit Malfunction P0356 Ignition Coil "F" Primary/Secondary Circuit Malfunction P0357 Ignition Coil "G" Primary/Secondary Circuit Malfunction P0358 Ignition Coil "H" Primary/Secondary Circuit Malfunction P0359 Ignition Coil "I" Primary/Secondary Circuit Malfunction P0360 Ignition Coil "J" Primary/Secondary Circuit Malfunction P0361 Ignition Coil "K" Primary/Secondary Circuit Malfunction P0362 Ignition Coil "L" Primary/Secondary Circuit Malfunction P0370 Timing Reference High Resolution Signal "A" Malfunction P0371 Timing Reference High Resolution Signal "A" Too Many Pulses P0372 Timing Reference High Resolution Signal "A" Too Few Pulses P0373 Timing Reference High Resolution Signal "A" Intermittent/Erratic Pulses P0374 Timing Reference High Resolution Signal "A" No Pulses P0375 Timing Reference High Resolution Signal "B" Malfunction P0376 Timing Reference High Resolution Signal "B" Too Many Pulses P0377 Timing Reference High Resolution Signal "B" Too Few Pulses P0378 Timing Reference High Resolution Signal "B" Intermittent/Erratic Pulses P0379 Timing Reference High Resolution Signal "B" No Pulses P0380 Glow Plug/Heater Circuit "A" Malfunction P0381 Glow Plug/Heater Indicator Circuit Malfunction P0382 Glow Plug/Heater Circuit "B" Malfunction P0385 Crankshaft Position Sensor "B" Circuit Malfunction P0386 Crankshaft Position Sensor "B" Circuit Range/Performance P0387 Crankshaft Position Sensor "B" Circuit Low Input P0388 Crankshaft Position Sensor "B" Circuit High Input P0389 Crankshaft Position Sensor "B" Circuit Intermittent P0400 Exhaust Gas Recirculation Flow Malfunction P0401 Exhaust Gas Recirculation Flow Insufficient Detected P0402 Exhaust Gas Recirculation Flow Excessive Detected P0403 Exhaust Gas Recirculation Circuit Malfunction P0404 Exhaust Gas Recirculation Circuit Range/Performance P0405 Exhaust Gas Recirculation Sensor "A" Circuit Low P0406 Exhaust Gas Recirculation Sensor "A" Circuit High P0407 Exhaust Gas Recirculation Sensor "B" Circuit Low P0408 Exhaust Gas Recirculation Sensor "B" Circuit High P0410 Secondary Air Injection System Malfunction P0411 Secondary Air Injection System Incorrect Flow Detected P0412 Secondary Air Injection System Switching Valve "A" Circuit Malfunction P0413 Secondary Air Injection System Switching Valve "A" Circuit Open P0414 Secondary Air Injection System Switching Valve "A" Circuit Shorted P0415 Secondary Air Injection System Switching Valve "B" Circuit Malfunction P0416 Secondary Air Injection System Switching Valve "B" Circuit Open P0417 Secondary Air Injection System Switching Valve "B" Circuit Shorted P0418 Secondary Air Injection System Relay "A" Circuit Malfunction P0419 Secondary Air Injection System Relay "B" Circuit Malfunction P0420 Catalyst System Efficiency Below Threshold (Bank #1) P0421 Warm Up Catalyst Efficiency Below Threshold (Bank #1) P0422 Main Catalyst Efficiency Below Threshold (Bank #1) P0423 Heated Catalyst Efficiency Below Threshold (Bank #1) P0424 Heated Catalyst Temperature Below Threshold (Bank #1) P0430 Catalyst System Efficiency Below Threshold (Bank #2) P0431 Warm Up Catalyst Efficiency Below Threshold (Bank #2) P0432 Main Catalyst Efficiency Below Threshold (Bank #2) P0433 Heated Catalyst Efficiency Below Threshold (Bank #2) P0434 Heated Catalyst Temperature Below Threshold (Bank #2) P0440 Evaporative Emission Control System Malfunction P0441 Evaporative Emission Control System Incorrect Purge Flow P0442 Evaporative Emission Control System Leak Detected (Small Leak) P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction P0444 Evaporative Emission Control System Purge Control Valve Circuit Open P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted P0446 Evaporative Emission Control System Vent Control Circuit Malfunction P0447 Evaporative Emission Control System Vent Control Circuit Open P0448 Evaporative Emission Control System Vent Control Circuit Shorted P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction P0450 Evaporative Emission Control System Pressure Sensor Malfunction P0451 Evaporative Emission Control System Pressure Sensor Range/Performance P0452 Evaporative Emission Control System Pressure Sensor Low Input P0453 Evaporative Emission Control System Pressure Sensor High Input P0454 Evaporative Emission Control System Pressure Sensor Intermittent P0455 Evaporative Emission Control System Leak Detected (Gross Leak) P0460 Fuel Level Sensor Circuit Malfunction P0461 Fuel Level Sensor Circuit Range/Performance P0462 Fuel Level Sensor Circuit Low Input P0463 Fuel Level Sensor Circuit High Input P0464 Fuel Level Sensor Circuit Intermittent P0465 Purge Flow Sensor Circuit Malfunction P0466 Purge Flow Sensor Circuit Range/Performance P0467 Purge Flow Sensor Circuit Low Input P0468 Purge Flow Sensor Circuit High Input P0469 Purge Flow Sensor Circuit Intermittent P0470 Exhaust Pressure Sensor Malfunction P0471 Exhaust Pressure Sensor Range/Performance P0472 Exhaust Pressure Sensor Low P0473 Exhaust Pressure Sensor High P0474 Exhaust Pressure Sensor Intermittent P0475 Exhaust Pressure Control Valve Malfunction P0476 Exhaust Pressure Control Valve Range/Performance P0477 Exhaust Pressure Control Valve Low P0478 Exhaust Pressure Control Valve High P0479 Exhaust Pressure Control Valve Intermittent P0480 Cooling Fan #1 Control Circuit Malfunction P0481 Cooling Fan #2 Control Circuit Malfunction P0482 Cooling Fan #3 Control Circuit Malfunction P0483 Cooling Fan Rationality Check Malfunction P0484 Cooling Fan Circuit Over Current P0485 Cooling Fan Power/Ground Circuit Malfunction P0500 Vehicle Speed Sensor Malfunction P0501 Vehicle Speed Sensor Range/Performance P0502 Vehicle