Check VSC System
Old Jul 13, 2015 | 01:34 PM
GeorgiaHybrid's Avatar
Default Re: Check VSC System
You will also need the INF code associated with the DTC code you have. It should be one of the following numbers, 132, 133, 134, 136, 137, 138 or 140. You will need to get that by using a pro level scan tool. This could be the ABS motor fuse, motor relay, motor relay circuit, pump motor circuit or, more than likely, the brake actuator assembly., I doubt that you could repair it where you are located at if it is the actuator assembly but the pump might be still be covered by Toyota if that is the issue.
Mikejl
Apr 25, 2022 02:38 AM
hopmedic
Aug 28, 2021 09:37 PM
backupguy
Aug 19, 2014 07:29 AM
KTLane
Feb 3, 2010 10:27 AM
rpt11
Jan 22, 2010 11:52 PM
