Can I get XM Radio with Nav?
Old Sep 15, 2007 | 05:39 PM
jay_man2's Avatar
Beyond AM. Beyond FM.
Default Re: Can I get XM Radio with Nav?
The old Terk XM Direct products have been discontinued, and the Toyota-compatible XM Direct 2 system hasn't been released yet. When I checked a couple of weeks ago, XMFanStore was out of stock of the discontinued Toyota Terk XM Direct; a few days later, I saw this post about the replacement product, for which the Toyota-compatible cable has not been released yet.
http://www.xmfan.com/viewtopic.php?t=84222
Old Sep 16, 2007 | 05:33 AM
xdothedew's Avatar
Originally Posted by Dang
Actually the Terk shows is XM-RVR-D-001, and according to the compatibility chart it shows you need XMDTLK, which they don't appear to sell.
Later!
Dang
Good eye.. didn't read the chart thoroughly. I guess we'll just have to wait then. Thanks
Old Sep 16, 2007 | 09:53 AM
timohapi's Avatar
Just like to add from my personal experience with XM radio on my TCH. My suggestion is, if you not planning on installing it your self do it at dealer. First, if there any issue with the radio or Navigation system you are covered, even if you buy Dealers XM tuner and have someone "professionally" installed, you are OK.
One more important thing about the Toyota XM kit, DO NOT INSTALL ANTENNA WHERE IT IS SUGGESTED BY TOYOTA. Xm antenna is installed inside of the vehicle will have bad reception, I installed my XM antenna from Dealer on the top of the rear glass outside, it works great and antenna comes with double sided tape attached, you can installed anywhere you like.
Also if you are planning on installing tint film and your antenna is inside of the car, it will practically cut the signal off completely even if the film is NON-Metallic
I hope this will give you some good idea.
Tim
Old Sep 16, 2007 | 10:57 AM
jay_man2's Avatar
Tim
My dealer installed the antenna on the trunk lid, where I'd had the Audiovox XPress antenna. I was pleasantly surprised that they put it there instead of by the brake light inside. They did a nice, clean job tucking the wire and wire tying it on the right side lift arm.
VietVet'67
Apr 23, 2012 06:03 AM
cowboy
Jul 21, 2011 09:31 AM
ronnie38
Aug 6, 2008 09:33 AM
Sky Blue
Mar 12, 2008 12:28 PM
Run_n_Late
Apr 10, 2006 05:24 PM