Speed Sensor Circuit Low Input P0503 Vehicle Speed Sensor Intermittent/Erratic/High P0505 Idle Control System Malfunction P0506 Idle Control System RPM Lower Than Expected P0507 Idle Control System RPM Higher Than Expected P0510 Closed Throttle Position Switch Malfunction P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction P0521 Engine Oil Pressure Sensor/Switch Range/Performance P0522 Engine Oil Pressure Sensor/Switch Low Voltage P0523 Engine Oil Pressure Sensor/Switch High Voltage P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance P0532 A/C Refrigerant Pressure Sensor Circuit Low Input P0533 A/C Refrigerant Pressure Sensor Circuit High Input P0534 A/C Refrigerant Charge Loss P0550 Power Steering Pressure Sensor Circuit Malfunction P0551 Power Steering Pressure Sensor Circuit Range/Performance P0552 Power Steering Pressure Sensor Circuit Low Input P0553 Power Steering Pressure Sensor Circuit High Input P0554 Power Steering Pressure Sensor Circuit Intermittent P0560 System Voltage Malfunction P0561 System Voltage Unstable P0562 System Voltage Low P0563 System Voltage High P0565 CruiseControl On Signal Malfunction P0566 Cruise Control Off Signal Malfunction P0567 Cruise Control Resume Signal Malfunction P0568 Cruise Control Set Signal Malfunction P0569 Cruise Control Coast Signal Malfunction P0570 Cruise Control Accel Signal Malfunction P0571 Cruise Control/Brake Switch "A" Circuit Malfunction P0572 Cruise Control/Brake Switch "A" Circuit Low P0573 Cruise Control/Brake Switch "A" Circuit High P0574 Through P0580 Reserved for Cruise Codes P0600 Serial Communication Link Malfunction P0601 Internal Control Module Memory Check Sum Error P0602 Control Module Programming Error P0603 Internal Control Module Keep Alive Memory (KAM) Error P0604 Internal Control Module Random Access Memory (RAM) Error P0605 Internal Control Module Read Only Memory (ROM) Error P0606 PCM Processor Fault P0608 Control Module VSS Output "A" Malfunction P0609 Control Module VSS Output "B" Malfunction P0620 Generator Control Circuit Malfunction P0621 Generator Lamp "L" Control Circuit Malfunction P0622 Generator Field "F" Control Circuit Malfunction P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction P0654 Engine RPM Output Circuit Malfunction P0655 Engine Hot Lamp Output Control Circuit Malfunction P0656 Fuel Level Output Circuit Malfunction P0700 Transmission Control System Malfunction P0701 Transmission Control System Range/Performance P0702 Transmission Control System Electrical P0703 Torque Converter/Brake Switch "B" Circuit Malfunction P0704 Clutch Switch Input Circuit Malfunction P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input) P0706 Transmission Range Sensor Circuit Range/Performance P0707 Transmission Range Sensor Circuit Low Input P0708 Transmission Range Sensor Circuit High Input P0709 Transmission Range Sensor Circuit Intermittent P0710 TransmissionFluid Temperature Sensor Circuit Malfunction P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance P0712 Transmission Fluid Temperature Sensor Circuit Low Input P0713 Transmission Fluid Temperature Sensor Circuit High Input P0714 Transmission Fluid Temperature Sensor Circuit Intermittent P0715 Input/Turbine Speed Sensor Circuit Malfunction P0716 Input/Turbine Speed Sensor Circuit Range/Performance P0717 Input/Turbine Speed Sensor Circuit No Signal P0718 Input/Turbine Speed Sensor Circuit Intermittent P0719 Torque Converter/Brake Switch "B" Circuit Low P0720 Output Speed Sensor Circuit Malfunction P0721 Output Speed Sensor Circuit Range/Performance P0722 Output Speed Sensor Circuit No Signal P0723 Output Speed Sensor Circuit Intermittent P0724 Torque Converter/Brake Switch "B" Circuit High P0725 Engine Speed Input Circuit Malfunction P0726 Engine Speed Input Circuit Range/Performance P0727 Engine Speed Input Circuit No Signal P0728 Engine Speed Input Circuit Intermittent P0730 Incorrect Gear Ratio P0731 Gear #1 Incorrect Ratio P0732 Gear #2 Incorrect Ratio P0733 Gear #3 Incorrect Ratio P0734 Gear #4 Incorrect Ratio P0735 Gear #5 Incorrect Ratio P0736 Reverse Incorrect Ratio P0740 Torque Converter Clutch Circuit Malfunction P0741 Torque Converter Clutch Circuit Performance or Stuck Off P0742 Torque Converter Clutch Circuit Stuck On P0743 Torque Converter Clutch Circuit Electrical P0744 Torque Converter Clutch Circuit Intermittent P0745 Pressure Control Solenoid Malfunction P0746 Pressure Control Solenoid Performance or Stuck Off P0747 Pressure Control Solenoid Stuck On P0748 Pressure Control Solenoid Electrical P0749 Pressure Control Solenoid Intermittent P0750 Shift Solenoid "A" Malfunction P0751 Shift Solenoid "A" Performance or Stuck Off P0752 Shift Solenoid "A" Stuck On P0753 Shift Solenoid "A" Electrical P0754 Shift Solenoid "A" Intermittent P0755 Shift Solenoid "B" Malfunction P0756 Shift Solenoid "B" Performance or Stuck Off P0757 Shift Solenoid "B" Stuck On P0758 Shift Solenoid "B" Electrical P0759 Shift Solenoid "B" Intermittent P0760 Shift Solenoid "C" Malfunction P0761 Shift Solenoid "C" Performance Or Stuck Off P0762 Shift Solenoid "C" Stuck On P0763 Shift Solenoid "C" Electrical P0764 Shift Solenoid "C" Intermittent P0765 Shift Solenoid "D" Malfunction P0766 Shift Solenoid "D" Performance Or Stuck Off P0767 Shift Solenoid "D" Stuck On P0768 Shift Solenoid "D" Electrical P0769 Shift Solenoid "D" Intermittent P0770 Shift Solenoid "E" Malfunction P0771 Shift Solenoid "E" Performance Or Stuck Off P0772 Shift Solenoid "E" Stuck On P0773 Shift Solenoid "E" Electrical P0774 Shift Solenoid "E" Intermittent P0780 Shift Malfunction P0781 1–2 Shift Malfunction P0782 2–3 Shift Malfunction P0783 3–4 