Check engine light on ODBII code P1423
Old Jul 10, 2008 | 06:45 AM
electro22's Avatar
Default Re: Check engine light on OBDII code P1423
Of course, I start my car to go to the service appointment and the light is now off!
Lost count but it seems as if it took at least 10 trips to make it turn off but it did eventually go off by itself.
Old May 12, 2010 | 04:43 PM
pmtab's Avatar
Default Re: Check engine light on ODBII code P1423
I have a similar story -- 8 months ago my 4 month old Camry had showed "check engine" after I didn't tighten the gas cap enough. Took it to the dealer and they instructed me about the need to really tighten that cap; they also reset the "check engine" light. Since then I've been pretty careful to tighten that cap . . . but the "check engine" light showed up again two days ago. I checked and tightened the cap but several starts later I still got the error. Took it in to the dealer and they showed "P1423 Fuel Tank Gross Leak, Needs Fuel Filler Neck." The dealer replaced this under warranty and the "check engine" light is again dark. Apparently it's enough of a problem that Toyota is paying for the repair ($350+) without question.
Old May 12, 2010 | 11:01 PM
rburt07's Avatar
I found P1423 code listed with many other codes under the header, Auxiliary Emission Controls.
cak615
Oct 28, 2013 08:11 PM
nash
Sep 27, 2013 10:00 AM
SadCarTime
Jul 9, 2012 08:05 AM
bear15
Sep 7, 2010 07:17 AM
n1ywb
Jun 29, 2005 02:07 PM
