Check Hybrid and VSC System
Old Mar 11, 2009 | 09:02 PM
GeorgiaHybrid's Avatar
Default Re: Check Hybrid and VSC System
If you went far enough without coolant, it could have fried the inverter. I would have thought that replacing the radiator and the inverter would have cost a LOT more than a $1000.00 though. Do you have an estimate of what the dealer is going to fix? This should list every item they will fix or replace. I could see the coolant, radiator, flush and bleed the air from the coolant system (a pain to do), the labor to install everything plus the time to diagnose the problem. Over a $1,000 for that seems high but a listing of the estimate should help.
Old Mar 12, 2009 | 06:18 AM
mikieboyblue's Avatar
Originally Posted by jbollt
Wouldn't this come under auto insurance, if it is something "hitting" the car? Maybe comprehensive? Perhaps worth a call to the insurance company.
Probably but there might be a $500 deductible and then you run the risk of them increasing your rates after that. Generally (in NY, not sure about other states), when an accident, you don't have to report it unless it is more than $1000.
Old Apr 20, 2009 | 03:18 PM
diggy's Avatar
Identical failure happened to my car yesterday. Lost all coolant from the inverter reservoir. Could not drive the car because it would not hold coolant. Had the car towed to the closest Dealer Fort Bend Toyota in Richmond Tx. I was sure it was covered by warranty till they pressurized the radiator. External damage visible, must have come from a small rock.
The repair will be finished tomorrow. It should be about $700.00, have not got the final bill yet
Old May 1, 2009 | 05:06 PM
danin951's Avatar
i got the same warning: ding, ding, ding " check vcs sys" but we had no brakes . after about 20-30 seconds the warning went off and the brakes returned. anybody?
Old May 2, 2009 | 03:28 AM
rburt07's Avatar
To both Dan's above, you forgot to mention what year Camry and how many miles you have on your cars. This being your first post, are you guys related ?
Old May 2, 2009 | 09:01 AM
danin951's Avatar
the camry is a 2006 with about 45000 miles. no relation. dealer says everything checks out but this also happened to my wife while driving about two weeks later. we cannot drive the car until we get some answers.
Old May 2, 2009 | 02:16 PM
rburt07's Avatar
That's dangerous, 20 to 30 seconds without brakes for any reason. I would sure have toyota digging into this one. Please be aware you do have a emergency brake that you can use just in case. Be sure to let us know what they find to fix the problem.
The 2007 Camry hybrid was the first year I remember the car being manufactured. Could be you bought your 2007 TCH in 2006.
Old Jan 22, 2010 | 11:52 PM
guccilover's Avatar
i ran into a similar situation, I have a 2008 camrywith 60,000. i told was driving to work @ approx 30-40 mph. I slowly came to a stop at a stop sign when my car starting ringing and the monitor displayed "CHECK VSC SYSTEM". My brakes were automatically locked and i couldnt even release the brake manually. i tried off the car and turned it back on, the problem was still there. i was about 5 miles away from work, i managed to drive about 10-`15 mph and got to work. called the dealership who was not helpful over the phone. had the car towed to dealership, they ran diagnostic and found the problem in the electrical panel which tells the car to be in "skid" protection. they had to replace the electrical box/panel not quite sure but it was covered under my extended warranty. the part itself was $1500 and the labor $400. i see alot of hybird owners are running into the similar problems. coincidence???? I believe its a manufacture defect and toyota should be accountable. i going to write to them to let them know, if we all have the issue with the "vsc system" they need a closer look at the problem and fixed it!
Mikejl
Apr 25, 2022 02:38 AM
hopmedic
Aug 28, 2021 09:37 PM
backupguy
Aug 19, 2014 07:29 AM
ahmadkq
Nov 23, 2012 09:57 AM
KTLane
Feb 3, 2010 10:27 AM