Shift Malfunction P0784 4–5 Shift Malfunction P0785 Shift/Timing Solenoid Malfunction P0786 Shift/Timing Solenoid Range/Performance P0787 Shift/Timing Solenoid Low P0788 Shift/Timing Solenoid High P0789 Shift/Timing Solenoid Intermittent P0790 Normal/Performance Switch Circuit Malfunction P0801 Reverse Inhibit Control Circuit Malfunction P0803 1–4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction P0804 1–4 Upshift (Skip Shift) Lamp Control Circuit Malfunction P1100 Barometric Pressure Sensor Circuit Fault P1120 Accelerator Pedal Position Sensor Circuit Malfunction P1121 Accelerator Pedal Position Sensor Range/Performance Problem P1125 Throttle Control Motor Circuit Malfunction P1126 Magnetic Clutch Circuit Malfunction P1127 ETCS Actuator Power Source Circuit Malfunction P1128 Throttle Control Motor Lock Malfunction P1129 Electric Throttle Control System Malfunction P1130 A/F Sensor Circuit Range / Performance Malfunction (Bank #1 Sensor #1) P1133 A/F Sensor Circuit Response Malfunction (Bank #1 Sensor #1) P1135 A/F Sensor Heater Circuit Malfunction (Bank #1 Sensor #1) P1150 A/F Sensor Circuit Range / Performance Malfunction (Bank #2 Sensor #1) P1153 A/F Sensor Circuit Response Malfunction (Bank #2 Sensor #1) P1155 A/F Sensor Heater Circuit Malfunction (Bank #2 Sensor #1) P1200 Fuel Pump Relay Circuit Fault P1300 Igniter Circuit Fault (Bank #1) P1305 Igniter Circuit Fault (Bank #2) P1310 Igniter Circuit Fault (Bank #3) P1315 Igniter Circuit Fault (Bank #4) P1320 Igniter Circuit Fault (Bank #5) P1325 Igniter Circuit Fault (Bank #6) P1330 Igniter Circuit Fault (Bank #7) P1335 Crankshaft Position Sensor Circuit Fault (during engine running) P1340 Igniter Circuit Fault (Bank #8) P1400 Sub-Throttle Position Sensor Circuit Fault P1401 Sub-Throttle Position Sensor Performance P1500 Starter Signal Circuit Fault P1510 Air Volume Too Low With Supercharger On P1520 Stop Light Switch Signal Malfunction P1600 ECM Battery Back-up Circuit Fault P1633 ECM Malfunction (ETCS Circuit) P1605 Knock Control CPU Fault P1700 Vehicle Speed Sensor Circuit Fault P1705 Direct Clutch Speed Sensor Circuit Fault P1765 Linear Shift Solenoid Circuit Fault P1780 Park Neutral Position Switch Fault __________________ |
Re: Complete list OBDII codes
P0xxx codes are "generic" and required to be generated per OBD II standards. The P1xxx codes are specific to a maker (in this case, Toyota) AND to a specific car. That is the reason that list does not have the P1420 series codes from a Camry Hybrid
OK, for purists:
here are ALL possible codes, specific and non specific. What we gonna do without Motherhttp: //alflash.com.ua/OBDII/DTCe1.pdf Russia... |
And all Hybrid Camry specific codes:
(once again, thank you, Mother Russia) AIR BAG RESTRAINT DTCS HYBRID DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION DTC Description B1000 Center Airbag Sensor Assembly Malfunction B1603 Front Satellite Sensor Bus RH Initialization Incomplete B1608 Front Satellite Sensor Bus LH Initialization Incomplete B1610 Front Airbag Sensor RH Malfunction B1612 Lost Communication with Front Airbag Sensor RH B1613 Front Airbag Sensor RH Initialization Incomplete B1615 Front Airbag Sensor LH Malfunction B1617 Lost Communication with Front Airbag Sensor LH B1618 Front Airbag Sensor LH Initialization Incomplete B1620 Driver Side - Side Airbag Sensor Malfunction B1622 Lost Communication with Driver Side -Side Airbag Sensor Assembly B1623 Driver Side - Side Airbag Sensor Assembly Initialization Incomplete B1625 Front Passenger Side - Side Airbag Sensor Malfunction B1627 Lost Communication with Front Passenger Side - Side Airbag Sensor Assembly B1628 Front Passenger Side - Side Airbag Sensor Assembly Initialization Incomplete B1630 Driver Side Rear Airbag Sensor Malfunction B1632 Lost Communication with Driver Side Rear Airbag Sensor B1633 Driver Side Rear Airbag Sensor Initialization Incomplete B1635 Front Passenger Side Rear Airbag Sensor Malfunction B1637 Lost Communication with Passenger Side Rear Airbag Sensor B1638 Passenger Side Rear Airbag Sensor Initialization Incomplete B1642 Lost Communication with Driver Side Satellite Sensor Bus B1643 Driver Side Satellite Sensor Bus Initialization Incomplete B1647 Lost Communication with Front Passenger Side Satellite Sensor Bus B1648 Front Passenger Side Satellite Sensor Bus Initialization Incomplete B1650 Occupant Classification System Malfunction B1653 Seat Position Airbag Sensor Circuit Malfunction B1655 Driver Side Seat Belt Buckle Switch Circuit Malfunction B1660 Passenger Airbag ON/OFF Indicator Circuit Malfunction B1771 Passenger Side Buckle Switch Circuit Malfunction B1780 Front Occupant Classification Sensor LH Circuit Malfunction B1781 Front Occupant Classification Sensor RH Circuit Malfunction B1782 Rear Occupant Classification Sensor LH Circuit Malfunction B1783 Rear Occupant Classification Sensor RH Circuit Malfunction B1785 Front Occupant Classification Sensor LH Collision Detection B1786 Front Occupant Classification Sensor RH Collision Detection B1787 Rear Occupant Classification Sensor LH Collision Detection B1788 Rear Occupant Classification Sensor RH Collision Detection B1790 Center Airbag Sensor Assembly Communication Circuit Malfunction B1793 Occupant Classification Sensor Power Supply Circuit Malfunction B1794 Open in Occupant Classification ECU Battery Positive Line B1795 Occupant Classification ECU Malfunction B1796 Sleep Operation Failure of Occupant Classification ECU B1800 Short in Driver Side Squib Circuit B1801 Open in Driver Side Squib Circuit B1802 Short to GND in Driver Side Squib Circuit B1803 Short to B+ in Driver Side Squib Circuit B1805 