Comments on the FAQ
Old Feb 8, 2008 | 04:27 AM
  #31
haroldo's Avatar
Default Re: Comments on the FAQ
Originally Posted by mikieboyblue
I edited it into the post, so I'll remember to do it when I edit the faq
Old Feb 11, 2008 | 08:06 AM
  #32
nash's Avatar
Originally Posted by ken1784
Larry and Nash wrote: TCH will not let the ICE shutdown when coasting in Stage 2.
Ken@Japan wrote: It is very strange, because all Japanese Toyota hybrid vehicles act same, ICE shuts off when coasting in Stage 2.
Action needed: Real experiment is required by a TCH driver who has ScanGauge-II.
Ken@Japan
Update: conditions - car garaged, temp 60F, ambient temp 40F, heater fan off.
- Three mornings I drove and after 1 minute, the ICE would shut off when I stopped. (Stage 2 - right?)
- I could not get the TCH ICE to stop when coasting after entering stage 2, and stopped several more times with the ICE stopping within seconds of stopping the car (all three mornings)
- Two mornings after ~3 minutes the temp gauge was on division below normal (4th mark) and the TCH began stopping when coasting ONLY if > 35mph. (Stage 3?) HOWEVER one morning (2nd test), the ICE would shut down coasting at any speed < 41mph. I was surprised and was able to replicate it twice. Why did this only happen one time out of three mornings???!!
- After ~4 minutes the temp gauge read normal (5th mark), ICE still only stopped if coasting > 35mph, or within seconds when I stopped from < 35mph. (all three mornings!!!)
- After ~5 minutes stopping gave prolonged idle (~7 seconds) and TCH entered Stage 4, and commenced stopping anytime I coasted < 41 miles per hour. Note: turning on the fan at this point would prevent the ICE from stopping. Turning the fan back off would immediately stop the ICE.
I drove the same route each morning, but hit some lights green occasionally. I was usually the only car on the road, so slowing and stopping at random was not a problem. Total distance covered from start to entering Stage 4 was constant at 1.6 miles. I turned into a cul-de-sac at 1.6 miles and always entered Stage 4 when I stopped.
I hope someone with a scan gauge can do some testing and add to this discussion. I hope this information was of some help.
Old Mar 4, 2008 | 09:29 PM
  #33
mikieboyblue's Avatar
Larry, do you want me to work these into the FAQ for you or do you plan to unlock it and take care of it?
Old Mar 4, 2008 | 11:41 PM
  #34
ken1784's Avatar
You're correct.
Warming up stages can't be discussed without coolant temperature reference using some instruments such as ScanGauge.
Ken@Japan
Old Mar 5, 2008 | 01:48 AM
  #35
haroldo's Avatar
Mikey, not sure if you can edit them, as they are my posts. I'll get around to it...hopefully sometime soon. However, if you can work it out with admin to be able to edit my posts, be my guest, although I think they'd have to give you admin powers.
Ask 'em?
Old Mar 5, 2008 | 03:42 PM
  #36
FastMover's Avatar
Old Boomer Techie
Post Re: Comments on the FAQ
...- Two mornings after ~3 minutes the temp gauge was on division below normal (4th mark) and the TCH began stopping when coasting ONLY if > 35mph. (Stage 3?) HOWEVER one morning (2nd test), the ICE would shut down coasting at any speed < 41mph. I was surprised and was able to replicate it twice. Why did this only happen one time out of three mornings???!!
I have seen the behavior also. In the instances were the ICE shut down below 35 MPH, in all cases I observed the SOC was at or near the top of the indicator. I don't know if it means anthing, but thought to ask you -- did you observe the SOC under the latter condition -- (presumably Stage 2).
Old Mar 5, 2008 | 04:26 PM
  #37
JHSmith's Avatar
Harold,
You've done a great job.
I have a question for y'all.
Do you think adding a section concerning the programming/settings for the SG-II (X) would be helpful? I see where the PC forum is starting to define other settings.
Old Mar 5, 2008 | 07:08 PM
  #38
Originally Posted by JHSmith
Harold,
Hi John,
I am not sure how many people have a SG. I know we are trying to keep the FAQ simple and for the less savvy. My 2 cents.
Old Mar 6, 2008 | 12:56 AM
  #39
haroldo's Avatar
I tend to agree 'little boy blue' (sorry, I've waited two months on that one and when you stated your age yesterday, I couldn't resist).
I don't even know what an SG-II(x) is, and I'm not sure if I want to.
My goal in setting up the FAQ was to create a quick reference for the newbie owner or curious shopper to be able to pop in and see many of the normal 'first timer' concerns. Were we to include all questions asked more than once, the FAQ would become a re-writing of the Owner's Manual.
I want the FAQ to be more 'Reader's Digest' and less 'Encyclopedia Britannica'.
Now, if one were interested in creating an "Advanced Owner's FAQ", covering topics for the high end tinkerer, I won't object. May be a good idea. I can't lend much to that endeavor since my lack of expertise, knowledge, time, and energy might prevent me from being an active participant. (Please note, creating and maintaining an FAQ is not as easy as it looks)
Old Mar 6, 2008 | 07:47 AM
  #40
Originally Posted by haroldo
I tend to agree 'little boy blue' (sorry, I've waited two months on that one and when you stated your age yesterday, I couldn't resist)....
Haha....
