coastal lockpick2 out for camry dvd input screen unlocked
Old May 5, 2009 | 01:29 AM
brentw59's Avatar
Default Re: coastal lockpick2 out for camry dvd input screen unlocked
Ok just for clarification the CD changer portion of the deck will now except DVDs after it has the added lockpick2 unit. So you could put 4 dvds in the changer instead of CDS?
Old May 5, 2009 | 06:12 PM
bkushner's Avatar
who told you that?
Old May 5, 2009 | 07:29 PM
zebrajeb's Avatar
Originally Posted by bkushner
hooked it up. All screens unlocked on nav. Video input to nav screen. Easy install.
How "easy?" I'd love one for my 2007 TCH but don't have a clue how to remove the nav unit or get behind it. Are instructions available online?
John
Old May 5, 2009 | 08:33 PM
bkushner's Avatar
search on here for "camrea" for procedure for removal of nav
Old May 5, 2009 | 08:38 PM
bkushner's Avatar
easy once you've done the camera
Old May 5, 2009 | 11:41 PM
brentw59's Avatar
No one told me the cd changer could be unlocked to play dvds. I was just asking the question because from what I had read in the previous post thats what it sounded like you were able to do. So I was asking if it was possible with the lockpick2 installed to put dvds in the changer. Or will it only work in the NAV slot.
Old May 6, 2009 | 11:59 AM
mikieboyblue's Avatar
Yes, there was a previous post that made it sound like you could put DVDs in the CD changer slot. Has anyone actually installed this device on the TCH? If so, what additional equipment (if any) is required to play DVDs on the NAV screen?
In addition, the images in a prior post, were those from the Coastal or from a user who installed the unit? If from a user, how did you play there DVD?
Lets get this clarified before we spin too far out of control.
Thanks!
Old May 6, 2009 | 08:58 PM
ga20646's Avatar
I'm confused. Did you get the 2AV or the 2WF?
Old May 8, 2009 | 12:39 PM
jkg51781's Avatar
Does the LockPick2 remove the requirement to press I Agree?
Old May 8, 2009 | 11:45 PM
brentw59's Avatar
Originally Posted by spgdxb
The website says we can have CD or DVD's in the changer!! I never knew I could put DVD's in there? There was never an option to buy a DVD changer in the '07!?
Hey bkushner I know you have the lockpick2 installed. I have a simple question for ya. There are 2 slots to install discs into behind the screen. The top one is for Music and the Bottom one is for the NAV disc. I'm curious with the lockpick2 installed are you able to put DVDS into the slot were you would normaly put Music. Or are you only able to put DVDS into the slot were the NAV disc goes.
I know what the owners manual says but I was curious if the lockpick2 unlocks the stereo so your able to place DVDS into the top audio slot.