Short in Front Passenger Side Squib Circuit B1806 Open in Front Passenger Side Squib Circuit B1807 Short to GND in Front Passenger Side Squib Circuit B1808 Short to B+ in Front Passenger Side Squib Circuit B1810 Short in Driver Side Squib 2nd Step Circuit B1811 Open in Driver Side Squib 2nd Step Circuit B1812 Short to GND in Driver Side Squib 2nd Step Circuit B1813 Short to B+ in Driver Side Squib 2nd Step Circuit B1815 Short in Front Passenger Side Squib 2nd Step Circuit B1816 Open in Front Passenger Side Squib 2nd Step Circuit B1817 Short to GND in Front Passenger Side Squib 2nd Step Circuit B1818 Short to B+ in Front Passenger Side Squib 2nd Step Circuit B1820 Short in Front Driver Side - Side Squib Circuit B1821 Open in Front Driver Side - Side Squib Circuit B1822 Short to GND in Front Driver Side - Side Squib Circuit B1823 Short to B+ in Front Driver Side - Side Squib Circuit B1825 Short in Front Passenger Side - Side Squib Circuit B1826 Open in Front Passenger Side - Side Squib Circuit B1827 Short to GND in Front Passenger Side -Side Squib Circuit B1828 Short to B+ in Front Passenger Side - Side Squib Circuit B1830 Short in Driver Side Curtain Shield Squib Circuit B1831 Open in Driver Side Curtain Shield Squib Circuit B1832 Short to GND in Driver Side Curtain Shield Squib Circuit B1833 Short to B+ in Driver Side Curtain Shield Squib Circuit B1835 Short in Front Passenger Side Curtain Shield Squib Circuit B1836 Open in Front Passenger Side Curtain Shield Squib Circuit B1837 Short to GND in Front Passenger Side Curtain Shield Squib Circuit B1838 Short to B+ in Front Passenger Side Curtain Shield Squib Circuit B1860 Short in Driver Side Knee Airbag Squib Circuit B1861 Open in Driver Side Knee Airbag Squib Circuit B1862 Short to GND in Driver Side Knee Airbag Squib Circuit B1863 Short to B+ in Driver Side Knee Airbag Squib Circuit B1900 Short in Front Driver Side Pretensioner Squib Circuit B1901 Open in Front Driver Side Pretensioner Squib Circuit B1902 Short to GND in Front Driver Side Pretensioner Squib Circuit B1903 Short to B+ in Front Driver Side Pretensioner Squib Circuit B1905 Short in Front Passenger Side Pretensioner Squib Circuit B1906 Open in Front Passenger Side Pretensioner Squib Circuit B1907 Short to GND in Front Passenger Side Pretensioner Squib Circuit B1908 Short to B+ in Front Passenger Side Pretensioner Squib Circuit ANTI-LOCK BRAKE DTCS HYBRID DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION DTC Description C0200 Front Speed Sensor RH Circuit C0205 Front Speed Sensor LH Circuit C0210 Rear Speed Sensor RH Circuit C0215 Rear Speed Sensor LH Circuit C0371 Yaw Rate Sensor (Test Mode DTC) C1202 Master Reservoir Level Malfunction C1203 ECM Communication Circuit Malfunction C1210 Zero Point Calibration of Yaw Rate Sensor Undone C1231 Steering Angle Sensor Circuit Malfunction C1234 Yaw Rate Sensor Malfunction C1235 Foreign Object is Attached on Tip of Front Speed Sensor RH C1236 Foreign Object is Attached on Tip of Front Speed Sensor LH C1238 Foreign Object is Attached on Tip of Rear Speed Sensor RH C1239 Foreign Object is Attached on Tip of Rear Speed Sensor LH C1241 Low Battery Positive Voltage C1242 Open in IG1/IG2 Power Source Circuit C1243 Acceleration Sensor Stuck Malfunction C1244 Open or Short in Acceleration Sensor Circuit C1245 Acceleration Sensor Output Malfunction C1246 Master Cylinder Pressure Sensor Malfunction C1247 Stroke Sensor Malfunction C1249 Open in Stop Light Switch Circuit C1252 Brake Booster Pump Motor on Time Abnormally Long C1253 Pump Motor Relay Malfunction C1256 Accumulator Low Pressure C1259 HV System Regenerative Malfunction C1271 Low Output Signal of Front Speed Sensor RH (Test Mode DTC) C1272 Low Output Signal of Front Speed Sensor LH (Test Mode DTC) C1273 Low Output Signal of Rear Speed Sensor RH (Test Mode DTC) C1274 Low Output Signal of Rear Speed Sensor LH (Test Mode DTC) C1275 Abnormal Change in Output Signal of Front Speed Sensor RH (Test Mode DTC) C1276 Abnormal Change in Output Signal of Front Speed Sensor LH (Test Mode DTC) C1277 Abnormal Change in Output Signal of Rear Speed Sensor RH (Test Mode DTC) C1278 Abnormal Change in Output Signal of Rear Speed Sensor LH (Test Mode DTC) C1279 Acceleration Sensor Output Voltage Malfunction (Test Mode DTC) C1281 Master Cylinder Pressure Sensor Output Malfunction (Test Mode DTC) C1290 Steering Angle Sensor Zero Point Malfunction C1300 Skid Control ECU Malfunction C1304 EPS Control System Malfunction C1310 Malfunction in HV system C1311 Open in Main Relay 1 Circuit C1312 Short in Main Relay 1 Circuit C1313 Open in Main Relay 2 Circuit C1314 Short in Main Relay 2 Circuit C1315 SMC1 Changeover Solenoid Malfunction C1316 SMC2 Changeover Solenoid Malfunction C1319 SCSS Changeover Solenoid Malfunction C1336 Zero Point Calibration of Acceleration Sensor Undone C1341 Front Hydraulic System RH Malfunction C1342 Front Hydraulic System LH Malfunction C1343 Rear Hydraulic System RH Malfunction C1344 Rear Hydraulic System LH Malfunction C1345 Linear Solenoid Valve Offset Learning Undone C1346 Stroke Sensor Zero Point Learning Malfunction (Test Mode DTC) C1352 Front Increasing Pressure Solenoid RH Malfunction C1353 Front Increasing Pressure Solenoid LH Malfunction C1354 Rear Increasing Pressure Solenoid RH Malfunction C1355 Rear Increasing Pressure Solenoid LH Malfunction C1356 Front Decreasing Pressure Solenoid RH Malfunction C1357 Front Decreasing Pressure Solenoid LH Malfunction C1358 Rear Decreasing Pressure Solenoid RH Malfunction C1359 Rear Decreasing Pressure Solenoid LH Malfunction C1364 Wheel Cylinder Pressure Sensor Malfunction C1365 Accumulator Pressure Sensor Malfunction C1368 Linear Solenoid Valve Offset Malfunction C1377 Capacitor Malfunction C1378 Capacitor Communication Malfunction C1381 Yaw Rate and/or Acceleration Sensor Power Supply Voltage Malfunction C1391 Accumulator Leak Malfunction C1392 Stroke Sensor Zero Point Calibration Undone U0073 Control Module Communication Bus OFF U0123 Lost Communication with Yaw Rate Sensor Module U0124 Lost Communication with Lateral Acceleration Sensor Module U0126 Lost Communication with Steering Angle Sensor Module U0131 Lost Communication with Power Steering Control Module U0293 Communication Error from HV ECU AUTOMATIC TRANSMISSION DTCS U250E DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION DTC Description P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input) P0710 Transmission Fluid Temperature Sensor "A" Circuit P0711 Transmission Fluid Temperature Sensor "A" Performance P0712 Transmission Fluid Temperature Sensor "A" Circuit Low Input P0713 Transmission Fluid Temperature Sensor "A" Circuit High Input P0717 Turbine Speed Sensor Circuit No Signal P0724 Brake Switch "B" Circuit High P0741 Torque Converter Clutch Solenoid Performance (Shift Solenoid Valve DSL) P0746 Pressure Control Solenoid "A" Performance (Shift Solenoid Valve SL1) P0748 Pressure Control Solenoid "A" Electrical (Shift Solenoid Valve SL1) P0766 Shift Solenoid "D" Performance (Shift Solenoid Valve S4) P0771 Shift Solenoid "E" Performance (Shift Solenoid Valve SR) P0776 Pressure Control Solenoid "B" Performance (Shift Solenoid Valve SL2) P0778 Pressure Control Solenoid "B" Electrical (Shift Solenoid Valve SL2) P0793 Intermediate Shaft Speed Sensor "A" P0796 Pressure Control Solenoid "C" Performance (Shift Solenoid Valve SL3) P0798 Pressure Control Solenoid "C" Electrical (Shift Solenoid Valve SL3) P0982 Shift Solenoid "D" Control Circuit Low (Shift Solenoid Valve S4) P0983 Shift Solenoid "D" Control Circuit High (Shift Solenoid Valve S4) P0985 Shift Solenoid "E" Control Circuit Low (Shift Solenoid Valve SR) P0986 Shift Solenoid "E" Control Circuit High (Shift Solenoid Valve SR) P2714 Pressure Control Solenoid "D" Performance (Shift Solenoid Valve SLT) P2716 Pressure Control Solenoid "D" Electrical (Shift Solenoid Valve SLT) P2769 Torque Converter Clutch Solenoid Circuit Low (Shift Solenoid Valve DSL) P2770 Torque Converter Clutch Solenoid Circuit High (Shift Solenoid Valve DSL) U660E DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION DTC Description P0500 Vehicle Speed Sensor "A" P0560 System Voltage P0617 Starter Relay Circuit High P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input) P0710 Transmission Fluid Temperature Sensor "A" Circuit P0711 Transmission Fluid Temperature Sensor "A" Performance P0712 Transmission Fluid Temperature Sensor "A" Circuit Low Input P0713 Transmission Fluid Temperature Sensor "A" Circuit High Input P0715 Input / Turbine Speed Sensor Circuit Malfunction P0717 Input Speed Sensor Circuit No Signal P0724 Brake Switch "B" Circuit High P0741 Torque Converter Clutch Solenoid Performance (Shift Solenoid Valve SL) P0746 Pressure Control Solenoid "A" Performance (Shift Solenoid Valve SL1) P0748 Pressure Control Solenoid "A" Electrical (Shift Solenoid Valve SL1) P0776 Pressure Control Solenoid "B" Performance (Shift Solenoid Valve SL2) P0778 Pressure Control Solenoid "B" Electrical (Shift Solenoid Valve SL2) P0791 Intermediate Shaft Speed Sensor "A" Circuit P0793 Intermediate Shaft Speed Sensor "A" P0796 Pressure Control Solenoid "C" Performance (Shift Solenoid Valve SL3) P0798 Pressure Control Solenoid "C" Electrical (Shift Solenoid Valve SL3) P0872 Transmission Fluid Pressure Switch No.1 Circuit Low P0873 Transmission Fluid Pressure Switch No.1 Circuit High P0877 Transmission Fluid Pressure Switch No.2 Circuit Low P0878 Transmission Fluid Pressure Switch No.2 Circuit High P0989 Transmission Fluid Pressure Switch No.3 Circuit Low P0990 Transmission Fluid Pressure Switch No.3 Circuit High P2714 Pressure Control Solenoid "D" Performance (Shift Solenoid Valve SLT) P2716 Pressure Control Solenoid "D" Electrical (Shift Solenoid Valve SLT) P2757 Torque Converter Clutch Pressure Control Solenoid Performance (Shift Solenoid Valve SLU) P2759 Torque Converter Clutch Pressure Control Solenoid Control Circuit Electrical (Shift Solenoid Valve SLU) P2769 Short in Torque Converter Clutch Solenoid Circuit (Shift Solenoid Valve SL) P2808 Pressure Control Solenoid "G" Performance or Stuck OFF (Shift Solenoid Valve SL4) P2770 Open in Torque Converter Clutch Solenoid Circuit (Shift Solenoid Valve SL) P2810 Pressure Control Solenoid "G" Electrical (Shift Solenoid Valve SL4) U0100 Lost Communication with ECM/PCM "A" CAN COMMUNICATION DTCS HYBRID DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION DTC Description B1207 Certification ECU Communication Malfunction B1247 Tire Pressure Monitor Receiver Communication Stop B2326 CAN MS Bus Line Communication Malfunction CRUISE CONTROL DTCS HYBRID DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION DTC Description P0500 Vehicle Speed Sensor Malfunction P0571 Brake Switch "A" Circuit P0607 Control Module Performance DOOR LOCK DTCS HYBRID DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION DTC Description B1242 Wireless Door Lock Tuner Circuit Malfunction ENGINE IMMOBILIZER DTCS (A00287573) W/ SMART KEY SYSTEM W/ SMART KEY SYSTEM DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION DTC Description B2784 Antenna Coil Open/Short B2785 Communication Malfunction between ECUs Connected by LIN B2786 No Response from Steering Lock ECU B2789 No Response from ID BOX B278A Short to GND in Immobilizer System Power Source Circuit B2790 ID BOX EEPROM Malfunction B2791 Communication Condition Failure between ECM B2799 Engine Immobilizer System W/O SMART KEY SYSTEM W/O SMART KEY SYSTEM DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION DTC Description B2780 Push Switch/Key Unlock Warning Switch Malfunction B2784 Antenna Coil Open/Short B2793 Transponder Chip Malfunction B2794 Unmatched Encryption Code B2795 Unmatched Key Code B2796 No Communication in Immobilizer System B2797 Communication Malfunction No. 1 B2798 Communication Malfunction No. 2 B2799 Engine Immobilizer System ENGINE IMMOBILIZER (HYBRID) DTCS (A00304747) ENGINE IMMOBILIZER (HYBRID) DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION DTC Description B2784 Antenna Coil Open/Short B2785 Communication Malfunction between ECUs Connected by LIN B2786 No Response from Steering Lock ECU B2789 No Response from ID BOX B278A Short to GND in Immobilizer System Power Source Circuit B2790 ID BOX EEPROM Malfunction B2791 Communication Condition Failure between ECM B2799 Engine Immobilizer System Malfunction ENGINE PERFORMANCE DTCS HYBRID DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION DTC Description P0010 Camshaft Position "A" Actuator Circuit (Bank 1) P0011 Camshaft Position "A" - Timing Over - Advanced or System Performance (Bank 1) P0012 Camshaft Position "A" - Timing Over-Retarded (Bank 1) P0016 Crankshaft Position -Camshaft Position Correlation (Bank 1 Sensor A) P0031 Oxygen (A/F) Sensor Heater Control Circuit Low (Bank 1 Sensor 1) P0032 Oxygen (A/F) Sensor Heater Control Circuit High (Bank 1 Sensor 1) P0037 Oxygen Sensor Heater Control Circuit Low (Bank 1 Sensor 2) P0038 Oxygen Sensor Heater Control Circuit High (Bank 1 Sensor 2) P0100 Mass or Volume Air Flow Circuit P0101 Mass Air Flow Circuit Range / Performance Problem P0102 Mass or Volume Air Flow Circuit Low Input P0103 Mass or Volume Air Flow Circuit High Input P0110 Intake Air Temperature Circuit Malfunction P0111 Intake Air Temperature Sensor Gradient Too High P0112 Intake Air Temperature Circuit Low Input P0113 Intake Air Temperature Circuit High Input P0115 Engine Coolant Temperature Circuit Malfunction P0116 Engine Coolant Temperature Circuit Range / Performance Problem P0117 Engine Coolant Temperature Circuit Low Input P0118 Engine Coolant Temperature Circuit High Input P0120 Throttle / Pedal Position Sensor / Switch "A" Circuit Malfunction P0121 Throttle / Pedal Position Sensor / Switch "A" Circuit Range / Performance Problem P0122 Throttle / Pedal Position Sensor / Switch "A" Circuit Low Input P0123 Throttle / Pedal Position Sensor / Switch "A" Circuit High Input P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature) P0136 Oxygen Sensor Circuit Malfunction (Bank 1 Sensor 2) P0137 Oxygen Sensor Circuit Low Voltage (Bank 1 Sensor 2) P0138 Oxygen Sensor Circuit High Voltage (Bank 1 Sensor 2) P0139 Oxygen Sensor Circuit Slow Response(Bank 1 Sensor 2) P0141 Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) P0171 System Too Lean (Bank 1) P0172 System Too Rich (Bank 1) P0220 Throttle / Pedal Position Sensor / Switch "B" Circuit P0222 Throttle / Pedal Position Sensor / Switch "B" Circuit Low Input P0223 Throttle / Pedal Position Sensor / Switch "B" Circuit High Input P0300 Random / Multiple Cylinder Misfire Detected P0301 Cylinder 1 Misfire Detected P0302 Cylinder 2 Misfire Detected P0303 Cylinder 3 Misfire Detected P0304 Cylinder 4 Misfire Detected P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor) P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor) P0335 Crankshaft Position Sensor "A" Circuit P0340 Camshaft Position Sensor "A" Circuit (Bank 1 or Single Sensor) P0351 Ignition Coil "A" Primary / Secondary Circuit P0352 Ignition Coil "B" Primary / Secondary Circuit P0353 Ignition Coil "C" Primary / Secondary Circuit P0354 Ignition Coil "D" Primary / Secondary Circuit P0420 Catalyst System Efficiency Below Threshold (Bank 1) P043E Evaporative Emission System Reference Orifice Clog Up P043F Evaporative Emission System Reference Orifice High Flow P0441 Evaporative Emission Control System Incorrect Purge Flow P0450 Evaporative Emission Control System Pressure Sensor / Switch P0451 Evaporative Emission Control System Pressure Sensor Range / Performance P0452 Evaporative Emission Control System Pressure Sensor/ Switch Low Input P0453 Evaporative Emission Control System Pressure Sensor / Switch High Input P0505 Idle Control System Malfunction P050A Cold Start Idle Air Control System Performance P0560 System Voltage P0604 Internal Control Module Random Access Memory (RAM) Error P0606 ECM/PCM Processor P0607 Control Module Performance P0657 Actuator Supply Voltage Circuit / Open P1420 Evaporative Emission Canister Small Leak P1421 Evaporative Emission Canister Gross Leak P1422 Fuel Tank Small Leak P1423 Fuel Tank Gross Leak P1451 Fuel Tank Pressure Sensor Range/ Performance P1452 Fuel Tank Pressure Sensor Low Input P1453 Fuel Tank Pressure Sensor High Input P2102 Throttle Actuator Control Motor Circuit Low P2103 Throttle Actuator Control Motor Circuit High P2111 Throttle Actuator Control System -Stuck Open P2112 Throttle Actuator Control System -Stuck Closed P2118 Throttle Actuator Control Motor Current Range / Performance P2119 Throttle Actuator Control Throttle Body Range / Performance P2135 Throttle / Pedal Position Sensor / Switch "A" / "B" Voltage Correlation P2195 Oxygen (A/F) Sensor Signal Stuck Lean (Bank 1 Sensor 1) P2196 Oxygen (A/F) Sensor Signal Stuck Rich (Bank 1 Sensor 1) P2237 Oxygen (A/F) Sensor Pumping Current Circuit / Open (Bank 1 Sensor 1) P2238 Oxygen (A/F) Sensor Pumping Current Circuit Low (Bank 1 Sensor 1) P2239 Oxygen (A/F) Sensor Pumping Current Circuit High (Bank 1 Sensor 1) P2252 Oxygen (A/F) Sensor Reference Ground Circuit Low (Bank 1 Sensor 1) P2253 Oxygen (A/F) Sensor Reference Ground Circuit High (Bank 1 Sensor 1) P2401 Evaporative Emission Leak Detection Pump Stuck OFF P2402 Evaporative Emission Leak Detection Pump Stuck ON P2419 Evaporative Emission System Switching Valve Control Circuit Low P2420 Evaporative Emission System Switching Valve Control Circuit High P2450 Fuel Vapor-containment Valve Stuck Open P2451 Fuel Vapor-containment Valve Stuck Close P2610 ECM / PCM Internal Engine Off Timer Performance P2A00 A/F Sensor Circuit Slow Response (Bank 1 Sensor 1) P3190 Poor Engine Power P3191 Engine does not Start P3193 Fuel Run Out U0001 High Speed CAN Communication Circuit U0293 Lost Communication with HV ECU HVAC (HYBRID) DTCS (A00304768) HVAC (HYBRID) DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION DTC Description B1411 Room Temperature Sensor Circuit B1412 Ambient Temperature Sensor Circuit B1413 Evaporator Temperature Sensor Circuit B1421 Solar Sensor Circuit (Passenger Side) B1423 Pressure Sensor Circuit B1424 Solar Sensor Circuit (Driver Side) B1441 Air Mix Damper Control Servo Motor Circuit (Passenger Side) B1442 Air Inlet Damper Control Servo Motor Circuit B1443 Air Outlet Damper Control Servo Motor Circuit B1446 Air Mix Damper Control Servo Motor Circuit (Driver Side) B1471 A/C Inverter High Voltage Power Resource System Malfunction B1472 A/C Inverter High Voltage Output System Malfunction B1473 A/C Inverter Start-up Signal System Malfunction B1474 A/C Inverter Malfunction B1475 A/C Inverter Cooling / Heating System Malfunction B1476 A/C Inverter Load System Malfunction B1477 A/C Inverter Low Voltage Power Resource System Malfunction B1497 BUS IC Communication Malfunction B1498 Communication Malfunction (A/C Inverter Local) B1499 Multiplex Communication Circuit P0AA6 Hybrid Battery Voltage System Isolation Fault |
Had to cut it in two pieces:
HYBRID BATTERY CONTROL DTCS (A00304769) HYBRID BATTERY CONTROL DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION DTC Description P0A1F Battery Energy Control Module P0A7F Hybrid Battery Pack Deterioration P0A80 Replace Hybrid Battery Pack P0A82 Hybrid Battery Pack Cooling Fan 1 P0A84 Hybrid Battery Pack Cooling Fan 1 P0A85 Hybrid Battery Pack Cooling Fan 1 P0A95 High Voltage Fuse P0A9C Hybrid Battery Temperature Sensor "A" P0A9D Hybrid Battery Temperature Sensor "A" Circuit Low P0A9E Hybrid Battery Temperature Sensor "A" Circuit High P0AAC Hybrid Battery Pack Air Temperature Sensor "A" Circuit P0ABF Hybrid Battery Pack Current Sensor Circuit P0AC0 Hybrid Battery Pack Current Sensor Circuit Range/Performance P0AC1 Hybrid Battery Pack Current Sensor Circuit Low P0AC2 Hybrid Battery Pack Current Sensor Circuit High P0AFA Hybrid Battery System Voltage Low P3011 Battery Block 1 Becomes Weak P3012 Battery Block 2 Becomes Weak P3013 Battery Block 3 Becomes Weak P3014 Battery Block 4 Becomes Weak P3015 Battery Block 5 Becomes Weak P3016 Battery Block 6 Becomes Weak P3017 Battery Block 7 Becomes Weak P3018 Battery Block 8 Becomes Weak P3019 Battery Block 9 Becomes Weak P3020 Battery Block 10 Becomes Weak P3021 Battery Block 11 Becomes Weak P3022 Battery Block 12 Becomes Weak P3023 Battery Block 13 Becomes Weak P3024 Battery Block 14 Becomes Weak P3025 Battery Block 15 Becomes Weak P3026 Battery Block 16 Becomes Weak P3027 Battery Block 17 Becomes Weak U029A Lost Communication with Hybrid Battery Pack Sensor module LIGHTING DTCS HYBRID DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION DTC Description B1244 Light Sensor Circuit Malfunction METER DTCS HYBRID DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION DTC Description U0100 Lost Communication with ECM/PCM "A" U0129 Lost Communication with Skid Control ECU P311 HYBRID VEHICLE CONTROL DTCS (A00304757) P311 HYBRID VEHICLE CONTROL DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION DTC Description P0343 Camshaft Position Sensor "A" Circuit High Input P0516 Battery Temperature Sensor Circuit Low P0517 Battery Temperature Sensor Circuit High P0560 System Voltage P0617 Starter Relay Circuit High P062F EEPROM Malfunction P0630 VIN not Programmed or Mismatch - ECM/PCM P0705 Transmission Range Sensor Circuit P0851 Park/Neutral Switch Input Circuit Low P0A01 Motor Electronics Coolant Temperature Sensor Circuit Range/Performance P0A02 Motor Electronics Coolant Temperature Sensor Circuit Low P0A03 Motor Electronics Coolant Temperature Sensor Circuit High P0A08 DC/DC Converter Status Circuit P0A09 DC/DC Converter Status Circuit Low Input P0A0D High Voltage System Inter-Lock Circuit High P0A0F Engine Failed to Start P0A10 DC/DC Converter Status Circuit High Input P0A1A Generator Control Module P0A1B Drive Motor "A" Control Module P0A1D Hybrid Powertrain Control Module P0A1F Battery Energy Control Module P0A2B Drive Motor "A" Temperature Sensor Circuit Range/Performance P0A2C Drive Motor "A" Temperature Sensor Circuit Low P0A2D Drive Motor "A" Temperature Sensor Circuit High P0A37 Generator Temperature Sensor Circuit Range/Performance P0A38 Generator Temperature Sensor Circuit Low P0A39 Generator Temperature Sensor Circuit High P0A3F Drive Motor "A" Position Sensor Circuit P0A40 Drive Motor "A" Position Sensor Circuit Range/Performance P0A41 Drive Motor "A" Position Sensor Circuit Low P0A4B Generator Position Sensor Circuit P0A4C Generator Position Sensor Circuit Range/Performance P0A4D Generator Position Sensor Circuit Low P0A51 Drive Motor "A" Current Sensor Circuit P0A60 Drive Motor "A" Phase V Current P0A63 Drive Motor "A" Phase W Current P0A72 Generator Phase V Current P0A75 Generator Phase W Current P0A78 Drive Motor "A" Inverter Performance P0A7A Generator Inverter Performance P0A90 Drive Motor "A" Performance P0A92 Hybrid Generator Performance P0A93 Inverter Cooling System Performance P0A94 DC/DC Converter Performance P0AA1 Hybrid Battery Positive Contractor Circuit Stuck Closed P0AA4 Hybrid Battery Negative Contractor Circuit Stuck Closed P0AA6 Hybrid Battery Voltage System Isolation Fault P0AC0 Hybrid Battery Pack Current Sensor Circuit Range/Performance P0AA7 Hybrid Battery Voltage Isolation Sensor Circuit P0ADB Hybrid Battery Positive Contractor Control Circuit Low P0ADC Hybrid Battery Positive Contractor Control Circuit High P0ADF Hybrid Battery Negative Contractor Control Circuit Low P0AE0 Hybrid Battery Negative Contractor Control Circuit High P0AE2 Hybrid Battery Precharge Contractor Circuit Stuck Closed P0AE6 Hybrid Battery Precharge Contractor Control Circuit Low P0AE7 Hybrid Battery Precharge Contractor Control Circuit High P0AEE Motor Inverter Temperature Sensor "A" Circuit Range/Performance P0AEF Drive Motor Inverter Temperature Sensor "A" Circuit Low P0AF0 Drive Motor Inverter Temperature Sensor "A" Circuit High P1555 Reactor Temperature Sensor Circuit Low P1556 Reactor Temperature Sensor Circuit High P1606 Collision Detection P2120 Throttle/Pedal Position Sensor/Switch "D" Circuit P2121 Throttle/Pedal Position Sensor/Switch "D" Circuit Range/Performance P2122 Throttle/Pedal Position Sensor/Switch "D" Circuit Low Input P2123 Throttle/Pedal Position Sensor/Switch "D" Circuit High Input P2125 Throttle/Pedal Position Sensor/Switch "E" Circuit P2126 Throttle/Pedal Position Sensor/Switch "E" Circuit Range/Performance P2127 Throttle/Pedal Position Sensor/Switch "E" Circuit Low Input P2128 Throttle/Pedal Position Sensor/Switch "E" Circuit High Input P2138 Throttle/Pedal Position Sensor/Switch "D"/"E" Voltage Correlation P2511 ECM/PCM Power Relay Sense Circuit Intermittent P2519 A/C Request "A" Circuit P2532 Ignition Switch Run Position Circuit High P3000 HV Battery Malfunction P3004 Power Cable Malfunction P3107 Airbag ECU Communication Circuit Malfunction P3108 A/C Amplifier Communication Circuit Malfunction P3110 IGCT Relay Malfunction P3137 Collision Sensor Low Input P3138 Collision Sensor High Input P3147 Transmission Malfunction P3221 Generator Inverter Temperature Sensor Circuit Range/Performance P3222 Generator Inverter Temperature Sensor Circuit High/Low P3223 Generator Inverter Temperature Sensor Circuit High P3226 DC/DC Boost Converter Temperature Sensor P3227 Converter Temperature Sensor Circuit Low P3228 Converter Temperature Sensor Circuit High P3232 Open or Short to B+ in Blocking of HV Gate Connection P3233 Short to B+ in Blocking of HV Gate Connection U0100 Lost Communication with ECM/PCM "A" U0110 Lost Communication with Driver Motor Control Module U0129 Lost Communication with Brake System Control Module U0140 Lost Communication with Body Control Module U0151 Lost Communication with Airbag ECU U0164 Lost Communication with A/C ECU U0424 Invalid Data Received from HVAC Control Module POWER STEERING (HYBRID) DTCS (A00304772) POWER STEERING (HYBRID) DIAGNOSTIC TROUBLE CODE (DTC) IDENTIFICATION DTC Description C1511 Torque Sensor Circuit Malfunction C1512 Torque Sensor Circuit Malfunction C1513 Torque Sensor Circuit Malfunction C1515 Torque Sensor Zero Point Adjustment Undone C1516 Torque Sensor Zero Point Adjustment Incomplete C1521 Motor Circuit Malfunction C1522 Motor Circuit Malfunction C1523 Motor Circuit Malfunction C1524 Motor Circuit Malfunction C1525 Rotation Angle Sensor Initialization Undone C1526 Rotation Angle Sensor Initialization Incomplete C1528 Motor Rotation Angle Sensor Malfunction C1531 ECU Malfunction C1532 ECU Malfunction C1533 ECU Malfunction C1534 ECU Malfunction C1541 Vehicle Speed Signal Malfunction C1551 IG Power Supply Voltage Malfunction C1552 PIG Power Supply Voltage Malfunction C1554 Power Supply Relay Failure C1555 Motor Relay Welding Failure C1581 Assist Map Number Un-Writing U0073 Control Module Communication Bus OFF U0100 Lost Communication with ECM/PCM "A" U0129 Lost Communication with Skid Control ECU U0293 Lost Communication with HV ECU SLIDING ROOF DTCS DTC Description B2341 Sensor (Motor) Failure B2342 Switch Failure B2343 Position Initialization Incomplete B2344 Position Failure STEERING COLUMN (HYBRID) DTCS DTC Description B2781 Open/Short in Steering Lock ECU B2782 Power Source Control ECU Malfunction B2788 IG2 Signal Malfunction WHEEL & TIRE DTCS DTC Description C2111 Transmitter ID1 Operation Stop C2112 Transmitter ID2 Operation Stop C2113 Transmitter ID3 Operation Stop C2114 Transmitter ID4 Operation Stop C2121 No Signal from Transmitter ID1 in Main Mode C2122 No Signal from Transmitter ID2 in Main Mode C2123 No Signal from Transmitter ID3 in Main Mode C2124 No Signal from Transmitter ID4 in Main Mode C2126 Transmitter ID not Received in Main Mode C2141 Transmitter ID1 Error C2142 Transmitter ID2 Error C2143 Transmitter ID3 Error C2144 Transmitter ID4 Error C2165 Abnormal Temperature Inside ID1 Tire C2166 Abnormal Temperature Inside ID2 Tire C2167 Abnormal Temperature Inside ID3 Tire C2168 Abnormal Temperature Inside ID4 Tire C2171 Transmitter ID not Registered C2176 Receiver Error C2177 Initialization not Completed C2179 Tire Pressure Monitor ECU Communication Stop C2181 Transmitter ID1 not Received (Test Mode DTC) C2182 Transmitter ID2 not Received (Test Mode DTC) C2183 Transmitter ID3 not Received (Test Mode DTC) C2184 Transmitter ID4 not Received (Test Mode DTC) C2191 Vehicle Speed Signal Error (Test Mode DTC) |
